Toymods » Tech & Conversions » 210's on a 6M
Cressida Supra
210's on a 6M Sun, 05 January 2003 14:08 Go to next message
i'm hopefully getting some 210cc injector for my 6m
blue ones from a 4age correct??
any tips for putting them in, cleaning them etc
its something i've never attempted before
Peewee
Re: 210's on a 6M Mon, 06 January 2003 01:26 Go to previous messageGo to next message
If you have done nothing to increase airflow into the engine (ie cams/porting/exhaust/turbo - cold air intake will do SFA) then you will gain nothing by doing this. It will just make the engine run a bit rich.
That said the blue 4AGE injectors would be the go - same plug, same impedence, same operating pressure. To fit them you will need to get to the injector rail....to get to this you may need to separate the top half of the intake manifold from the bottom half. Order the manifold gasket now - it may have to come from Japan. I think the 6MGE gasket might be different to the 5MGE.
Re: 210's on a 6M Mon, 06 January 2003 07:47 Go to previous messageGo to next message
Late 5M-GE's have the same manifold as 6M-GE's, but early ones are different. Who needs a gasket though? A tube of blue gunk works fine for me. Smile
Re: 210's on a 6M Mon, 06 January 2003 07:59 Go to previous messageGo to next message
Norbie, I mean the gasket between the two halves of the intake manifold - I'm almost 100% certain the 6MGE has bigger runners.
But point taken, who needs gaskets when you have gasket in a tube!!!! Razz
Re: 210's on a 6M Mon, 06 January 2003 12:58 Go to previous messageGo to next message
Yes, the 6M-GE has runners with a D-shape cross-section, but the later 5M-GE's apparently have these as well. Early 5M-GE's have normal O-shaped runners.
Cressida Supra
Re: 210's on a 6M Mon, 06 January 2003 13:28 Go to previous messageGo to next message
so you dont reckon running them will be any good?
even tho both the 6m runs the 5m's 182's??
all i have done is an exhaust, and i dont plan on doing anything else ever.
i was just looking at these coz they are coming up cheap
Cressida Supra
Re: 210's on a 6M Mon, 06 January 2003 13:56 Go to previous messageGo to next message
just in case it makes a difference
i'm running a manual 6m, on a 5m auto ecu
Re: 210's on a 6M Mon, 06 January 2003 20:59 Go to previous messageGo to next message
CS, I'd suggest you whack the thing on a dyno and see if it is actually running lean. A mate put a 6MGE in a MA45 and ran it on a 5ME ECU, and it was actually running a tad rich. It may be that the AF ratios can be adjusted merely by playing with the AFM spring tension.
Re: 210's on a 6M Tue, 07 January 2003 00:15 Go to previous messageGo to next message
So you've just changed the exhaust? There's no reason whatsoever to change your injectors then; as GT suggested it will just screw up the mixtures and make your car run like crap. If the mixtures do need fine-tuning this can be done on a chassis dyno by adjusting the spring tension in the airflow meter.
Cressida Supra
Re: 210's on a 6M Tue, 07 January 2003 14:49 Go to previous messageGo to next message
ok then
cheers guys
i wont worry aobut the 210's then
i'm pretty sure the mixture is safe, and maybe a tad rich
so i'll just leave it as it is
Re: 210's on a 6M Wed, 08 January 2003 10:05 Go to previous messageGo to next message
Give em to Kev! He was looking for a set of those injectors for ages! Razz
kevz0r
Re: 210's on a 6M Wed, 08 January 2003 16:08 Go to previous messageGo to next message
heh, yeah but two things, frankie
1. theyre not 210's anyway (182s.. pfft)
2. the 295s i have will be going in....
but ic first... found me one yet? check the quokka tomorrow k Razz
Re: 210's on a 6M Wed, 08 January 2003 21:44 Go to previous messageGo to next message
How would a 1JZ one do ya?
kevz0r
Re: 210's on a 6M Thu, 09 January 2003 06:37 Go to previous messageGo to next message
nah man, in/outlets in wrong place/s Confused
Re: 210's on a 6M Thu, 09 January 2003 10:22 Go to previous messageGo to next message
do you want them at opposite ends or what? i forget...
kevz0r
Re: 210's on a 6M Fri, 10 January 2003 01:49 Go to previous messageGo to next message
dont necessarily have to be at opposite ends, just something where they dont point outwards.
preferably outlet on either side, both pointing towards the engine... someone find me one! Razz
Re: 210's on a 6M Fri, 10 January 2003 01:56 Go to previous messageGo to next message
Whats wrong with pointing outwards?
kevz0r
Re: 210's on a 6M Fri, 10 January 2003 12:39 Go to previous message
would need to have excess 90 and 180 degree bends.... no can do, chief Smile
Previous Topic:4age auto idea?
Next Topic:Odyssey Battery?
Current Time: Wed Oct 14 18:47:40 UTC 2026
Total time taken to generate the page: 0.063113927841187 seconds
