Toymods » Tech & Conversions » ecu advice for 1j
1j180sx
goldcoast
June 2005
ecu advice for 1j Thu, 06 October 2005 04:50 Go to next message
hey guys,anyone changed to after market engine control for their 1j?
would love to hear the results and comments.
im looking for something thats not too dear,can run the accessories like factory and wont cost the earth to tune and obviously get good hp.
thanks for any help
bad experiences also want to know about
Re: ecu advice for 1j Thu, 06 October 2005 04:55 Go to previous messageGo to next message
if I had my time again, I'd definitly avoid microtech. it runs most things well... doesn't do cold start very well tho. cant comment on the new microtechs
Re: ecu advice for 1j Thu, 06 October 2005 05:07 Go to previous messageGo to next message
draven wrote on Thu, 06 October 2005 12:55
How are you controlling yout ISCV though Draven, I thought you just had your throttle cracked open a little bit? In that case, I'm not surprised it doesn't work very well Smile Grab yourself a 20v ISCV, and with a bit of patience and tuning, the Microleb will be fine Wink
Re: ecu advice for 1j Thu, 06 October 2005 05:10 Go to previous messageGo to next message
which would be great, except it only has 1 aux output, and that's controlling my thermos.
ke382TG
Re: ecu advice for 1j Thu, 06 October 2005 05:17 Go to previous messageGo to next message
What temp does the 1J operate at? Be a simple job to fit a single wire thermo switch from a 4A (if the right temp range) and use that to control the thermos, thus freeing up your auxillary output Wink
Re: ecu advice for 1j Thu, 06 October 2005 05:19 Go to previous messageGo to next message
91 currently... plans to fit a cooler thermostat are in the pipeline.
what would this single wire thermo switch connect to?
ke382TG
Re: ecu advice for 1j Thu, 06 October 2005 05:25 Go to previous messageGo to next message
They normally sit in or near the thermostat housing. Threaded.
Edit, sorry I probably did not interpet your post correctly. as far as wiring connection it is a normally closed switch so it needs to be set up as a switched earth as per WITZLS diagram for how to wire a 4AG thermo in the tech docs.
[Updated on: Thu, 06 October 2005 05:27]
Re: ecu advice for 1j Thu, 06 October 2005 06:07 Go to previous messageGo to next message
Go get the cold start tuned properly.
Mine wasn't the best, but I never really wanted it tuned.
Its only cold for about 2mins every morning, fine thereafter.
If you are willing to leave it with a competant tuner for a week, the cold start will be perfect.
I'm not sure if you can use a 20V ISCV though.
I'm only using 2 of the 4 ignition drivers, so I think 2 of them have been used for ISCV control.
You are probably using all 6 injector and all 6 ignition drivers.
Blaming the cold start on the ecu is wrong.
Blame it on the tuner, or your wallet Razz
Re: ecu advice for 1j Thu, 06 October 2005 06:19 Go to previous messageGo to next message
it's not tuner's fault, there's just not enough left of the mtech to run my iscv Sad
Re: ecu advice for 1j Thu, 06 October 2005 06:26 Go to previous messageGo to next message
You don't need an ISCV
You can use an ABV instead (AirBypass Valve)
You can get fully mechanical ones that operate via coolant temp (cold = open to let more air in, hot = closed)
You can get stand alone electrical ones that have there own sensor, and just need +12v
Or you can use a Tridon Thermo Fan Switch to control the thermos (I have one on the Cressida), and use the Microtech output to control the ABV.
Re: ecu advice for 1j Thu, 06 October 2005 06:28 Go to previous messageGo to next message
I can deal with the low idle for the first minute after starting up - just saying that if I were going to do it again, for this reason I wouldn't get a mtech
Skip
Re: ecu advice for 1j Thu, 06 October 2005 06:33 Go to previous messageGo to next message
Haltech E6X is prob easiest thats what ive got.
It uses the standard 1J sensors except for the air temp and coolant temp which is simple enough. I believe it can use the standard TPS but I just used the haltech supplied one. It will run the standard ISCV. It has 4 PWM outputs to run thermos, boost control, etc. i suggest you look at the website.
I was told it would work with the standard ignition module but my ignition started to break down over 4500rpm full load so i swapped to the haltech ones.
Only prob I have also is my cold start is shite but that once again is the fault of poor tuning.
Re: ecu advice for 1j Thu, 06 October 2005 06:35 Go to previous messageGo to next message
how much did the haltech set you back?
Re: ecu advice for 1j Thu, 06 October 2005 06:40 Go to previous messageGo to next message
The Haltech can't run full sequential fuelling and ignition though. Had Draven not wanted these features, he'd have oodles of outputs. In that case he could've gone LT10S (had it been available then) and it would still have oodles of outputs Razz
Re: ecu advice for 1j Thu, 06 October 2005 06:44 Go to previous messageGo to next message
aahhh
teh ghey
Skip
Re: ecu advice for 1j Thu, 06 October 2005 06:45 Go to previous messageGo to next message
Yes I run multipoint and waste spark Laughing
I think it was about $1545
Chris Davey
sunny coast, qld
Re: ecu advice for 1j Thu, 06 October 2005 07:18 Go to previous messageGo to next message
I have a wolf 3d V4. As you could probably tell if you read any of my other threads, I can’t get it do control timing as well as the auto. So if you have an auto I wouldn’t recommend it.
