Toymods » General Car Talk » 4agze gear box
pkt-rkt
March 2005
    vz
4agze gear box Thu, 29 September 2005 12:59 Go to next message
how do you tell if ya car has a lsd gearbo or standard e51 ?
i cant tell as i cant get car starter at the time being need a starter ? help me please
[Updated on: Thu, 29 September 2005 13:00]
Henn
Rosanna, Melb
Re: 4agze gear box Thu, 29 September 2005 14:12 Go to previous messageGo to next message
Put the car in neutral with handbrake off and (carefully) jack it up. Spin one wheel and check what the opposite one does.
- Spins the same way = clutch type LSD
- Spins the opposite way = rubbish
Hen
Starfire
Re: 4agze gear box Fri, 30 September 2005 01:25 Go to previous messageGo to next message
Drop a burnout
2 black lines = lsd
1 black line = rubbish
Smile
4agte
Toronto, Downtown
Re: 4agze gear box Fri, 30 September 2005 04:16 Go to previous messageGo to next message
Starfire wrote on Fri, 30 September 2005 11:25
Drop a burnout
2 black lines = lsd
Smile
this is the preferred way make sure to post the video too Very Happy
toof
Re: 4agze gear box Fri, 30 September 2005 08:41 Go to previous messageGo to next message
Henn wrote on Fri, 30 September 2005 00:12
Hen
not nessecarily.. if it locks but spins locked in the opposite direction it is most likley a viscous coupling lsd..
i had one in the mr2 and it was great on the corners. much more progressive then the clutch pack unit ive got now.. although the tight clutch pack is good for shennanigans
Darola
Taree, 4h nth of syd
Re: 4agze gear box Fri, 30 September 2005 11:36 Go to previous messageGo to next message
hey all,
another easy way to check, jack one wheel of the ground, if u cant move it, its lsd, if it moves, its no lsd
Eddie
pkt-rkt
March 2005
    vz
Re: 4agze gear box Fri, 30 September 2005 15:45 Go to previous messageGo to next message
yo i tried that eddie on the passenger side wheel , it spins
so no lsd ?
toof
Re: 4agze gear box Fri, 30 September 2005 23:16 Go to previous message
if its a viscous it will not lock until its loaded up depending on how worn it is.
have both wheels up clutch in. gearbox in gear (1st) then turn one wheel. the other wheel should lock and turn in the opposite direction.. but locked...
Previous Topic:Sump question...
Next Topic:How to get into Fibro Glass moulding ???
Current Time: Sun Oct 18 17:57:12 UTC 2026
Total time taken to generate the page: 0.0059709548950195 seconds
