Toymods » Tech & Conversions » E58 now installed into AW11 but a problem remains!
nick.parker
January 2005
E58 now installed into AW11 but a problem remains! Sun, 09 October 2005 01:07 Go to next message
Howdy,
Well I finally got my E58 LSD intalled into the MR2. A machine shop bored the hole in the 'front' side of the box and a rubber lip seal was pressed in and it looks absolutely factory! Then I simply took the E51 shifter and bolted it in, and bolted on the the external E51 shifter parts...truly bolt up! I could feel the shifter moves more freely straighy away compared to the E51.
The short passenger side drive shaft was a perfect fit, all that was required was a 22mm hub nut since the threaded portion of the E58 stub axle is 22mm instead of 19mm like the SC MR2. Splines are identical.
The longer driver side axle however is a problem!
It is too long by about atleast 40mm or something. For the meantime I found the E51 shaft can do the job, but its gearbox end is designed to have a c-clip, unlike the E58, so the axle doesn't go in far enough by about 2-3mm I'd say. It in there for now, and the oil seal is fine, but it's not ideal.
Is there someone out there who has solved this little issue with another toyota part? Does Anyone know if any SW20 drive shafts can be used?
Cheers, Nick
4agte
Toronto, Downtown
Re: E58 now installed into AW11 but a problem remains! Sun, 09 October 2005 11:31 Go to previous messageGo to next message
all the e58 into aw11's ive seen use custom billet driveshafts
nick.parker
January 2005
Re: E58 now installed into AW11 but a problem remains! Sun, 09 October 2005 11:48 Go to previous messageGo to next message
Custom billet sounds expensive.
The passenger side shaft was a perfect drop in apart form buying a 22mm hub nut.
I have heard on the US list that you can use a MK2 turbo shaft, I have yet to investigate this.
Can you put ne in touch with the AW11 people who have the billet shafts?
Cheers, Nick
[Updated on: Sun, 09 October 2005 11:51]
4agte
Toronto, Downtown
Re: E58 now installed into AW11 but a problem remains! Sun, 09 October 2005 12:03 Go to previous messageGo to next message
yup i belive gunmetal grey 87 uses billet shafts but he didnt put them in some1 else did however i think from memory some1 else that put custom shafts into his ae82 with a 6speed celica gearbox it cost him arround the $800 mark
nick.parker
January 2005
E58 passenger side axle on AW11 picture Tue, 11 October 2005 02:21 Go to previous messageGo to next message
This is the axle I am having trouble with. If the straight section was only approx. 40mm shorter it would be PERFECT! Does anyone know another toyota axle that would be like this?
Regards, Nick
http://www.e-wire.net.au/~nrparker/ToyModsPics/passenger%20axle.JPG
Lachie
Re: E58 passenger side axle on AW11 picture Tue, 11 October 2005 04:52 Go to previous messageGo to next message
Couldn't you just take the shaft to a decent engineering shop and have them shorten it?
People do it axles in rear wheel drive, front engine cars when they cut down diffs, shouldn't be any different Confused
toof
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 05:17 Go to previous messageGo to next message
that driveshaft is form the fwd corolla or the likes ? i like the equal length shaft setup. that bearing between the innet CV and the gearbox slines mount onto the... engine ? or crossmember.. cent remmeber with and is helf in with a large circlip. are you actually musing that mount top use the equal length shafts ? iirc the sw20 does something like this too.
the shaft off the e51 i couldnt imsgaine would hold in too well ? jsut given the e51 uses the clips on the shaft where the e58 shafts will be held in with the large clip near the innet cv.
i would have suggested perhaps getting the inner splines trimmed back so they were that little bit shorter and fitted nicely. however im not sure if that would be suitable given you need 40mm shorter and also i would be worried about how well it would hold in place ?
i really dont like the idea of cut and shut on the shafts. just feels like asking for trouble. what about gettnig a custom shaft made for the section between the two CV's ?
the guys ive know that have had to get custom shafts done up have all looked at around the $1000 mark for both shafts so i couldnt imagine you wuold be up for too much for just that small section.
4agte
Toronto, Downtown
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 05:25 Go to previous messageGo to next message
$1000 sounds pretty good for custom shaft it would essentially be new shafts considering toyota are "supposed" to charge $1300 for theirs sounds like a good deal to me
toof
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 05:34 Go to previous messageGo to next message
quite honestly there isnt really that much too them. take two appropriate sized piece of steel. machine splines at each end. attach off the shelf purchased cv joint on.
dont get my wrong in not suggesting i can home brew them up but there really isnt *that* much too them.
i know they are insanley strong steel, and very precise in their manufacture but still they are hardly anything *that* odd to produce.
a mate of mine got a set done up for around $1000 although he was in the trade, but i couldnt imagine you would pay too much more then that for them to be made up..
