Toymods » Tech & Conversions » injecters not pulsing
syncro
ireland
injecters not pulsing Mon, 03 October 2005 00:51 Go to next message
i have a uk spec ae86 that will not start.
it was running fine until i disconected the battery to weld some seat rails, i reconnected it when i was finished and used a booster pack as the battery was flat, the car will not start.
i checked all the fuses and they are fine, i put my ecu in a friends car and it is working fine
i looked up the tech docs here for a wiring diagram. i cannot find the solenoid resistor on my car, what does this look like and where would it be? i have spark when cranking and the fuel pump is priming as it should. there is power at both pins on each injecter and there is 12v at pins No.10 and No.20 on the ecu.
any ideas what may be wrong?
[Updated on: Mon, 03 October 2005 01:05]
Re: injecters not pulsing Mon, 03 October 2005 03:36 Go to previous messageGo to next message
The injectors are earthed through the ECU.
So if the injectors have +12v, then either the ecu is not earthed well enough, or the ecu is fried.
mic*
July 2005
Re: injecters not pulsing Mon, 03 October 2005 06:42 Go to previous messageGo to next message
First up, how did you measure a voltage at the injectOr?
That is weird...
Cruzida,
Dont you think that if the earth was bad on the ECU, you would get full time open circuit, not closed??? And on other things too other than just injector circuits???
What about a short in one of the injector wires? Do you think that could make it give a power reading? After writing it and thinking, i doubt it... Confused
Re: injecters not pulsing Mon, 03 October 2005 06:50 Go to previous messageGo to next message
Injectors have constant +12v from one of the relays.
That has nothing to do with the ECU.
mic*
July 2005
Re: injecters not pulsing Mon, 03 October 2005 07:11 Go to previous messageGo to next message
Thanx Cruz -
im still learning a lot.
I thought that the relay was triggered by the ECU, so that there is no power there when ignition is off. Then the injector makes a pulse when the ECU lets it earth out through it.
Can you tell me how it works then?
Re: injecters not pulsing Mon, 03 October 2005 07:23 Go to previous messageGo to next message
Relay is triggered by START or AFM signal.
That is the Circuit Opening Relay.
The EFI Main Relay is triggered by the ecu, and that powers the ecu itself.
syncro
ireland
Re: injecters not pulsing Mon, 03 October 2005 11:02 Go to previous messageGo to next message
my ecu is not fried, i put it in a friends car and that starts and drives fine with it.
i printed off some info from the tech docs so im off to see if i can get my head around it, thanks for the help
http://toymods.org.au/Repository/TechDocs/4age_boo k/efi/fi_39.jpg
my problem is im only getting 0.4 volts between STA and E1 on the ECU during cranking, i should have 6-14 volts
[Updated on: Mon, 03 October 2005 13:49]
mic*
July 2005
Re: injecters not pulsing Mon, 03 October 2005 22:34 Go to previous messageGo to next message
Looking at the schematic, Cruz, your bad earth theory at E1 is not disproved then.
And if this earth wire from the ECU clip to the body on the other car was ok everything would run fine wouldn it
wilbo666
Re: injecters not pulsing Tue, 04 October 2005 01:32 Go to previous messageGo to next message
Or it could also be the ECU getting no STA signal....
If the ECU is good then it obviously has to be a wiring issue.
Check the earths, the ECU power (it has power when cranking), continuity between the injector wires and the ECU...
If you pull the diag codes from it the lack of STA signal should be throwing one.
Re: injecters not pulsing Tue, 04 October 2005 02:55 Go to previous messageGo to next message
It will still start without an STA signal.
wilbo666
Re: injecters not pulsing Tue, 04 October 2005 04:05 Go to previous messageGo to next message
CrUZsida wrote on Tue, 04 October 2005 12:55
Yeah, I was under that impression as well, but who knows...
Bill Sherwood
Brisbane / Gold Coast
Re: injecters not pulsing Tue, 04 October 2005 04:46 Go to previous messageGo to next message
If the injectors have been sitting around for a shile it's possible they've jammed-up.
Give them a gentle tap on the side with a small hammer to see if that helps.
syncro
ireland
Re: injecters not pulsing Tue, 04 October 2005 12:01 Go to previous messageGo to next message
ill give that a try, ill check all earths again
the diagnostic code is: one short flash-pause for 5 seconds-one short flash-pause for 5 seconds, i think it means system ok
ill try tapping injecters
i spent about 4 hours at it yesterday and my brain turned to mush
syncro
ireland
Re: injecters not pulsing Tue, 04 October 2005 19:46 Go to previous message
its running again!
there was a bad earth on a resister that mounts near the fusebox on the lhs chassis leg.
big thank you for the advice guys Smile
Previous Topic:Is this definately head gasket ?
Next Topic:jzx90 wiring diagram, where is it?
Current Time: Tue Oct 27 11:29:06 UTC 2026
Total time taken to generate the page: 0.0063760280609131 seconds
