Toymods » Tech & Conversions » replacing valve seals
chadix24_7
cebu city, philippines
replacing valve seals Sun, 09 October 2005 03:34 Go to next message
i have a 4age bigport head and i was just wondering if it is possible to replace the valve seals without removing the cylinder head?
how?
thanks and more hp.
Smile
tricky
July 2005
Re: replacing valve seals Sun, 09 October 2005 03:50 Go to previous messageGo to next message
yes, it's possible, but from all accounts it sucks. Do a quick search. This was discussed about a month ago. Basically, it'll be quicker, easier and safer to do it with the head off.
Maurice c
Re: replacing valve seals Sun, 09 October 2005 13:46 Go to previous messageGo to next message
Theres a valve that you can fit in place of the spark plug that allows you to keep pressure on the valves with an air line, they aren't too expensive but I don't know how good they are.
dingaling
tas
Re: replacing valve seals Mon, 10 October 2005 02:50 Go to previous messageGo to next message
Yeah on my compression tester i took the adaptor off it (spark plug thread on one end) and adapted it to an air compressor.
This trick does work, but there are times when you have a hard time building enough pressure to hold the valve up with enuf force to press the springs down. You have to add oil down the plug whole sometimes and rotate the valves around to get that sealing happening again. Very frustrating i tell you. But not impossible.
wilbo666
Re: replacing valve seals Mon, 10 October 2005 03:09 Go to previous messageGo to next message
http://www.mkiv.com/techarticles/valve_stem/
This looks like a decent write up to me.
Maurice c
Re: replacing valve seals Mon, 10 October 2005 12:35 Go to previous message
A wise man once said to me.
"When you open a 25 year old engine and finish with any less then a complete rebuild then your doing well. I when to do a set of valve seals on my old 18 r and ended up after chucking in about 500 bucks worth of parts. I was pissed, people cant give these engines away but I needed the car for a daily driver.
Previous Topic:fuel pump for 4agze in ae92
Next Topic:coilovers celica sa63
Current Time: Tue Nov 24 10:50:44 UTC 2026
Total time taken to generate the page: 0.004925012588501 seconds
