Toymods » Tech & Conversions » random reving??
laaag
syd- northen beaches
June 2005
random reving?? Sun, 02 October 2005 11:04 Go to next message
hey guys.
when my car is idling it randomly starts reving itself Rolling Eyes
its starts at about 1000rpm then rises to 2100rmp and suddemly
drops back down again and the whole thing keeps repeating. it does this constantly untill i start driving for a while.
i just pisses me off because i have a fairly loud exhaust and
when im at traffic lights people look at me as if im being a
dickhead Embarassed
i was told it could have something to do with my clutch because
it's on its way out...
any help would be apprieciated cheers Razz
Smokey228
January 2005
Re: random reving?? Sun, 02 October 2005 11:10 Go to previous messageGo to next message
if ur idling at the lights, i cant see how it would be the clutch.
im geusing whoever told u the clutch misunderstood you, cause it would randomly jump when driving...
if ur driving along and the revs jump up as if u just punched the clutch in as u are driving along, but u didnt actualy punch the cluch, then its slipping.
shinybluesteel
melbourne
Re: random reving?? Sun, 02 October 2005 11:21 Go to previous messageGo to next message
mine did this and i have seen it a bunch of times.
do a search for "hunting idle" and if that doesnt return any posts then click on my username, click "show all posts by this user" and it should be in there somewhere.
its not the clutch
laaag
June 2005
Re: random reving?? Sun, 02 October 2005 11:23 Go to previous messageGo to next message
well it still revs itself when in neutral randomly but the
clutch is also slipping a bit.
it doesnt jump or skip but it engages right at the end of the
pedals travel an slips at high rpm Crying or Very Sad
what could be causing it to rev?
i was thinking it might also have something to with the cold
start as when its cold it idles at just over 2000rpm...
thanks smokey Razz
FKN16V
NSW, East Coast
Re: random reving?? Sun, 02 October 2005 11:41 Go to previous messageGo to next message
Either a leak in the intake manifold somewhere, you have a very dirty throtle body or a air passage in your cooling system.
Give your throttle body a good clean with some throttle body/carby clean then check timing.
If its still doing it afterwards, park up a steepish hill (front of car higher then the rear) remove radiator cap and check water levels, allow to idle for atleast 4-5mins giving the throttle a quick dab everyso often.
Last but not least if all else fails, spray some throttle body/carby cleaner around any joines on the intake manifold, if idle changes you got a air leak causing false signals from your air flow meter or map sensor which ever is the case.
Happy Hunting
Steve
laaag
June 2005
Re: random reving?? Sun, 02 October 2005 11:55 Go to previous messageGo to next message
how will the radiator effect the idle??
the engine constantly runs hot...
when not moving the temp needle gets to 3/4 or just touching
the overheating marker before the thermofan turns on and brings
the temp back down to just over 1/2. and the cycle continues Confused
when driving the airflow keeps the temp fairly regular.
thanks for the help guys Wink
FKN16V
NSW, East Coast
Re: random reving?? Sun, 02 October 2005 12:23 Go to previous messageGo to next message
Whats easier to push, water or air. Razz
if you have an air lock in your water system, when/if air comes around to the water pump its easier to move (not as heavy as water) putting less load on the motor momentarily.
Side affect "iractic/hunting idle".
its happened to me many times before i got off my damm arse and fixed the leak.
And for the record ive asked the same question you did and got these same responses that i have suggested.
And it turns out i had them all, not at once thou.
Steve
laaag
June 2005
Re: random reving?? Sun, 02 October 2005 12:50 Go to previous messageGo to next message
big thanks to steve and anyone else who contributed to this
thread Very Happy Very Happy
will try both methods and let you guys know how it goes...
laaag
June 2005
Re: random reving?? Sun, 02 October 2005 23:42 Go to previous message
ok so i parked it on my steep driveway and opened the radiator
cap when it was just warm.
it spat out some foamy water and kept hunting.
whilst running with cap off i sprayed wd40 around the intake,
throttle body, airfilter ect.... it still kept hunting exept no other changes like bogging.
so i did as fkn16v suggested and let it sit for a few minutes
occasionally reving it and it just stopped hunting a settled on about 1000rmp Very Happy Very Happy
took it for a drive and it idled perfectly....
thanks for the help guys. much appreciated Razz Razz
[Updated on: Sun, 02 October 2005 23:43]
Previous Topic:Corona 22RE vaccum diagram.
Next Topic:1gfe into ra23
Current Time: Tue Oct 20 22:56:12 UTC 2026
Total time taken to generate the page: 0.0054080486297607 seconds
