Toymods » Tech & Conversions » Diff making a clunking sound when changeing gears.
michaelhaynes110
Townsville, QLD, Australia
June 2005
Diff making a clunking sound when changeing gears. Thu, 29 September 2005 08:02 Go to next message
My diff goes clunk every time I change gears. Any kind of easy fixes or should I start looking for a new diff?
Will changeing the oil do anything? Can someone suggest a type so I can do it this weekend. Btw its an ra65.
Rallystanza
Re: Diff making a clunking sound when changeing gears. Thu, 29 September 2005 09:21 Go to previous messageGo to next message
It sounds like it could be a backlash issue in the diff caused by wear.
May also be lash in your tailshaft/s... Check out you backlash in the diff and also the uni's in your tailshaft/s.
Good luck with it.
Jeremy
Re: Diff making a clunking sound when changeing gears. Thu, 29 September 2005 09:56 Go to previous messageGo to next message
put handbrake on, take it out of gear, get under and try and rotate the tailshaft back and forward by hand.... it shouldn't move heaps...
if it does...
pull out centre, adjust backlash, stick it back in Wink
check all suspension monuts while you are there..
allencr
tallahassee FL usOFa
Re: Diff making a clunking sound when changeing gears. Thu, 29 September 2005 14:01 Go to previous messageGo to next message
backlash adjusters!
you are talking about the pinion/spider gear backlash, and not the ring/crownwheel & pinion backlash, right??
clubagreenie
1st street on the right
Re: Diff making a clunking sound when changeing gears. Thu, 29 September 2005 15:19 Go to previous message
No. Crownwheel/pinion lash is what will cause noise.
Take apart,
replace bearings,
reshim,
lap,
test,
preload,
set backlash,
reinstall.
profit
Previous Topic:HELP!!! CELICA!!
Next Topic:3SGE gen 2 sump capacity
Current Time: Sat Nov 21 00:13:15 UTC 2026
Total time taken to generate the page: 0.0056710243225098 seconds
