Toymods » Tech & Conversions » ae92 front sway bar
Flem
cambo
ae92 front sway bar Mon, 06 January 2003 08:53 Go to next message
ive got a az92 holden nova (4afc) and it dont come with a sway bar if any one has a front sway bar other than a stock sx bar could you tell me the cost brand and size and how good it is , also is bigger better?.If it makes any difference ive got a 18mm rear sway bar from whiteline $165
haggis
Re: ae92 front sway bar Mon, 06 January 2003 10:00 Go to previous message
Dont forget to check that a sway bar will actualy fit! On the AE82 model corollas, only the hatch shells had the chassis mounting points for the sway bar. Sedans don't.
I'm not sure abut the different versions of the AE92, but its worth checking before buying!
Bigger may well be better depending on what you want the car to do. A sway bar will not help if there is a problem with the suspension setup in the first place. Best to talk to a suspension expert about how you want the car to handle before buying parts.
Craig.
Previous Topic:help!!!
Next Topic:how do you hook up an ammetre gauge?
Current Time: Sat Nov 21 04:00:58 UTC 2026
Total time taken to generate the page: 0.0054781436920166 seconds