$1300!! *sigh* dont you love the cost of genuine parts. somethings are so well priced. where others are just so horribly priced... 4agze piston < handbrake cable Sad
4agte
Toronto, Downtown
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 05:39 Go to previous messageGo to next message
clutch slave cylinder bleed pipe
4age: $25
4agze:$125 and 3 weeks wait
Confused
ended up bending a spare n/a one i had
they are made exactly the same except the s/c one is a different shape
Lachie
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 06:04 Go to previous messageGo to next message
AE92 centre console $45 from the wreckers, $18 from toyota
RA23 brake master cylinder somewhere round $750 - $900 or some ridiculous price, $200 for ABS stainless reselvee
I can't understand toyotas pricing on parts, it seems they just pull a number out of a hat sometimes!
Sorry for the thread hijack Rolling Eyes
toof
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 06:28 Go to previous messageGo to next message
yeah some bits are so well priced and then you just come across something that is so stupidly priced.
the alternator in mt st184 died.. toyota $900 and 8 weeks out of japan. aftermarket $300. wreckers $80
nick.parker
January 2005
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 06:30 Go to previous messageGo to next message
Yes that shaft is from a front wheel drive Corolla. That bracket bolts onto the block, and shares a bolt with the SC bottom bracket. Although I made a custom bracket (for SC14) I was a clever lad, and designed it to still be compatible with this equal length system...then I got shot down in flames when I went to fit it all and discovered it was too long, even thought the shaft installs perfectly and the brackets mount up nicely etc....grrrr
Does anyone know if there is a shorter version of this shaft? are AE92 and AE101 a different track width? These both had E58 gearboxes I think.
Cheers, Nick.
toof
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 06:36 Go to previous messageGo to next message
my mate has a ae92 gtz with a e52 gearbox... and conveniently his drive shafts are out atm Razz ill be giving him a hand to put everything back together tomorrow so ill measure them up whilst im at it.
nick.parker
January 2005
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 10:42 Go to previous messageGo to next message
The distance from the 'gearbox spline end' to the 'first CV' is what I'd like to know. Then I can easily compare with my shaft.
Thanks, Nick
toof
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 10:57 Go to previous messageGo to next message
no probs, two of the cv boots had blown out and were a hint lacking in grease so he figured it was time for some fresh cv's. so we should get them abck tomorrow and install toorrow night so ill make sure to measure them up then.
Ben Wilson
Re: E58 now installed into AW11 but a problem remains! Tue, 11 October 2005 22:29 Go to previous messageGo to next message
Have a look on www.twobrutal.co.uk they have a bunch of driveshaft info there..
nick.parker
January 2005
Re: E58 now installed into AW11 but a problem remains! Wed, 12 October 2005 03:53 Go to previous messageGo to next message
I think I am getting closer to the answer. Apparently one guy I found in the USA used an E153 (late model turbo SW20 MR2) shaft and bolted up the rest of the E51 drive shafts. V6 shafts look similar. See pics.
On that note is anyone here in Perth and have as SW20 shaft lying around? Wink
http://www.e-wire.net.au/~nrparker/ToyModsPics/suppshafts.jpg
dingaling
tas
Re: E58 now installed into AW11 but a problem remains! Wed, 12 October 2005 05:14 Go to previous messageGo to next message
Hmm i am not sure, but i will mention it anyway just incase it helps.
My memory sux.
But anywayb when i installed a beams 3sge into an aw11, we used an LSD sw20 5 speed gearbox. (dam my memory sux)
But we had no drama's installing it, we used the driveshafts from a sw20 turbo, pressed the hubs out of the piddly aw11 hubs, and had the sw20 turbo hubs pressed in place with new bearings.
The driveshafts fited in perfect and lined up perfect. Shit i wish i could remember which gearbox this was. I know it was an sw20 LSD 5 speed box. The driveshafts were meaty bastards compared to the aw11 4age ones. I have pics somewhere of the driveshafts and gearbox.
[Updated on: Wed, 12 October 2005 05:15]
dingaling
tas
Re: E58 now installed into AW11 but a problem remains! Wed, 12 October 2005 05:20 Go to previous messageGo to next message
Sorry E58 is a 4A box. Dam that's what i get for forgetting my lunch today. (no energy to think straight) lol
4agte
Toronto, Downtown
Re: E58 now installed into AW11 but a problem remains! Wed, 12 October 2005 05:32 Go to previous messageGo to next message
it would be an e51 gearbox for the sw20 i would imagine
dingaling
tas
Re: E58 now installed into AW11 but a problem remains! Wed, 12 October 2005 05:43 Go to previous message
yeah that sounds familiar.
The picture of that driveshaft up further looked exactly the same as the E51 driveshaft.
Previous Topic:Where does the vacumn hose off the advance/retard acutator go - 3tgte
Next Topic:Gen 2 3S-GE Questions
Current Time: Mon Oct 26 07:07:18 UTC 2026
Total time taken to generate the page: 0.0073890686035156 seconds
