Toymods » Tech & Conversions » Busted fuel / rear brake lines
white86
Busted fuel / rear brake lines Tue, 04 October 2005 21:52 Go to next message
Hi everyone,
I bought someone's incomplete ae86 project and found that in taking out the gearbox the fuel and brake lines running in the transmission tunnel had been damaged.
What are my options to replace them?
The damage section is only about 15-20cm long on all lines and none of them are actaully punctured. I'm considering cutting out the dodgy section and just silver soldiering new bits of pipe in.
Opinions?
M.J.H
Re: Busted fuel / rear brake lines Tue, 04 October 2005 23:01 Go to previous messageGo to next message
easiest fix for the fuel line would be to cut out the damaged section and replace with some rubber hose,or get a small lenght of steel line and use the hose to join in the new and old sections.
As for the brake line do it properly and take the whole thing out and get a new one made at the brake shop.Not to hard to bend it into place as you refit it.
white86
Re: Busted fuel / rear brake lines Wed, 05 October 2005 01:20 Go to previous messageGo to next message
Hmm, would rubber sections be suitable in an efi setup though?
beige_bandit
September 2005
Re: Busted fuel / rear brake lines Wed, 05 October 2005 01:40 Go to previous messageGo to next message
if its hose to suit efi you'll be right
but dont muck around with the brake lines!
get some copper brake lines, easy to bend to
the shape you need
Hunty
Re: Busted fuel / rear brake lines Wed, 05 October 2005 04:04 Go to previous messageGo to next message
what about the heat? will a rubber hose be ok??
beige_bandit
September 2005
Re: Busted fuel / rear brake lines Wed, 05 October 2005 08:22 Go to previous messageGo to next message
how far from exhaust is them?
white86
Re: Busted fuel / rear brake lines Wed, 05 October 2005 13:44 Go to previous messageGo to next message
close in some parts
beige_bandit
September 2005
Re: Busted fuel / rear brake lines Wed, 05 October 2005 22:13 Go to previous message
how close?
more or less than 10cm?
Previous Topic:3t in ta22
Next Topic:Water/Rust type stains around Spark plug wells!
Current Time: Sat Nov 21 13:28:33 UTC 2026
Total time taken to generate the page: 0.0056171417236328 seconds
