Toymods » Tech & Conversions » 7M-GE in MZ10 soarer
nemesis2187
7M-GE in MZ10 soarer Sat, 01 October 2005 14:03 Go to next message
Got a complete 7m-ge motor cheap as chips and need to know if its gonna be a drop straight into my mz10 soarer and if the wiring will have to be done or can it just plug straight in?
any info greatly apprecitated
Thanx
Ivan.
wilbo666
Re: 7M-GE in MZ10 soarer Sat, 01 October 2005 15:23 Go to previous messageGo to next message
Many factors depend. What is the 7M-GE out of? You will need a front sump (You can swap you M-TEU front sump of you have a MA70 7M).
You can use the engine mounts off your existing M-TEU.
The existing MZ10 High Pressure PS hose can be modified to fit.
You can use the existing Oil cooler.
You will need a shorter accelerator cable (suggest SV21 camry if I recall).
If you are going manual you can use a MA61/RA6X manual gearbox crossmember. If you are going auto I am not sure if the stock auto crossmember will fit.
The wiring will 100% not plug straight in. Laughing
You will need to extend the MZ10 alternator plug (or wire in the 7M alternator from the 7M loom).
Many other wiring efforts will need to be undertaken as well such as, wiring +Batt, +B, M-REL, STA, water temp, tacho, oil light etc etc etc.
yes ... and no.
As wilbo & i found so far:
the wiring needs some work (see above)
the gear stick hole is not in the right spot (we put 7mge+W58 to where MTEU+auto once sat)
hard line for clutch required (from celica)
power steering lines
some fuel lines
tailshafts...ma61 fits (for our setup anyway)
nothing ever just bolts up Laughing Razz
see (taken before clutch master installed):
http://everest.fit.qut.edu.au/~n4150414/MZ10%20%2014-4-2005/MZ10%207mge/tn_DSC01450.JPG
[Updated on: Sat, 01 October 2005 15:39]
Previous Topic:Hilux Diff
Next Topic:sx corolla frontmount ideas
Current Time: Sun Nov 1 00:46:21 UTC 2026
Total time taken to generate the page: 0.009530782699585 seconds
