Toymods » Tech & Conversions » Intercooler question
Big T
Intercooler question Thu, 06 October 2005 14:58 Go to next message
Hey all. I'm trying to research an appropriate IC for my car but i'm having a little trouble sifting through the shite out there Rolling Eyes Laughing
There is a cooler i'm interested in but i'm thinking it's a bit TOO big for my application. My setup will be a bigport 4agte with a gt2540 (hopefully Very Happy ) in RWD configuration. Max boost will be about 18-20 psi... about 12 for street
The IC will be front mounted. The cooler i have in mind has core dimensions of 400x250x130. Yes it is a FAT bugger. It's a tube/fin IC as well. I'm fairly certain from the pics i recieved that it's actually 2 cores that have been welded together and has custom endtanks.
So, what do people think? Any feedback appreciated.
Eddie.
[Updated on: Thu, 06 October 2005 15:00]
Re: Intercooler question Thu, 06 October 2005 23:27 Go to previous messageGo to next message
IMO there's no such thing as too big.
There are other factors to consider besides the overall dimensions though. Core type, end tank construction, direction of flow, condition of the fins etc.
I might add that I have a very fat cooler on my Supra (two JZA80 cores joined together) and I find it's had a detrimental effect on overall engine cooling. The cooler itself works really well, but it also prevents a lot of airflow getting to the radiator. I believe this is the major reason for my cooling problems, which is why I'm ditching the cooling-brick shortly in favour of a much smaller 600x300x76 eBay cooler.
shinybluesteel
melbourne
Re: Intercooler question Thu, 06 October 2005 23:50 Go to previous messageGo to next message
In line with what Norbie has said, you will get diminishing returns with increasing intercooler width/fatness.
read "maximum boost" if you want to learn about intercoolers, and plan on using one with inlet and outlet pipes on opposite corners of the core.
one of those hybrid knockoffs should be fine, and if it isn't good enough, they are cheap enough to turn in to a coffee table.
Big T
Re: Intercooler question Fri, 07 October 2005 00:11 Go to previous messageGo to next message
Cheers dudes. Here's what the cooler looks like... i don't know any of the flow rates/pressure figures unfortunately.
http://img213.imageshack.us/img213/4708/yoshicooler35rr.th.png
http://img213.imageshack.us/img213/3382/yoshicooler21gf.th.png
Fattony
Re: Intercooler question Fri, 07 October 2005 00:36 Go to previous messageGo to next message
PWR make a cooler similar to the size your after, which is what i am running now and for the mere sum of 430 dollars you get a sexcellent cooler. Core design allows proper flow and cooling of charge are whilst also allowing air to reach your radiator, they come under the name aero 2 and basically use a pre fab end tank which is the reason why the price is a lot lower than the usual run of the mill coolers available from pwr, though that said the end tank is the real restriction of the cooler and doesnt allow you to entirly use the whole core of the cooler.
mic*
July 2005
Re: Intercooler question Fri, 07 October 2005 00:46 Go to previous messageGo to next message
Looking at those shots the end tanks are welded straight onto open core, no sort of baffles or whatever. Intake charge is mostly gonna flow straight through it one side to the other. Most of the bottom of the core is effectively dead weight. That is why (as shinybluesteel said) you look for a corner to corner setup, which is the most efficient basic design.
Hey shiny - been looking for a copy of that book for ages ay. I borrowed it from the library ages ago but its gone now (any wonder). Who is the authour & where can i get it? Sad
Stefan
Hobart, Tas
Re: Intercooler question Fri, 07 October 2005 02:49 Go to previous messageGo to next message
If an I/C is bigger than it needs to be, you're adding lag.
Stefan
Hobart, Tas
Re: Intercooler question Fri, 07 October 2005 02:52 Go to previous messageGo to next message
BTW by 'corner to corner', do you mean like this? Very Happy
http://www.speedtoys.com/~stefan/1G/intercooler1.jpg
shinybluesteel
melbourne
Re: Intercooler question Fri, 07 October 2005 02:59 Go to previous messageGo to next message
absolutely not!
both of those corners are on the same side,
for it to be "opposite corners" the left end tank would look as it does (with pipe pointing down), but the end tank on the right would have the pipe pointing up.
Also, you are better off having more shorter tubes than less longer ones.
Stefan
Hobart, Tas
Re: Intercooler question Fri, 07 October 2005 03:16 Go to previous messageGo to next message
...meh.
Re: Intercooler question Fri, 07 October 2005 04:08 Go to previous messageGo to next message
Stefan wrote on Fri, 07 October 2005 12:49
In theory this is true. In practice the effect is negligible.
Compare the flow rate of your turbo to the volume of a large intercooler and you'll see what I mean.
mic*
July 2005
Re: Intercooler question Fri, 07 October 2005 04:25 Go to previous messageGo to next message
Norbie wrote on Fri, 07 October 2005 14:08
There are so many variables here, but its more to do with static drag than volume. If you had an IC with say a 10L volume it will cause more loss than a straight 100mm pipe with the same volume.
I havent done this but find a car with a way oversized IC & measure boost before vs boost after. You should measure a drop off, more than can be attributed to density changes.
Without going to any effort, corner to corner looks like this.
That should be clear enough.
mic*
July 2005
Re: Intercooler question Fri, 07 October 2005 04:27 Go to previous messageGo to next message
That didnt come out at all Mad
_________
_________=
mic*
July 2005
Re: Intercooler question Fri, 07 October 2005 04:28 Go to previous messageGo to next message
piece of crap Mad Mad
if i type a space its for a bloody reason!
Skip
Re: Intercooler question Fri, 07 October 2005 04:45 Go to previous messageGo to next message
IMHO all that thickness is useless. It is better to have a thinner cooler with more surface area and staggered inlet / outlet as suggested. That thing is just big and would be inefficient.
4agte
Toronto, Downtown
Re: Intercooler question Fri, 07 October 2005 05:52 Go to previous messageGo to next message
also may well effect the cooling of the radiator or even how much you have to chop away from the bumper but at the end of the day its going to cool better than no i/c so aslong as you didnt pay the earth the who cares bump it on and see how it goes
mic*
July 2005
Re: Intercooler question Fri, 07 October 2005 06:07 Go to previous messageGo to next message
Yeah, just chop it down the middle (thickness) first, then turn one end tank 180deg. so air goes thru it, and go for it.
The whole concept of air to air intercooling is surface area to expose to wind chill. Making your intercooler thicker follows the same logic as installing it sideways or on your rear bumper or something.
4agte
Toronto, Downtown
Re: Intercooler question Fri, 07 October 2005 07:08 Go to previous messageGo to next message
mic* wrote on Fri, 07 October 2005 16:07
ahhh well not exactly the i/c is effectively a heat sink so the more metal it has the more heat it can absorb from the charge air and the longer it will take to heatsoak plus the air will travel thru the core
Re: Intercooler question Fri, 07 October 2005 08:23 Go to previous messageGo to next message
Exactly. Most intercoolers act as a heatsink more than anything, which is why a lot of drag cars have small but very thick coolers.
Big T
Re: Intercooler question Fri, 07 October 2005 09:47 Go to previous message
Thanks for all the replies. Looks like a dirty cheap ebay cooler's the way to go then Razz
That fatty IC isn't what i'd call "dirt cheap" so i'll let it go.
Eddie.
Previous Topic:what alternators fit 18rg's
Next Topic:Ma70 aerial trigger
Current Time: Thu Nov 19 21:01:55 UTC 2026
Total time taken to generate the page: 0.027117013931274 seconds