It has 2 aux outputs. One is controlling an ABV as the stock ecu is still controlling the stock ISCV and the other is for the shift light. AFAIK it can only control 4 wire ISCV’s and the 1j has a 6 wire one. So I would like to fit a 4 wire ISCV and get the wolf controlling that properly so that I can get rid of the ABV and use the aux output for something better like N2O Razz
I like the software though. It is very easy to use and I have tuned the fuel myself using my techedge wideband o2 sensor which I would also recommend.
Will comment later when I have got it doing timing as my power levels are shit now but I suspect that is the fault of the stock ecu.
Also, it uses all the stock sensors except water temp. I think it used the stock air temp one.
They are $1100 or so I think and a bit more for a hand controller.
Re: ecu advice for 1j Thu, 06 October 2005 07:22 Go to previous messageGo to next message
Dbl post.
[Updated on: Thu, 06 October 2005 07:24]
Re: ecu advice for 1j Thu, 06 October 2005 07:24 Go to previous messageGo to next message
Chris Davey wrote on Thu, 06 October 2005 15:18
The wolf version 4 can only control a 3 wire ISCV (2 controls and 1 +12v).
The wolf version 4+ can control a 4 wire ISCV (4 controls no +12v)
The stock ISCV is 6 wire (4 controls and 2 +12v).
The wolf v4+ can control the stock one, but not the wolf v4
Chris Davey
sunny coast, qld
Re: ecu advice for 1j Thu, 06 October 2005 07:52 Go to previous messageGo to next message
So can it control a 20v one like someone said before? I have also heard about a 5m one?
Re: ecu advice for 1j Thu, 06 October 2005 07:55 Go to previous messageGo to next message
5M is 6 wire like the 1JZ (at least 5MGE is, I'm not sure what 5ME was, I think that was more an ABV than an ISCV)
But yes, you should be able to control a 20V ISCV.
Chris Davey
sunny coast, qld
Re: ecu advice for 1j Thu, 06 October 2005 08:03 Go to previous messageGo to next message
Thanks mate. WIll be looking for one soon then Very Happy
1j180sx
goldcoast
June 2005
Re: ecu advice for 1j Thu, 06 October 2005 12:35 Go to previous messageGo to next message
ok,so it sounds like none of those ecu s are really ideal for a 1j?
Skip
Re: ecu advice for 1j Fri, 07 October 2005 02:56 Go to previous messageGo to next message
1j180sx wrote on Thu, 06 October 2005 20:35
I think you will find the most ideal is the E6X.
1j180sx
goldcoast
June 2005
Re: ecu advice for 1j Sat, 08 October 2005 02:18 Go to previous messageGo to next message
hey skip,why do you reckon the e6x is a good choice? it s a microtech right?
Chris Davey
sunny coast, qld
Re: ecu advice for 1j Sat, 08 October 2005 04:34 Go to previous messageGo to next message
haltech
Rossco
Re: ecu advice for 1j Sat, 08 October 2005 05:29 Go to previous messageGo to next message
im using as microtech lt12s on my 1jz and its pretty much perfect. there is a slight overfuel if i put my foot down in the first few minutes, but shouldnt be stinging it cold anyway. will get it looked at when i go back for a retune with more boost, prolly can be sorted out no dramas
bonus of microtech is they r one of the cheapest ecus around, and do the job fine.
Re: ecu advice for 1j Sat, 08 October 2005 07:09 Go to previous messageGo to next message
how does it go controlling your ISCV?
I know the new mtechs have more outputs (apparently)
slylux
perth WA
    nup
Re: ecu advice for 1j Sat, 08 October 2005 09:27 Go to previous messageGo to next message
where in perth u getting the microtech tuned ???
Rossco
Re: ecu advice for 1j Sun, 09 October 2005 05:09 Go to previous messageGo to next message
it was tuned at ovaboost in malaga, more then likely going back to them for high boost tune
Ross
Skip
Re: ecu advice for 1j Mon, 10 October 2005 02:50 Go to previous messageGo to next message
1j180sx wrote on Sat, 08 October 2005 10:18
Price, easier to tune with the new halwin software, it's ability to use the ISCV/O2 sensor/CAS etc, lots of outputs.
The LTX12 may do all this but not sure of price. It's been 2 years since i bought my E6X so maybe there is better producton the market to suit 1J now???
Blackers
Forrestdale W.A.
Re: ecu advice for 1j Mon, 10 October 2005 23:51 Go to previous message
I personally like Rotomotion, they are on the conservative side with the BHP figures but none of their tunes that I know of have made an engine go bang! I prefer a healthy safety factor and they always accomodate this.
Mark
Previous Topic:20v Kw reading???
Next Topic:4age cams, ecu, quad throttle bodies...
Current Time: Sun Nov 22 07:19:27 UTC 2026
Total time taken to generate the page: 0.0091578960418701 seconds
