Classifieds » Miscellaneous » 1000w AMP
AZAE86
Bundoora/Blackburn
icon11.gif  1000w AMP Thu, 06 June 2002 01:55 Go to next message
B-52 Furious Eagle Amplifier.
- 2 channel 1000w.
- Bridging capabilities.
- All the options, bass boost, gain, line out.
- Solid Di-cast shell, shaped like American Eagle.
This Amp was bought off SIREX two days ago, due to unforseen engine problems i cant afford to buy a system. This amp was running on two Kicker 600w Subs and went hard.
Was bought for $400 will sell for same.
Am in Melbourne.
SomeCorona
Re: 1000w AMP Thu, 06 June 2002 04:34 Go to previous messageGo to next message
I may be interested, do you have any pics at all, or even a link to the product somewhere?
AZAE86
Bundoora/Blackburn
Re: 1000w AMP Thu, 06 June 2002 05:09 Go to previous messageGo to next message
no sorry, all i can tell you is its american, it is about 40cm x 25cm x 7cm. it weighs a bit, very rugged and is cast in the shape of an eagle, wings and the head cocked to the side. SIREX only had it for a year, and no dramas, not run hot or anything.
Flem
cambo
Re: 1000w AMP Sat, 08 June 2002 12:42 Go to previous messageGo to next message
is that a mono block amp(class d)? - fuses how many and wat are they rated at?
[Updated on: Sat, 08 June 2002 12:43]
AZAE86
Bundoora/Blackburn
Re: 1000w AMP Mon, 10 June 2002 22:42 Go to previous messageGo to next message
i dont know if its D class but it has two fuses rated at 30 i think, will check tonight. mono block? its bridgeable to mono if that helps????
AZAE86
Bundoora/Blackburn
Re: 1000w AMP Tue, 11 June 2002 04:24 Go to previous message
Extra Heavy Duty Die Cast Heatsink
MOSFET Power Supply
Variable Hi/Lo Pass Crossovers
Bass Boost
2 Ohm Stereo Stable
Hi/Lo Level Inputs
Soft Turn on/Off Circuit
Discrete Wire Connections
Power LED Indicators
Soft Turn-On/Off circuit eliminates the annoying "pop." on power up or power down
Gold Plated RCA connectors for minimized line-loss, resistance and corrosion resistance.
Variable Gain Control.
Multi-Mode Bridgeable channels offer wide choice of output configurations and possibilities.
Previous Topic:ALPINE V12 AMP MRV 1005
Next Topic:FS: MA70/GA70 Brake Master Cylinder
Current Time: Fri Nov 20 01:19:38 UTC 2026
Total time taken to generate the page: 0.010316848754883 seconds
