Toymods » Tech & Conversions » Lets talk whining gearboxes.
Farkurnell
Liverpool
February 2005
Lets talk whining gearboxes. Sat, 08 October 2005 02:30 Go to next message
Righto blokes,
The gearbox in the RA28 has developed a very noticable whine in recent weeks. So much so it's pissing me off no end. What needs to be done? Rebuild? New gearbox oil? The box is out of a TA23. Anyone got a good one they wanna flog off?
Thanks for the help.
Cheers, Greg.
Dale_ta22
Forster NSW
Re: Lets talk whining gearboxes. Sat, 08 October 2005 03:04 Go to previous messageGo to next message
So it's a t50 box? You have a 3tgte by memory, so if your gearbox is on the way out it might be better to look into a w5x conversion to replace it, rather than a rebuild.
Mine used to whine a bit in 5th... Is yours whining in every gear?
[Updated on: Sat, 08 October 2005 03:04]
Farkurnell
Liverpool
February 2005
Re: Lets talk whining gearboxes. Sat, 08 October 2005 07:32 Go to previous messageGo to next message
Dunno if it's t50 or not. It's one of them old alloy jobs.
Yeah, the things whining in every gear.
Scuse my ignorance but what are the benefits of a w5x conversion and what are they out of?
Cheers, Greg.
Dale_ta22
Forster NSW
Re: Lets talk whining gearboxes. Sat, 08 October 2005 08:03 Go to previous messageGo to next message
Sounds like a t50 then
Benefits would be strength, 3tgte's put out a bit more power than what t50's were designed to be put behind. You won't find yourself needing to rebuild another t50 within 12 months or so if you upgraded to something a bit tougher - which is a common thing for t50's!
They're supra gearboxes generally, but also some cressidas and a few other things depending on which variant. Also in carina/corona's which had 3tgte's in them from the factory!
There's a bit of a list there
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Gearboxes.html
And Simon's site has some info on putting w55's behind a 3tgte to give you an idea what's involved
http://users.chariot.net.au/~stmezz/3tginfo.htm
Depending how you drive a T50 might hold up ok, but it would be well worth pricing up the difference to upgrade vs rebuild
Rallystanza
Re: Lets talk whining gearboxes. Sat, 08 October 2005 08:34 Go to previous messageGo to next message
Has it got a leaking rear main seal and is losing a lot of oil??
Perhaps its low on oil...
If it still shifts fine then one would suggest it may be losing oil, therefore low on oil.
Jezza
Farkurnell
Liverpool
February 2005
Re: Lets talk whining gearboxes. Sat, 08 October 2005 09:45 Go to previous message
Thanks Dale. Good solid advice. Much appreciated.
There has been a few drops of oil on the garage floor but nothing that looked too serious. I'll have to crawl under and suss it out.
Cheers, Greg.
Previous Topic:Alternator noises.
Next Topic:ca18det into ke20
Current Time: Wed Oct 28 00:03:58 UTC 2026
Total time taken to generate the page: 0.0053291320800781 seconds
