Toymods » Tech & Conversions » 4agte oil return - Anyone used this? (PIC)
d-shiznit
W.A
icon5.gif  4agte oil return - Anyone used this? (PIC) Fri, 07 October 2005 04:35 Go to next message
Has anyone tried using either of the 2 points circled for their turbo oil return?
http://i3.photobucket.com/albums/y85/4agtetrueno/07-10-05_1052.jpg
I figured that I could find an attachment to screw in rather than having to drill/weld a return into the sump.
Can anyone see any problems with this?
I'm using a highmount turbo manifold btw so height shouldnt be a problem...
4agte
Toronto, Downtown
Re: 4agte oil return - Anyone used this? (PIC) Fri, 07 October 2005 04:48 Go to previous messageGo to next message
The oil return needs to be below the turbo as it uses gravity thats the only problem i can see if your turbo is mounted low
Re: 4agte oil return - Anyone used this? (PIC) Fri, 07 October 2005 04:51 Go to previous messageGo to next message
Also you'd probably find those spots are actually oil galeries, so they will be under pressure from the oil pump..
d-shiznit
W.A
Re: 4agte oil return - Anyone used this? (PIC) Fri, 07 October 2005 05:11 Go to previous messageGo to next message
TurboRA28 wrote on Fri, 07 October 2005 14:51
Yeah thats what I was worried about...
But if thats the case then why hasn't anyone used them for an oil feed rather than T'ing into the oil pressure sender?
Can anyone confirm that these are definately under pressure?
[Updated on: Fri, 07 October 2005 05:15]
kingmick
Banned by his request
moved to tamworth
Re: 4agte oil return - Anyone used this? (PIC) Fri, 07 October 2005 05:18 Go to previous messageGo to next message
neither are any good,the one on the right near the oil filter is water gallery bleed.you will have to weld on on the top of the sump.test fit the manifold and turbo to give you the best place to put the drain in the sump.
mick
mr2gze
Re: 4agte oil return - Anyone used this? (PIC) Fri, 07 October 2005 05:22 Go to previous messageGo to next message
The plug you've circled next to the oil pressure sensor go's into the coolant gallery aswell, to drain it.
edit - too slow Confused , as kingmick said.
[Updated on: Fri, 07 October 2005 05:24]
TE72_Turbo
Re: 4agte oil return - Anyone used this? (PIC) Fri, 07 October 2005 09:05 Go to previous messageGo to next message
And I *think* the plug on the left with the female hex houses the relief spring/valve for the oil pump. Correct me if i'm wrong though Cool
adavy84
Perth, WA
Re: 4agte oil return - Anyone used this? (PIC) Fri, 07 October 2005 12:45 Go to previous message
Hey Jeremy just do what i did (and most others) T it off from the oil pressure sender. And yes the one on the right is for water. And make a hole in the sump for the return... Just make sure the adaptor is welded up good Smile
Previous Topic:gx81 digi dash fuel sender...soarer?
Next Topic:My KE70T
Current Time: Wed Nov 25 22:04:56 UTC 2026
Total time taken to generate the page: 0.0067501068115234 seconds
