Toymods » Tech & Conversions » intake water injection i wanna know more
mx83toy
intake water injection i wanna know more Mon, 06 January 2003 23:09 Go to next message
how does it work /setup ect...
any pis or ilistrtions would be really cool
pulcino
Mackay QLD
Re: intake water injection i wanna know more Tue, 07 January 2003 00:51 Go to previous messageGo to next message
I assume you are askink how mine is set up?
It is very simple and effective. I run a standard 4age running 8 pounds boost so it also runs quit high comp ratio.
The kit consists of a winscreen washer bottle and pump a Hob switch ( it is a boost activated swith ) hose going into the intake.The hob switch connects to an air line that registers boost.It can be adjusted to come on at what ever boost you deem fit ( mine comes on at 4 pounds )This in turn is connected to the washer pump and pumps water into the intake.I have heard of people preasurizing the bottle with another boost line so the pump pressur increases as the boost goes up but I havent needed to try that.
There is heated discussion on wether the water injection should be before the turbo or after ( some say that before will attomize the water alott more some say that it dammages the turbine) I just had my turbo rebuilt ( cos the oil seal went ) and the turbine was fine.
Now the tip that goes into the intake needs to be burnt flat to close the end then pin pricks need to be put along the hose evenly from the bottom to about 5cm up about 12 holes should do it; so when under pressure it will drip water out. Use a grommet to install it in line and thats it. I dont have a digital or a scanner so it is hard for me to send picks but I hope I have explained it for you.
You can run just water or a 50 50 mix of water methanol. You can also mix octane booster in.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: intake water injection i wanna know more Tue, 07 January 2003 02:55 Go to previous messageGo to next message
A couple of weeks ago in tafe we were doing water injection in aircraft, & only real benifit of adding methanol is to stop the water from freezing at high altitudes. While it does provide heat energy when it burns water has a greater & more beneficial cooling effect.
mx83toy
Re: intake water injection i wanna know more Tue, 07 January 2003 03:09 Go to previous messageGo to next message
interesting... im understanding the theory ect...what i'm not picturing is where you insert the hose on the intake...infront of the pletnium???? or can it go any where??? any one have pics of a set up (this is cool i really think i could use this!!!)
BigWorm
Turramurra, Sydney.
Re: intake water injection i wanna know more Tue, 07 January 2003 03:15 Go to previous messageGo to next message
Infront of the throttle body's usually the way to go.
ed_ma61
Lost in the K hole
Re: intake water injection i wanna know more Tue, 07 January 2003 03:57 Go to previous messageGo to next message
joel, methanol also has a lower boiling point, so it has a tendancy to evaporate in the intake faster, thus cooling the intake charge better than just water Smile
ed
Re: intake water injection i wanna know more Tue, 07 January 2003 05:42 Go to previous messageGo to next message
I'm pretty sure water has a higher specific heat capacity than methanol, so wouldn't plain old water be better for cooling? Methanol may evaporate faster, but water will evaporate quick enough once it's compressed inside the combustion chamber! Smile
pulcino
Mackay QLD
Re: intake water injection i wanna know more Tue, 07 January 2003 05:45 Go to previous messageGo to next message
Eva spilt methanol on your skin? Its freezing. Methanol does burn slower and kleener so in doing so wards off detonation.
Best place is anywere before the throttle body but U also want the water to attomize befor it reaches the plenum so you dont just have big globs of water.
BigWorm
Turramurra, Sydney.
Re: intake water injection i wanna know more Tue, 07 January 2003 06:37 Go to previous messageGo to next message
Water absorbs more than twice the heat of Methyl alcahol when it evapourates, which it does at only moderately higher temps.
According to my tafe scribblings water water absorbs 970 BTU/lb at 212deg F, while methyl alc. does only 418 BTU/lb at 148deg F.
Methyl alc also provides 9000 btu/lb of heat when burned, while water produces none.
M.W.P.
Rocky Mountains, Canada
Re: intake water injection i wanna know more Tue, 07 January 2003 09:17 Go to previous message
There has been lots of talk about this latley on the MegaSquirt mailing list.
One thing everyone has agreed on is that the water must be properly atomized. Dripping water in wont do squat.
Use a high pressure pump, and a propper atomizing head.
BTW... you can also spray water into the exst manifold before the turbo, it makes the turbo spool quicker.
Previous Topic:1g gte?
Next Topic:microtech mt-4 3D mod
Current Time: Sat Nov 21 01:08:38 UTC 2026
Total time taken to generate the page: 0.00484299659729 seconds
