Toymods » Tech & Conversions » rocker cover removal
toyota_XT130
March 2005
rocker cover removal Thu, 06 October 2005 03:31 Go to next message
hello peeps..
i have a 7mge cressida....i was wondering because of the extreme amount of oil around my rocker cover area and spark plug area...will i do any damage or cause any problems if i remove them to get cleaned...in doing this ill also clean around the spark plug area etc....
I need to get this oil cleaned off..
terra
July 2005
Re: rocker cover removal Thu, 06 October 2005 04:39 Go to previous messageGo to next message
get a new gasket(s).
you dont have rockers, its just a valve/cam cover Smile
dont drop anything in youre engine when its off >_<
ChuckLandwehr
Re: rocker cover removal Thu, 06 October 2005 04:44 Go to previous message
Hi mate, the rocker cover gaskets become hardened with age. But there is another reason, why they leak, many people either leave the nuts too loose, or quite simply overtighten the nuts. Too loose, and oil will find its way out. Too tight, and the gasket is deformed around the stud, again leaving an escape route for the oil.
Get a new gasket, but before installing, degrease the engine. Use a long thin screwdriver with absorbent rag around the tip, to clean and dry around the spark plugs. Dry out with compressed air, if you have access to a compressor and dusting pistol.
Fit your new gasket, and torque to the Toyota specs.
cheers Chuck.
Previous Topic:20v valve stem seals
Next Topic:AE101 brake upgrade
Current Time: Sat Oct 24 23:07:23 UTC 2026
Total time taken to generate the page: 0.0040838718414307 seconds
