Toymods » Tech & Conversions » JDM AE86 in-tank pump vs. VL external pump
Phrostbyte
Frankston, Victoria
JDM AE86 in-tank pump vs. VL external pump Wed, 05 October 2005 10:15 Go to next message
Just wondering the flow rate on each of the above pumps, does anyone know?
Kev.
EVOSTi
cambo
      no
Re: JDM AE86 in-tank pump vs. VL external pump Wed, 05 October 2005 11:51 Go to previous messageGo to next message
i dont have the specs for the sprinter pump but do have for the VL pump so can only guess but i would imagine the VL pump to flow a greater amount of fuel. it is after all used on 6cyl and 6cyl turbo engines.
Ken_T
June 2005
Re: JDM AE86 in-tank pump vs. VL external pump Wed, 05 October 2005 13:06 Go to previous messageGo to next message
I looked up the flow rates for the VL pump the other day but I've forgotten what it was. Laughing Sorry mate.
Sam_Q
S.E suberbs, Vic
Re: JDM AE86 in-tank pump vs. VL external pump Wed, 05 October 2005 23:44 Go to previous messageGo to next message
the VL and VL turbo pumps are the same and if I rememebr correctly they support over 200kw
Phrostbyte
Frankston, Victoria
Re: JDM AE86 in-tank pump vs. VL external pump Thu, 06 October 2005 00:35 Go to previous messageGo to next message
Yeah just that I have a trade pending at the moment... I have a JDM AE86 internal fuel pump with mount, but it won't fit in the KE70 tank, I'd need to get an AE86 tank... One of the people that is interested in trading a VL pump to me for it, wants to know how many kw the JDM pump would withstand?
Kev.
Lambolica
Northwestern Sydney
Re: JDM AE86 in-tank pump vs. VL external pump Thu, 06 October 2005 02:33 Go to previous messageGo to next message
I started running into issues running the AE86 pump at around 130rwkw on a 1G.
Jonny2TG
Tasmania
Re: JDM AE86 in-tank pump vs. VL external pump Thu, 06 October 2005 07:18 Go to previous messageGo to next message
And keeping with this theame...
do you think the stock fuel line in the Aussie AE86 will be big enough dia for 130rwkw also? And can the stock fuel line in AE86 be flaired for high pressure fittings from intank pump to fuel filter? This is what I plan to do.
I have a mate with a KE20, 4A-GTE with 170rwkw, does 13.1sec etc... All on the stock KE20 fuel line. But a big pump in the boot I think.
LiL_MiC
Melb
Re: JDM AE86 in-tank pump vs. VL external pump Thu, 06 October 2005 07:35 Go to previous messageGo to next message
my ae86 pump died a couple of months ago.. what you get for 20 y/o pump.
luckily i just exited teh freeway and coasted it into a sidestreet, as i could've been stuck right on the exit inbound toorak rd on peak hour!!
Jonny2TG
Tasmania
Re: JDM AE86 in-tank pump vs. VL external pump Thu, 06 October 2005 08:11 Go to previous messageGo to next message
I am wanting to go to the JDM AE86 intank setup. I think I have to buy the AE82 twincam or AE92 intank pump and brakets, and it should bolt in ??
But I don't care for the age of the actual pump, because I have a newish V6 Camry pump that should fit in the bracket (a fringe benifit of working at a dealership). I also got a RAV4 pump, which should also be good enough.
Blackers
Forrestdale W.A.
Re: JDM AE86 in-tank pump vs. VL external pump Thu, 06 October 2005 08:34 Go to previous messageGo to next message
Why do you need to have the AE82 brackets etc, surely you could make something to fit any pump? I cut and welded a plate from a pintara tank into my AE86 ADM tank and have an Audi fuel pump inside it as well as the home made internal swirl pot. There is a thread about welding fuel tanks, have a look at that and see what you can come up with.
Blackers
EVOSTi
cambo
      no
Re: JDM AE86 in-tank pump vs. VL external pump Thu, 06 October 2005 10:43 Go to previous messageGo to next message
a VL fuel pump CAN support 200RWKW as can the standard fuel lines. thats the steel lines not the original carby rubber hoses obviously.
Lambolica
Northwestern Sydney
Re: JDM AE86 in-tank pump vs. VL external pump Thu, 06 October 2005 22:14 Go to previous message
Yeah I can't help on the fuel lines as mine are up sized.
I now run a walbro intank pump on the AE86 mount. Smile
Previous Topic:Toyot Celica Har Top 77 compression ratio??
Next Topic:4agze timing belt
Current Time: Sun Oct 25 08:11:10 UTC 2026
Total time taken to generate the page: 0.0063059329986572 seconds
