Toymods » Tech & Conversions » speed limiter and the powerchip
AlanSupra
speed limiter and the powerchip Sun, 05 January 2003 23:56 Go to next message
I have a couple of questions regarding the 7M-GTE engine...
I require the 180km/h speed limiter to be removed somehow, due to the car being used on the track.
I would like to know whether the powerchip piggyback computer is a waste of time and money at $890. They claim a 30kW boost in power over stock, but to do this they also increase boost by 2 psi.
I would also like to know how much the powerchip is actually doing, so how much power could you expect from increasing boost by 2 psi over stock without the chip. One thing in the powerchip's favour is that they said that when the chip is installed they can remove the speed limiter.
I am not looking at large power increases, as it starts to cost $$$ to make the 7M engine reliable it higher boost pressures, so with a stock engine with stock head gasket torqued to 72lb/ft (as mine is) what sort of boost pressure is acceptable without overly compromising the reliabilty of the engine?
These probably have been covered at some stage in the forums, but I can't find all these answers. Any help appreciated.
Thanks,
Alan
jza70-mel
Perth WA
Re: speed limiter and the powerchip Tue, 14 January 2003 15:03 Go to previous messageGo to next message
Get a second hand Apexi Rev Speed Meter or some sort of "Speed cut defender" if you want to go faster than the 180kph.
From memory boost cut for the 7m-gte is 11 psi?
Check out
http://www.supras.com/sogidb/index.php
http://www.supras.com/~riemer/sonic/sonic.htm
http://www.supraforums.com
I find it hard to believe that they would be doing more than a half decent job of improving your power without dyno tuning.
They could be just leaning out your fuel mixtures "blind" which would be slightly dodgy for reliability.
Is your supra a Jap import or Aust. delivered? The local model apparently has no speed cut.
[Updated on: Tue, 14 January 2003 15:07]
hobbs
Epping NSW
Re: speed limiter and the powerchip Wed, 15 January 2003 05:59 Go to previous messageGo to next message
From memory the power increase provided by upping the boost on the stock turbo is 11 bhp per psi, so a 2 psi increase would only account for around half of the 30kw power increase claimed.
BTW who makes the chip? i didn't think many companies made them for the 7MGTE anymore.
AlanSupra
Re: speed limiter and the powerchip Wed, 15 January 2003 08:34 Go to previous messageGo to next message
My car is a Jap import. It has only been on the track once (at Sandown) where I could only just reach 180km/h on the straights anyway, so I am not 100% sure it is limited. I am hoping to go on Calder Park, Winton and Phillip Island though, where I am told the speeds reached can be higher. At this stage I think I will wait for the next track day to see for sure if it is limited.
It is a bit of a worry with the powerchip not being dyno tuned specifically for each individual vehicle, but being created for a generic model. From a data sheet they sent me, it seems that the boost is increased, and the powerchip just optimises the ignition timing for the increased boost (and for the fuel RON specified). I don't think the mixtures could really be modified due to the the ECU having an embedded unmodifyable processor.
The ~15kw power increase from the boost increase seems about right, due to powerchip claiming 18kW for the 7M-GE, because obviously they cannot increase boost on that engine!
I have no idea who makes the powerchip, but the website is:
www.powerchipgroup.com
Thanks for your replies.
jza70-mel
Perth WA
Re: speed limiter and the powerchip Wed, 15 January 2003 13:38 Go to previous message
You may find that with exhaust / intake mods you make in order of those benefits anyway.
Previous Topic:Malpassi
Next Topic:Hilux dual cab 1990 - Any one know the standard weight?
Current Time: Mon Oct 26 18:22:16 UTC 2026
Total time taken to generate the page: 0.0086069107055664 seconds
