Toymods » Tech & Conversions » HKS P-Fcon for 4AGE?
drift86levin
brisvegas
HKS P-Fcon for 4AGE? Thu, 06 October 2005 06:48 Go to next message
hey, i managed to scam one of these for free..can anyone tell me a bit about them?? it's the oldschool one to suit the yellow plug ecu's (ae82/86)
matty
improvedae86
Re: HKS P-Fcon for 4AGE? Thu, 06 October 2005 06:56 Go to previous messageGo to next message
Did you get the wiring diagram for it ?
Hodgo
Re: HKS P-Fcon for 4AGE? Thu, 06 October 2005 11:00 Go to previous messageGo to next message
I got one on my 4agze atm, not bad, even better with the GCC thingie to fine tune.
4agte
Toronto, Downtown
Re: HKS P-Fcon for 4AGE? Thu, 06 October 2005 12:22 Go to previous messageGo to next message
mate has one on his gze seems to run well makes good power he got his retuned at bd4's
parrot
Re: HKS P-Fcon for 4AGE? Fri, 07 October 2005 04:08 Go to previous messageGo to next message
There are different proms to suit different states of tune, i.e. standard, airflow/exhaust, cams etc. The number is written on the prom and starts with an E, i.e. E138 for cams above 256 degrees.
drift86levin
brisvegas
Re: HKS P-Fcon for 4AGE? Fri, 07 October 2005 07:13 Go to previous messageGo to next message
ahh right o! this one apparently has a map sensor included, i'm using quads, higher CR, but stock cams for the moment..i've heard that the stock ECU won't handle the quads very well with the sudden change in manifold vaccume, but i am running a balance tube right through the adaptor plate for the booster, and map line..so i think it will be right..right?
parrot
Re: HKS P-Fcon for 4AGE? Sat, 08 October 2005 11:26 Go to previous messageGo to next message
The F-Con has its own map sensor. As for the quad business, has been done to death on this site. Remember the F-Con only adjusts the fuelling. If you don't end up using it, would be interested in buying but would need to know the prom code.
drift86levin
brisvegas
Re: HKS P-Fcon for 4AGE? Sat, 08 October 2005 22:40 Go to previous message
ok i'll get the code..i know the quads thing has been done do death, but there is no clean cut straight answer! some say yes with factory ECU, some say you don't have a chance etc etc.. anyway, thanks for your replies..
Matty
Previous Topic:wheel spin
Next Topic:3tgte questions
Current Time: Thu Oct 29 21:46:54 UTC 2026
Total time taken to generate the page: 0.0052781105041504 seconds
