Toymods » Tech & Conversions » Jaycar Universal High Energy Ignition Kit
michaelhaynes110
Townsville, QLD, Australia
June 2005
Jaycar Universal High Energy Ignition Kit Mon, 03 October 2005 13:21 Go to next message
Just having a look at the ignition kit that jaycar has for sale.
http://www.jaycar.com.au/productView.asp?ID=KC5247 &CATID=&keywords=ignition&SPECIAL=& ;form=KEYWORD&ProdCodeOnly=&Keyword1=& Keyword2=&pageNumber=&priceMin=&priceM ax=&SUBCATID=
Has anyone actually used one? Would it be beneficial on a 22re? Worth the money? How do you hook one of these up?
Re: Jaycar Universal High Energy Ignition Kit Mon, 03 October 2005 13:31 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=search
keywords "jaycar hei" or "jaycar high energy"
good luck Very Happy
Grant
Newcastle, NSW, Australia
Re: Jaycar Universal High Energy Ignition Kit Mon, 03 October 2005 21:35 Go to previous messageGo to next message
The kit works well. I used one many years ago when I still had a points ignition.
Chris Davey
sunny coast, qld
Re: Jaycar Universal High Energy Ignition Kit Tue, 04 October 2005 03:32 Go to previous messageGo to next message
Had a look at a different thread but didn't answer the easy question I have. Can you use this on an ignition system that has no distributor so it is a multi coil setup?
Re: Jaycar Universal High Energy Ignition Kit Tue, 04 October 2005 03:49 Go to previous messageGo to next message
no - only input is from the dizzi (be it points, or hall effect or...) and it can only drive one coil.
if you want waste-spark or CoP, then you need crank-trigger (and Cam sensor if CoP).
With MS-n-S, you could adapt a Toyota 24tooth dizzi to be a crank trigger (12-2 wheel) and drive 3 coil packs. But you'd be a pioneer.
If the wolf does waste-spark - use it to reduce complexity.
Chris Davey
sunny coast, qld
Re: Jaycar Universal High Energy Ignition Kit Tue, 04 October 2005 04:18 Go to previous messageGo to next message
Thanks Charles. Wolf does waste spark. I was unsure if this HEI was similar to a CDI unit but looks like it isn’t Sad
Re: Jaycar Universal High Energy Ignition Kit Tue, 04 October 2005 04:50 Go to previous messageGo to next message
the HEi is actually an ignitor with different inputs Wink
it can be used (vaguely) with reluctor dizzies, easily with hall efffect (5V switch) or points (12V switch), and CAN be used with aftermarket ECU's (i had it triggering from MS2's 5V output)
you can use the circuit to drive the coils as a (sometimes) cheaper alternative to ignitors..
gearb0x
Re: Jaycar Universal High Energy Ignition Kit Tue, 04 October 2005 12:24 Go to previous messageGo to next message
anyone know anything aboot the boost retard features on the jaycar HEI?
Re: Jaycar Universal High Energy Ignition Kit Tue, 04 October 2005 12:43 Go to previous messageGo to next message
it has boost retard?
gearb0x
Re: Jaycar Universal High Energy Ignition Kit Tue, 04 October 2005 12:52 Go to previous messageGo to next message
Ive heard it mentioned several places, maybe its only with the programable ignition kit, which jaycar doesnt seem to supply anymore
Maurice c
Re: Jaycar Universal High Energy Ignition Kit Tue, 04 October 2005 17:50 Go to previous messageGo to next message
Jaycar still does the programmable ignition but I've never heard of it controlling boost before. I know that it can control vacuum advance, does anybody know how it figures out when to advance without a map sensor etc? Sorry for the thread hop.
[Updated on: Wed, 05 October 2005 03:33]
Re: Jaycar Universal High Energy Ignition Kit Thu, 06 October 2005 07:24 Go to previous messageGo to next message
stay tuned... next year a PIC microcontroller based new version of the electronic ignition kit and a FULLY PROGRAMMABLE option will be available!!!
Im talking ignition timing programmable on RPM vs MAP!!
Chris Davey
sunny coast, qld
Re: Jaycar Universal High Energy Ignition Kit Thu, 06 October 2005 08:25 Go to previous messageGo to next message
THE WITZL wrote on Thu, 06 October 2005 17:24
Does this boost spark or just control it?
Re: Jaycar Universal High Energy Ignition Kit Thu, 06 October 2005 22:14 Go to previous messageGo to next message
Chris - this shouldnt matter to you, because your Wolf3D already does what the above is supposed to. Razz
This kit does enhance the spark, but not massively when compared to a modern day electronic ignition system.
You'd have to read the article (which doesnt come out until Dec or Jan) to fully understand Razz
Chris Davey
sunny coast, qld
Re: Jaycar Universal High Energy Ignition Kit Thu, 06 October 2005 22:38 Go to previous messageGo to next message
Thanks mate. I was just checking if this was going to be a similar product to a HKS DLI or CDI type thing. Smile
Maurice c
Re: Jaycar Universal High Energy Ignition Kit Fri, 07 October 2005 05:01 Go to previous messageGo to next message
Can't wait to put one of those together.
Re: Jaycar Universal High Energy Ignition Kit Fri, 07 October 2005 16:33 Go to previous message
me three Smile sound sgood!!
Previous Topic:ke70 parts into a ke55?
Next Topic:KE55 Front Discs+Caliper Onto KE30
Current Time: Thu Nov 19 08:15:24 UTC 2026
Total time taken to generate the page: 0.011405944824219 seconds
