Toymods » Tech & Conversions » 3tgte rebuild, do i need to put these back on??
lilcrash
ipswich queensland
3tgte rebuild, do i need to put these back on?? Wed, 28 September 2005 21:04 Go to next message
ok there is a few things that i dont want tot put bak onto my engine, i will post pics of them and can sumone please tell me if i need them. i will be removing the heater lines, cold start injector and the thing on the inlet as im pretty sure i odnt need them. but im not sure about this one.
thank you
pics-
http://img264.imageshack.us/img264/193/mvc005f6oc.jpg
Re: 3tgte rebuild, do i need to put these back on?? Wed, 28 September 2005 23:11 Go to previous messageGo to next message
Yes, that is your positive crank case ventilation.
Purple_Beasty
New Zealand
Re: 3tgte rebuild, do i need to put these back on?? Thu, 29 September 2005 00:17 Go to previous messageGo to next message
You could remove it, but then need to run a catch can. Not sure how legal that is in Oz though, effects emissions.
Callum
terra
July 2005
Re: 3tgte rebuild, do i need to put these back on?? Thu, 29 September 2005 09:14 Go to previous messageGo to next message
erm, can you start the car without the cold start? i know on my engine i need hte cold start becuase fuel pump doesnt run til 400rpm+afm open.
sideshow
Re: 3tgte rebuild, do i need to put these back on?? Thu, 29 September 2005 10:08 Go to previous messageGo to next message
looks like u fukt the wire to yr knock sensor too
jackel
Re: 3tgte rebuild, do i need to put these back on?? Thu, 29 September 2005 18:00 Go to previous messageGo to next message
i've seen that engine somewhere before, oh wait it's mine Wink
the knock sensor wiring just needs to be soldered back in piss easy, i don't have a knock computer though Razz
lilcrash
ipswich queensland
Re: 3tgte rebuild, do i need to put these back on?? Thu, 29 September 2005 19:39 Go to previous messageGo to next message
ok if i gotta use it where does the hose go to??
thanx
jackel
Re: 3tgte rebuild, do i need to put these back on?? Fri, 30 September 2005 06:22 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=73924&rid=3316&S=5b9b21ad5a25bec360e355a 5059b6838&pl_view=&start=0#msg_692742
Wink
Re: 3tgte rebuild, do i need to put these back on?? Fri, 30 September 2005 09:43 Go to previous messageGo to next message
terra wrote on Thu, 29 September 2005 17:14
Cold start needs the fuel pump too dude...
And fuel pump should turn on when you put key in "Start"
But the CSI is not really needed, unless you are doing lots subzero starts.
It will be a bit harder to start the car with the CSI, but it by no means impossible.
If you are going aftermarket management, you can ditch the CSI no problems.
lilcrash
ipswich queensland
Re: 3tgte rebuild, do i need to put these back on?? Fri, 30 September 2005 13:37 Go to previous message
for wat im doing i wouldnt dream of using the standard ecu. ive been running my car on a haltech for the last i odnt know how long so i will just keep using it.
so would there be a up/down side to using the 2tg block ova the 3tg block?? ive got both blocks sitting here. the only thing i know i will need to do is put the turbo return into the sump if i use the 2tg block. is this right??
doesnt my 2tgeu tappet cover have a pcv valve on it?? so i will need to run 2???? if i do thats fine but it just sounds funny.
wat block does everyone think i should use and y??
Previous Topic:AW11 transaxle
Next Topic:blow off valve not working
Current Time: Thu Oct 29 14:09:20 UTC 2026
Total time taken to generate the page: 0.034568071365356 seconds
