Toymods » Tech & Conversions » 20v vvti actuator
Steve-AE86
Ademelaide, SA
20v vvti actuator Tue, 11 October 2005 02:00 Go to next message
is it necessary to run vvti with aftermarket ecu and a t28 turbo on a blacktop 20v?
the reason i ask is, my new engine has a broken vvti actuator.
would it be beneficial at all to blank off the hole in the side of the head, or maybe even set the actuator so the vvti is on all the time?
Re: 20v vvti actuator Tue, 11 October 2005 02:03 Go to previous messageGo to next message
It's not necessary to run it. On most engines, it's beneficial if it's working, especially if you have control of the change over point.
Oh, and it's only vvt Smile
Re: 20v vvti actuator Tue, 11 October 2005 02:07 Go to previous messageGo to next message
Only MoTeC and Autronic can control VVTi, so unless you have one of them (thats if it is VVTi not VVT, I'm not sure about blacktops), then don't worry.
[Updated on: Tue, 11 October 2005 02:18]
terra
July 2005
Re: 20v vvti actuator Tue, 11 October 2005 02:54 Go to previous messageGo to next message
loose a bit of torque, but then again you got a turbo Smile
Raceflow
August 2005
Re: 20v vvti actuator Tue, 11 October 2005 07:23 Go to previous messageGo to next message
it's an electronic controlled solenoid, as far as i'm aware, so even microleb's can switch it on and off...
what i want to know is, can i have it on permanently, and will it affect the way it runs?
Steve-AE86
Ademelaide, SA
Re: 20v vvti actuator Tue, 11 October 2005 09:33 Go to previous messageGo to next message
sorry Jon Laughing
Jonny2TG
Tasmania
Re: 20v vvti actuator Tue, 11 October 2005 11:18 Go to previous messageGo to next message
I can hardly believe people are still wreseling with the basics of this.
As far as I know, the actuator in the silvertop and blacktop are the same. On the Silvertop is it called VVT, and the cumputer only uses one thing (to decide) to switch the solenoid on or off. I think on the Blacktop its called VVTi, because the computer uses more than one thing to decide when to switch it.
Wether your aftermarket computer controlled system is VVT or VVTi depends on how inteligent you think you have made it, and its up to you to decide. What sticker would you rather?
Wether its working or not, valve timing is still important. Use a degree wheel and dial gauge and sus it out!!!!
As for turbo, I can't think of any factory turbo system that uses VVT of any type. (My knowledge is limited to popular Toyota models). Maybe late model 2JZ-GTE uses VVTi? I'm not sure. Either way its not really needed. But if its fixed, be sure to know what the valve timing is!!!
Also beware. If the VVT controler is not connected or not working, the intake sprocket will not be locked to the cam when the engine is off and can still turn either way, so be aware of this if you are dialing in the cams with the VVT system still in there. For a serious motor not using VVT, you would get a new sprocket or cam or whatever and make sure the sprocket is properly locked to the cam.
But thats just my opinion, dont take as fact...
deesonet
Toowoomba
Re: 20v vvti actuator Tue, 11 October 2005 12:06 Go to previous messageGo to next message
Jonny is almost correct. If you don't have the VVT / VVTi actuator working how will you maintain oil pressure to keep the cam sprocket fully advanced or retarded to the position where you have set the cams up. You would be better to replacae the sprocket with a standard one except that they don't fit onto a VVTi camshaft.
Both the 1JZGTE and 2JZGTE (both turbo'd) have VVTi versions - only on the inlet camshaft. I have a '98 model 1JZGTE VVTi in my Lexus IS200. When you dismantle the VVTi cam gear it is activated by maintaining oil pressure on both sides of the piston.
The control of the actuator is a PWM (pulse width modulated)signal - not an on / off signal hence most computers can't control it. Motec and Autronic are the most likely units to control it.
You can run without the VVTi with little difference in overall power - you just looose a lot of the VVTi advantage of much better torque at lower revs. It will feel different to drive.
sideshow
Re: 20v vvti actuator Tue, 11 October 2005 12:24 Go to previous messageGo to next message
since when is a blacktop a vvti
i thought all 20vs whether black or silver were just vvt
cam timing is either retarded or advanced by one solenoid
i didnt think the blacktop ecu was that clever
i might be wrong but im pretty sure they just turn vvt on after about 3500 or 4000 rpm
and u dont get oil pressure probs if theyre not hooked up
the cam gear just stays retarded
when u get the oil pressure in the cam sproket section it advances the timing of the gear
i have seen once where on an ems it didnt make much diference on the dyno whether is was on or off
like someone said best just get an adjustable cam gear for it
another thing is its a big pain to tune vvti since u have to take into affect oil pressure change
[Updated on: Tue, 11 October 2005 12:25]
Bill Sherwood
Brisbane / Gold Coast
Re: 20v vvti actuator Tue, 11 October 2005 13:02 Go to previous messageGo to next message
Guys.
20v's of any colour top have plain old VVT.
The cam is advanced with oil pressure that the VVT solenoid lets in, and retards when the VVT solenoid turns off.
That's as complex as it gets.
myne
October 2005
Re: 20v vvti actuator Tue, 11 October 2005 13:25 Go to previous messageGo to next message
You could dodge something that'd do the job with a tacho that supports a shift light. Rig the shift light to a relay and then to the solenoid.
There's possibly a moderately simple way to emulate the i part of vvti.
Find some form of vacume operated switch, rig it to switch at about 8" of vacuume (same as the gze supercharger is) and put it in sequence so that it has to be above 8" of vacuum AND above 5500 rpm.
Ofcourse, a properly tuned computer with an auxilery switch would be the best idea.
Jonny2TG
Tasmania
Re: 20v vvti actuator Tue, 11 October 2005 13:27 Go to previous messageGo to next message
... same with the new Camry and Corolla (1AZ-FE, 1ZZ-FE).
Re: 20v vvti actuator Tue, 11 October 2005 23:52 Go to previous message
Jonny2TG wrote on Tue, 11 October 2005 21:27
They both use vvti, not plain vvt. As deesonet described, vvti isn't just simple on/off, it uses a PWM controlled solenoid to advanced and retard the timing between two points.
Previous Topic:Help identify my struts + possible brake upgrades! Pics (Warning 56kers!)
Next Topic:whats the best way to go with a turbo engine for my car
Current Time: Fri Nov 20 21:53:09 UTC 2026
Total time taken to generate the page: 0.049057960510254 seconds
