Toymods » Tech & Conversions » AE86 4AGE firing order and injectors??
panda_levin86
AE86 4AGE firing order and injectors?? Thu, 29 September 2005 05:33 Go to next message
Hey guys
Does anyone know the firing order of a JDM AE86?
And if all 4 of the injectors are firing together?
Ben Wilson
Re: AE86 4AGE firing order and injectors?? Thu, 29 September 2005 05:35 Go to previous messageGo to next message
1,3,4,2 like most 4 cylinders. IIRC, they batch fire the injectors in pairs up until a certain rev range, then fire all at once from then up.
panda_levin86
Re: AE86 4AGE firing order and injectors?? Thu, 29 September 2005 05:52 Go to previous messageGo to next message
thanks for that Ben
You might be able to help me out here.
I have just put the small port 4AGE in the sprinter.
And I am having a problem.
When I start the car... it will start either fine.
Or like its running on 3 cylinger.
I am just wondering if the car is having too much fuel when it starts.
Cos when I look at the wiring diagram. It shows that it the 4 injectors are firing at the same time...
Therefore I am not sure if thats the problem.
shinybluesteel
melbourne
Re: AE86 4AGE firing order and injectors?? Thu, 29 September 2005 11:32 Go to previous message
they are babtch fired, two "squirt" at the same time.
sounds like you have a dead injecttor/bad wiring connection, when i first got my engine running one of the injector plugs was rooted, you could move it around and it would work or not work.
i replaced it with a plug from my spare loom, and it has worked perfectly ever scince.
i should have a few plugs and injectors lying around
Previous Topic:toyotas
Next Topic:Adjustable Rear Camber for MA61 - Anyone interested ? Update 9 Aug
Current Time: Fri Nov 20 22:31:21 UTC 2026
Total time taken to generate the page: 0.0053060054779053 seconds
