Toymods » Tech & Conversions » 4AGZE CAS Timing
Necros
4AGZE CAS Timing Thu, 06 October 2005 03:04 Go to next message
Does anyone know how to set the crank angle sensor timing on a 4AGZE?
nick.parker
January 2005
Re: 4AGZE CAS Timing Thu, 06 October 2005 03:50 Go to previous messageGo to next message
- Short E to T1 on the diagnostic connector (fixes timing to 10°)
-Get a timing light with trigger lead attached to cylinder one ignition lead (closed to crank pulley).
-start up engine
-check ignition timing should be 10° (most anti-clockwise timing mark on crank pulley (marks are TDC, 10°,14° advance)
-stop engine
-loosen position locking bolt on the CAS and adjust a TINY amount
-re-check timing
Now you know which way to rotate the CAS keep adjusting until its its right!
Cheers, Nick
Necros
Re: 4AGZE CAS Timing Sat, 08 October 2005 12:02 Go to previous messageGo to next message
Hi Nick,
Do you know how to set the timing if the CAS has been removed from the engine?
Re: 4AGZE CAS Timing Sun, 09 October 2005 08:52 Go to previous messageGo to next message
same as any other 4age.
EVOSTi
cambo
      no
Re: 4AGZE CAS Timing Sun, 09 October 2005 08:56 Go to previous messageGo to next message
basically you just put it in and have a guess, keep doing so till you get it close enough.
ChuckLandwehr
Re: 4AGZE CAS Timing Sun, 09 October 2005 09:10 Go to previous messageGo to next message
From the 4AGE manual: Set No1 TDC compression stroke, align the drill mark on the CAS shaft with the protrusion on the housing. Insert CAS into cylinder head.
From memory, Wink there are markings on the lip of the CAS body, which are visible when the CAS cover is removed. Align the drillmarked rotor arm, with the marks on the housing. Install CAS.
cheers Chuck.
Necros
Re: 4AGZE CAS Timing Sun, 09 October 2005 09:31 Go to previous messageGo to next message
Ok, great ill give it a go... thanx
Re: 4AGZE CAS Timing Sun, 09 October 2005 10:10 Go to previous message
http://www.toymods.org.au -> tech docs -> 4age book
Previous Topic:3sgte intercooler cap pressure
Next Topic:rattle in exhaust
Current Time: Mon Nov 2 09:28:15 UTC 2026
Total time taken to generate the page: 0.006911039352417 seconds
