Toymods » Tech & Conversions » what alternators fit 18rg's
RA40Celica
Hobart
  chris_rg@jabber.org
what alternators fit 18rg's Mon, 03 October 2005 02:11 Go to next message
I need an alternator with better current ability for my 18rg with upgraded headlights.
Anyone know of an alternator with better current that will fit the mounts?
Or even an alternator which i can swap the guts with?
Chris
Mr DOHC
Re: what alternators fit 18rg's Mon, 03 October 2005 07:37 Go to previous messageGo to next message
just get yours rebuilt and get it upgraded, they can change the guts to make it better
or get a better aftermarket one
willwal98
Toowoomba
Re: what alternators fit 18rg's Mon, 03 October 2005 23:28 Go to previous messageGo to next message
I fitted a 90amp (or was it 100) alt froma Nissan Pulsar onto mine. The lower mount was a very close fit, just drilled to holes to take the original bolt, and made a new top bracket. Was an easy fit, i'm sure there are other easy fits if you go the wreckers and do some measuring or if you know a parts supplier willing to go through his books for you and get measurments.
But Just for headlights you shouldn't need a bigger alt. If you are having problems maybe you should look at your wiringg (make sure it's clear) and check your alternator power leads and battery earth strap.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: what alternators fit 18rg's Tue, 04 October 2005 01:10 Go to previous messageGo to next message
well if the standard alternator is only 40A and i have 400W of lights running at 12V, thats 33A just in headlights. Then you have to add the EFI system, and sometimes wipers or fan, not to hard to get over 40A. Espceically when the battery is charging aswell.
But you are right, i will be checking my wiring aswell.
this alternator i have now is definitely rooted though, hardly charges at all.
willwal98
Toowoomba
Re: what alternators fit 18rg's Tue, 04 October 2005 13:38 Go to previous messageGo to next message
wtf you doin with 400w of lights? If it's stuffed it's a good time to upgrade. Like Mr DOHC suggested you can rebuild, price that and a new high capactiy alt. I got mine for $90 but that's not much over wholesale.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: what alternators fit 18rg's Tue, 04 October 2005 21:50 Go to previous messageGo to next message
lol... 400W means i can see wombats coming, lol. Previous owner did it, and i love it.
I took it to a local auto electrican today, he said 'nup' can't upgrade it. He was crapping on about changing the regulator for a higher voltage one. Why is a higher voltage needed?, the alternator just needs to be able to supply more current. If the alternator was able to supply the current the regulator would be fine at its 13.5 or whatever it is.
So he is looking into getting an alternator with an internal regulator with similiar mounts.
Mr DOHC any idea what guts went into yours?
Chris
RA40Celica
Hobart
  chris_rg@jabber.org
Re: what alternators fit 18rg's Tue, 04 October 2005 22:04 Go to previous messageGo to next message
Got a call from the auto elec. he wants to sell me a 'battery sensing' alternator 70A output for $220.
M.J.H
Re: what alternators fit 18rg's Tue, 04 October 2005 22:54 Go to previous messageGo to next message
I had a bosch ext reg one and got the XF Falcon int reg guts fitted to the original Toyota case on mine.
Had to use a small spacer on the rear of the bracket but appart from that it was all fine.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: what alternators fit 18rg's Tue, 04 October 2005 23:18 Go to previous messageGo to next message
i think mine a nippon denso one.
[Updated on: Tue, 04 October 2005 23:18]
RA40Celica
Hobart
  chris_rg@jabber.org
Re: what alternators fit 18rg's Fri, 07 October 2005 10:45 Go to previous message
for future reference....
I ended up getting an alternator to suit a pintara. The mounts are almost the same just needs a couple of washers for spacers, and the pulley changing over.
provides 75Amps of current and is internally regulated
Chris
Previous Topic:Corona RT142 Wheel offset question
Next Topic:Intercooler question
Current Time: Wed Nov 25 22:21:28 UTC 2026
Total time taken to generate the page: 0.037551879882812 seconds
