Toymods » Tech & Conversions » low pressure (6psi) elec fuel pumps...
ed_ma61
Lost in the K hole
low pressure (6psi) elec fuel pumps... Thu, 29 September 2005 12:45 Go to next message
as in title, externally mounted, needs to maintain 6psi at a reasonable rate of flow...
anyone have any recommendations? something old and crappy i can rip one off??
also, generally speaking - how does one regulate the line pressure on these pumps? or is it all a bit hit and miss...
ed
Re: low pressure (6psi) elec fuel pumps... Thu, 29 September 2005 12:49 Go to previous messageGo to next message
how reasonable a rate are we talking?
there a lot of little leccy pumps that self-regulate, but flow can't be huge i don't think..
if you are talkin as a decent lift pump, it might pay to look toward the TBI pumps.. they are only designed to provide 15psi, but with big V8 fuel consumption...
as for regulating, you can get fuel pressure regs for carby, TBI and MPI that are all pressure referenced for boost...
in the states they have heaps of MPI crap.. and aftermarket also.. what scheme did you have in mind?
ed_ma61
Lost in the K hole
Re: low pressure (6psi) elec fuel pumps... Thu, 29 September 2005 13:27 Go to previous messageGo to next message
enough to flow around 150-200hp worth of methanol at 6psi - ive yet to figure out what rate that is in L/min
and yes i know methanol will root pumps. i plan on flushing plain petrol through the pump after each use to relube everything and prevent corrosion.
ed_ma61
Lost in the K hole
Re: low pressure (6psi) elec fuel pumps... Thu, 29 September 2005 14:13 Go to previous messageGo to next message
Sizing fuel pumps for Petrol engines (approx):
For Dead-Head type regulators:
Multiply maximum horsepower by .23 to calculate minimum pump size in "free flow" GPH.
Example: 400 HP x .23 = 91 GPH "free flow"
For Return-Style regulators:
Multiply maximum horsepower by .17 to calculate minimum pump size in "free flow" GPH.
Example: 400 HP x .17 = 68 GPH "free flow"
MULTIPLIER for Methanol (approx):
FJ = Fuel Jet
MJ = Methanol jet
MJ = 2 x (FJ - (FJ x 0.15))
SO.....
for 200hp on methanol, using a dead head reg, ill need something that can flow about 78 GPH free flow
using a return type reg, ill need a pump to flow about 58 GPH free flow
i'd ideally need to maintain these kinds of flow rate at around 6psi
ed_ma61
Lost in the K hole
Re: low pressure (6psi) elec fuel pumps... Thu, 29 September 2005 14:25 Go to previous messageGo to next message
tadaa...
HOLLEY HIGH PERFORMANCE RED ELECTRIC FUEL PUMPS--- 97 GPH @ 5-7 POUNDS PRESSURE
a more 'freely' available alternative (ie: PNPL) would be good though...
Re: low pressure (6psi) elec fuel pumps... Thu, 29 September 2005 23:26 Go to previous messageGo to next message
i have/had a holley low pressure, high volume pump at the back of the RA40 - is a goddam noisy thing.
Cant remember if is 'red' of 'blue' - will be avail. in about a month or less (when i feel inclined to get under the car and remove it)
Carter make a similar sized/power pump as well.
Do any of the solid-state Ashdown pumps flow enough?
<http://www.ashdown.com.au/ezyedit/fileLib/Catalogu es/general3.pdf>
(sorry, PDF)
Re: low pressure (6psi) elec fuel pumps... Fri, 30 September 2005 04:32 Go to previous messageGo to next message
Ed - there is but one solution for you.
Henry Street Spares.
if you dont know the place, you're gay.
rob_RA40
c'town, NSW
Re: low pressure (6psi) elec fuel pumps... Fri, 30 September 2005 04:40 Go to previous messageGo to next message
ive got a low pressure lift pump u can play with if u want, if it suits your needs make offer, lunch or sex or something.
ed_ma61
Lost in the K hole
Re: low pressure (6psi) elec fuel pumps... Fri, 30 September 2005 06:29 Go to previous message
thanks guys...
PM sent Nod
Previous Topic:3SGTE in a ESTIMA
Next Topic:AE92 17" vs 18" Wheels
Current Time: Fri Nov 20 23:40:54 UTC 2026
Total time taken to generate the page: 0.0049700736999512 seconds
