Toymods » Tech & Conversions » URGENT, help with circuit open relay output voltage...
Phrostbyte
Frankston, Victoria
URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 06:14 Go to next message
Hey peeps,
Firstly I want to say thanks to all the peeps from these forums that helped me out, couldn't have done the conversion without yas.
I'm up to the absolute final stage of my conversion, just about to mount the fuel pump. After screwing up the wiring of my circuit open relay about 4 times, I finally looked deep at the wiring diagram and the plug pinout diagram and did it properly. With my multimeter in hand i turned the starter to check the output voltage... EXACTLY ONE VOLT?? Made me go "wtf?". Is this normal? Like is it meant to be only 1 volt while starting, then once the starter goes off and the engine raises above 5RPM and the ECU kicks it into action off the 12V EFI, it raises to 12V?
It's the last thing I need to figure out till i fill the tank and start the car, so I really want a fast reply on this.
Thanks heaps!
Kev.
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 06:29 Go to previous messageGo to next message
what happens when you crank it over? and it is getting pulses?
the volvo ones have 12V... since it is basically a normal relay.. but also has a timed trigger for the crank pulses..
sure it's not fubar? got another one to try?
Phrostbyte
Frankston, Victoria
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 06:41 Go to previous messageGo to next message
Lol the car aint running yet, i need a fuel pump that runs before i can crank the engine over Razz.
But yeah as mentioned above, one of the triggers for the open circuit is the starter motor, but only EXACTLY 1v is getting through when i crank the starter. I'm not talking 1.02 or something, im talking 1.00000Volts... Kinda makes it seem like its meant to do that?
Kev.
wilbo666
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 07:38 Go to previous messageGo to next message
The starter signal should cause 12v to goto the fuel pump (not 1V), as should the AFM flap opening.
COR's are pretty simple, it is just a relay that triggers off the starter signal and the AFM...
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 08:46 Go to previous messageGo to next message
Wilbo,
if he is using a MAP sensored engine that info doesnt apply Razz
On MAP sensor Toyota engines, the COR is triggered by the "FC" pinout of the ECU. This FC output is an open collector, meaning than when triggering, it connects to GROUND.
Of the 5 wires, in most common systems:
# B-R => 12V ign power from EFI main relay
# B (or B-W on some) => Starter motor switch from keybarrel
# L-B (the blue wire Razz) => fuel pump power output
# G-R => FC pin trigger from ECU
# W-B => earth
So how does it work?
The toyota system does not run/prime the fuel pump prior to cranking the engine. It runs the pump whilst the engine is cranking, and then the ECU controls the fuel pump. It is a simple 12V on/off control.
Having the starter trigger to the COR is there to aid the fuel rail pressue and engine starting up whilst the engine is cranking.
You can cheat this by momentarily cranking the starter (short enough not to start the engine) and the pump will run for a couple of seconds before shutting off.
shinybluesteel
melbourne
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 13:13 Go to previous messageGo to next message
frosty, you don't need a circuit opening relay, and if you want one you can make one yourself out of two relays, as conceptually it is easier to understand and the opening relays can be unreliable.
My car and my mate's car trigger the fuel pump off the "engine running" signal, works very well in practice!
Phrostbyte
Frankston, Victoria
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 13:33 Go to previous messageGo to next message
Thanks heaps boys. Seems after looking at teh Witzl's post, I did have it wired up properly... Seems I'm looking for another open circuit relay, my one must be busted... For the moment I've done a hardwired relay triggered by the ignition switch, as unsafe as that is, it will only be temporary (ie. 1 or 2 weeks)...
Kev.
shinybluesteel
melbourne
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 13:36 Go to previous messageGo to next message
did you read my post? you dont need one Razz
you can have the relay triggered by what its supposed to be triggered by, the opening relay isn't some magic thing, its jus ta pain in the asS!
Phrostbyte
Frankston, Victoria
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 13:43 Go to previous messageGo to next message
Lol, thats basically the same thing but with 2 relays instead of one f00 Razz.
By "Engine running" signal you mean the FC connector in the ECU correct?
Kev.
shinybluesteel
melbourne
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 13:56 Go to previous messageGo to next message
should have been more clear, what i meant to say is that my car and my mates car only use one relay, its triggered by the output that goes to the opening relay that ISNT the start signal.
cant remember what its called
you only need to use one relay! totally fine!
Phrostbyte
Frankston, Victoria
Re: URGENT, help with circuit open relay output voltage... Sun, 09 October 2005 14:18 Go to previous message
Hmm.. If you can find out exactly where I'm meant to get the trigger on, that sounds great Smile.
Kev.
Previous Topic:ra42 front sway bar
Next Topic:Sprinter interior light cover
Current Time: Sat Jun 20 21:55:36 UTC 2026
Total time taken to generate the page: 0.0063920021057129 seconds
