Toymods » Tech & Conversions » vibrations
smrt1
darwin
September 2005
icon5.gif  vibrations Wed, 28 September 2005 01:08 Go to next message
have a bad(sort of rough) vibration when car
is idling but goes away when u
put the car in motion.
have checked timing,spark,fuel
all is fine....any suggestions
holden apollo 89 5spd
smt_007
Re: vibrations Wed, 28 September 2005 01:26 Go to previous messageGo to next message
Do you mean your dash rattles and your seats vibrate, i have that problem too, my exhaust was leaking so i changed the exhaust and its a lot less now, but the exhaust guy said i have to change the bushes on the engine mount because they are worn then i wont have rattles Wink , my mate told me this a while back but i dont have time to fix it.
mic*
July 2005
Re: vibrations Wed, 28 September 2005 03:08 Go to previous messageGo to next message
Engine mounts is the first place to check.
In particular the front centre one ($120 approx).
There are five all up worth about $700 for em all(ouch)
Front and back being the most prone in an east-west configuration.
kingmick
Banned by his request
moved to tamworth
Re: vibrations Wed, 28 September 2005 03:21 Go to previous messageGo to next message
exhast is the first place to look!get in and give it a good shake
mick
smt_007
Re: vibrations Wed, 28 September 2005 04:09 Go to previous messageGo to next message
mic* wrote on Wed, 28 September 2005 13:08
Yeah your right Wink , i was told the front and rear are worn, not surprised since my car has done 380,000ks.
[Updated on: Wed, 28 September 2005 04:09]
mic*
July 2005
Re: vibrations Wed, 28 September 2005 04:12 Go to previous messageGo to next message
Yeah, exhaust too.
Heat shielding on your motor is notorious for wearing out & making vibrations... The holes in the manifold for the heat shield bolts go a mm or so from all the way through to where the gases flow. They blow/wear through from the inside and cause an exhaust leak or a lot of vibration.
smrt1
darwin
September 2005
Re: vibrations Wed, 28 September 2005 06:01 Go to previous messageGo to next message
yeah that was my next thing to
inspect every thing vibrates,dash,
column surround etc dont think it
could be the exhaust because you would
still feel it rattling or at least hear it rattling.
cost price plus 20% should get 1 for about $50 . Very Happy
mic*
July 2005
Re: vibrations Wed, 28 September 2005 06:26 Go to previous messageGo to next message
Increased rpm's obviously increased the frequency of any moise it induces. As is demonstrated by a sub-woofer - lower frequencies produce the vibrations. In this respect do not rule out that your exhaust, at idle, could be causing noise.
If interior parts are vibrating at a stand still, and not in motion, something is rough at idle. The road causes a lot of vibration itself & should bring out most rattles - anything that would present itself in a normally idling engine anyhow.
Check your mounts, intrior trim, & exhst manifold then see how u go.
smrt1
darwin
September 2005
Re: vibrations Sat, 01 October 2005 13:27 Go to previous messageGo to next message
replaced r/h side engine mount
(or engine stablizing mount as it
is correctly refered to)and that
fixed the vibrations Very Happy
smt_007
Re: vibrations Sat, 01 October 2005 13:58 Go to previous messageGo to next message
smrt1 wrote on Sat, 01 October 2005 23:27
how much did it cost?.
smrt1
darwin
September 2005
Re: vibrations Mon, 03 October 2005 03:13 Go to previous messageGo to next message
how much did it cost?.[/quote]
are you sitting down???
myself got it for $120,but that is at
cost price + 20% and 10% gst but for the
off the street customer they would pay $218.65,
plus i live in the northern territory so it
always cost more up here to buy.
living down there you might get it cheaper
best of luck and i hope it fixes your problem too.
mic*
July 2005
Re: vibrations Mon, 03 October 2005 06:16 Go to previous message
That sounds spot on smrt1.
sm_007, if you are asking for cost as a comparison, you will be pleasantly suprised to know that full retail on the front one is about $110. It will take you all of 20 minutes to replace (cold engine, or the exhaust gets tricky to work round) even if you've never done one before.
...And it will make a shitload of difference if yours is 380,000kms old.
It'll probably look like mine did; casting only left, all signs of rubber long gone Laughing Laughing
Previous Topic:Limp mode? Project Decade strikes again.
Next Topic:Which Corolla's came with oil coolers?
Current Time: Fri Oct 23 04:56:48 UTC 2026
Total time taken to generate the page: 0.022891044616699 seconds
