Toymods » Tech & Conversions » how the fudge do I get this bitch strut off??? (pics included)
how the fudge do I get this bitch strut off??? (pics included) Fri, 30 September 2005 17:34 Go to next message
ok i've cracked it, yet AGAIN Mad
After replacing the rear right air strut last month, i had less than 3 weeks of joy until the rear left started leaking.
So i got me a new air strut, decided to change the rear left tonight for ToyotaFest.
NOW... when i tried removing the rear right, the inner crush tube of the lower strut mounting bush was iron-oxided to the little stub mount.... such that i litterally TORE the rest of the strut (inluding outer metal of said lower bush) and ended up attacking the bitch with an angle grinder to get it off.....
.... of course now this one is doing the same.
I dont want to try removing it like the last one in case i fail - cos then i have no air strut, and that is bad.
can anyone suggest an alternative method of removing this crusted up slut??
http://www.witzl.com/crown/strutmnt1.jpg
http://www.witzl.com/crown/strutmnt2.jpg
Re: how the fudge do I get this bitch strut off??? (pics included) Fri, 30 September 2005 18:13 Go to previous messageGo to next message
just a quick Q, which bit are you trying to save???
if you are just trying to get the strut and aformentioned bush bits off the stub, could you just drill out the bush 90% with a drill bit, and make it easier to rip out? then do the angle grinder jiggidy jig to make it purdy again?
if she's a bit rusty inside, the combination of expansion and chemical bonding of the rusting process will make it very nasty to get off indeed, with no love for you or the strut...
methinks gently seperating inner crush tube from the outer bit by removing as much rubber as possible.. might be the only happy way Sad
Re: how the fudge do I get this bitch strut off??? (pics included) Fri, 30 September 2005 18:14 Go to previous messageGo to next message
is that a WST bedroom lamp in the background?? my mum curses everytime i take one outside cos she knows it's going to be returned broken in half Laughing
Re: how the fudge do I get this bitch strut off??? (pics included) Fri, 30 September 2005 18:20 Go to previous messageGo to next message
yes indeed it is a bedroom lamp Razz
and the method you just outlined is how i removed the last one... so i'll have to wait until morning to fire up the angle grinder... and probably shouldnt do it around Toob's car!!
Re: how the fudge do I get this bitch strut off??? (pics included) Fri, 30 September 2005 18:41 Go to previous message
ahh bugger... sorry to confirm your fears Sad
rusting is natures "one-up" on interference fit Razz
heh heh, and cover all glass.... amazing how thise little bits of metal eat into both car and house glass Confused Sad Mad Embarassed
only other way i can think of is brute force with a decent hydraulic puller, but i doubt you could get enough purchase on the inner tube, or get enough force into it, without it being deformed and slipping anyway...
good luck Very Happy
Previous Topic:4agzer starter motor
Next Topic:4agze bov
Current Time: Fri Oct 30 07:54:44 UTC 2026
Total time taken to generate the page: 0.0044910907745361 seconds
