Toymods » Tech & Conversions » 1JZ stock oil pressure sender unit
MR 1JZ
1JZ stock oil pressure sender unit Thu, 06 October 2005 05:47 Go to next message
Hey all,
Im installing an aftermarket oil pressure guage on my soarer at the moment and I have one final hurdle to cross and thats the location of the stock sender unit for the factory guage...
mine doesnt work in the dash anyway so I figure ill remove the stock one and replace it with the Autometer aftermarket one but I am having trouble finding it...
anyone have any ideas where it would be?
Re: 1JZ stock oil pressure sender unit Thu, 06 October 2005 05:55 Go to previous messageGo to next message
Just check whether or not it's going to work. If the engine came out of a car with an oil pressure switch it may not work properly with a gauge.
MR 1JZ
Re: 1JZ stock oil pressure sender unit Thu, 06 October 2005 06:09 Go to previous messageGo to next message
no i want to remove the stock sender unit and put my own sender unit in...
Skip
Re: 1JZ stock oil pressure sender unit Thu, 06 October 2005 06:43 Go to previous messageGo to next message
I have an auto meter oil gauge, I ended up going the union bolt method for getting a signal. AFAIK the standard sensor is down near the aircon and is a PITA, you would have to remove the aircon condenser and PS pump to get too it???
I cant remember why i settled on what i did but i did and i think you know that i think you should do what i did even though i cant remember why i did what i did. Smile
Chris Davey
sunny coast, qld
Re: 1JZ stock oil pressure sender unit Thu, 06 October 2005 07:29 Go to previous messageGo to next message
Since you are single turbo just use the outlet from one of the old turbos. That is what I did. So much easier than trying to fit an aftermarket sended in the factory position!
Skip
Re: 1JZ stock oil pressure sender unit Thu, 06 October 2005 07:30 Go to previous messageGo to next message
Yeah but you get an end of the line pressure reading chris Very Happy
Chris Davey
sunny coast, qld
Re: 1JZ stock oil pressure sender unit Thu, 06 October 2005 07:49 Go to previous messageGo to next message
But as long as you know what the normal reading is then I can't see it being a problem.
MR 1JZ
Re: 1JZ stock oil pressure sender unit Thu, 06 October 2005 07:54 Go to previous messageGo to next message
im twin turbo still
i want to fit the sender before G1...which is this saturday Confused Confused
might have to tap in somewhere
Manny
Re: 1JZ stock oil pressure sender unit Thu, 06 October 2005 12:40 Go to previous messageGo to next message
http://www.mkiv.com/techarticles/oil_sensor_mod/in dex.html
Re: 1JZ stock oil pressure sender unit Thu, 06 October 2005 23:36 Go to previous message
Do what it says in the link above. This is the best place to get the pressure signal from as it's right after the oil pump. Tapping into the turbo oil feed is probably the worst place to do it.
Previous Topic:Nasty clutch noise
Next Topic:MX83 ntake mods - better performance/economy [7M NA]
Current Time: Thu Nov 19 21:56:14 UTC 2026
Total time taken to generate the page: 0.0059361457824707 seconds
