Toymods » Members Rides » Matt's ST162 - 3rd Gen 3SGE Engine swap
matt86sx
Gold Coast, QLD
Matt's ST162 - 3rd Gen 3SGE Engine swap Thu, 13 October 2005 05:42 Go to next message
Hey guys,
Been planning this for ages and now it's finally underway. Bought this engine about six months ago and have been waiting to have the time and money (mortgages suck!) to install it ever since! But now that work is quiet and I can take some time off, I have seized my chance. The downtime here at work also means that our workshop is quiet so I am able to use a corner of it to work on the car rather then my pitiful townhouse garage at home.
Nezz (3SGTE Man on these forums) came around last Wednesday to give me a hand with getting the engine out, the forklift here at work came in very handy! So here's a summary of week one:
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0002.jpg
Old donk ready to be lifted out, sling in place ready for the forklift.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0006.jpg
Forklft doing its thing. Only learnt to drive it a few days earlier (!!) but it's pretty easy.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0008.jpg
The old and the new........
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0012.jpg
Hmm, it definitely had an oil leak problem!
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0013.jpg
New one is gleaming in comparison!
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0017.jpg
My now engineless car, in it's temporary home for the next couple of weeks.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0018.jpg
LOTS of degreaser needed here.....
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0019.jpg
Particularly right behind where the oil leak was happening!
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0020.jpg
A few days (and lots of degreaser and rags) later - much nicer!
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/DCP_0022.jpg
Rebuilt brake and clutch master cylinders back in place. I figured that replacing the seals in these would be cheap insurance while the engine is out and they are so much more accessible. The clutch one had about half an inch of what looked like mud in the bottom of it, didn't see it until it was drained of course.
While the engine is out, I'm also replacing the steering rack (old one was very worn, have an exchange one now waiting to go in), ball joints, tie rod ends, wheel bearings plus I will be rebuilding the brake calipers as well. In addition to that I will be painting some body and trim pieces, as well as the brake calipers. So it will be a very different car when it's all done!
More pics to come as it happens. Hope you enjoy the progress!
Matt
[Updated on: Thu, 13 October 2005 05:43]
smashed_wombat
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Thu, 13 October 2005 09:01 Go to previous messageGo to next message
Nice work man! Looks like the project is coming along smoothly! Good idea to do the new rack and suspension bits while everything is apart too - wish I had the same foresight! Very Happy
About the questions you asked in the ST162 thread;
- Yes, using the original radiator hoses will be ok but you'll need to cut 40 ~ 50mm off the top end end of the bottom hose to make it fit.
- Yeah, i just used the original thermoswitch. Seeing as I didn't use the original A/C wiring I pinched the wires for the A/C pressure sensor for the switch wiring - saves pulling the loom apart to run extra wires.
I got the housing done by a workshop. They cut the threaded bit that sticks out of the original housing off, welded it to the new housing then drilled out the centre hole so that the coolant could get up to the switch. If you look at the pictures of mine, a fraction lower and toward the dipstick would've been the perfect position. My one is ok spot... just a little too close to the alternator for my liking.
Good luck! Very Happy
[Updated on: Thu, 13 October 2005 09:07]
warrior
Sydney / NSW
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Thu, 13 October 2005 09:06 Go to previous messageGo to next message
what an awesome working environment, look at all that space Shocked . should be a great conversion matt. all the best with it. Wink
Karl
smashed_wombat
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Thu, 13 October 2005 09:13 Go to previous messageGo to next message
Just looking at your pics again (reminiscing Razz) and noticed the top mount on the new gearbox. Is that the original from the ST202? If so, do you reckon it'll be a straight fit into the ST162? Got the gears turning in my head again... Very Happy
matt86sx
Gold Coast, QLD
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Mon, 17 October 2005 07:08 Go to previous messageGo to next message
Hey Andy, yes the mount that is on the new gearbox is the original one from the ST202. I haven't really had a close look at it yet, but it LOOKS like the mount is in the same position as the old one and should mate up - but I'll be sure to check it closer first. (Conversely, the drivers side ST202 mount is completely different so I'll have to use the old one. No problem though, it was only my front/rear mounts that were broken, the side ones are OK.)
I'll get back to you with a definite answer mate.
matt86sx
Gold Coast, QLD
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Tue, 25 October 2005 03:26 Go to previous messageGo to next message
Time for an update - engine is in!!
Neil came around again on Saturday and the engine went in without any real dramas. Only thing that held us up was that we realised that the exhaust secondaries were never going to fit (Andy has told me that it fouls on the 162 crossmember anyway) so out came the angle grinder to cut it after the flex pipe.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap049.jpg
Engine bay with new steering rack, fuel filter, throttle cable etc in place ready to accept the new engine.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap053.jpg
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap054.jpg
Trusty forklift in use once again.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap057.jpg
Neil getting the gearbox mount sorted out.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap058.jpg
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap059.jpg
Front and rear brakes rebuilt and painted. Decided on gloss black, figured red ones would look a bit tacky on a white car. And white ones wouldn't stay white for very long! The front discs are replacements I got from a wrecker (for $25 each) that had already been machined and had more material left on them than my old ones. Both the front and rears will look a lot better once they have been scuffed by the pads! One day I'll get some DBA slotted rotors though, when the budget allows.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap060.jpg
New engine nestling in the bay - not a bad half day's work! Everything lined up and went together really well.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap061.jpg
Another view. Here you can see the front mount fan fitted which came from an ST Celica. I also grabbed the aircon pipes to suit from the same car.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap062.jpg
Pic showing just why the front mount fan is necessary! With those sexy Gen 3 factory extractors in place there's no room for the old fan anymore. Also note the freshly painted radiator - took it to a radiator place for a flush and found out it was about 25% blocked. So it should run a lot cooler now. Also down in the bottom left (right above the brake booster) is my new power steering high pressure hose.
All that's really left for me to do now is get some new F/R engine mounts (didn't realise till too late that the ST202 ones were no good to me) and radiator hoses. Once all that's together it's wiring, exhaust and a wheel alignment and that should be it! Decided on getting a pro to do the wiring (otherwise I'd be in WAY over my head), just have to wait for one to become available. At this stage the earliest I'll be able to get someone will be this weekend, if not early next week. Sad
Oh well, I'm getting fit by riding my mountain bike to and from work at the moment! Big thanks once again to Nezza for his invaluable assistance.
Laters,
Matt
matt86sx
Gold Coast, QLD
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Mon, 31 October 2005 08:48 Go to previous messageGo to next message
Engine is wired up and running!!
I had an engine wiring pro come around today and he got the whole thing done in about 5 hours. (If anyone ever wants his details, let me know!) His timing couldn't have been more perfect - now I have the rest of the week to finish it off. Probably get the exhaust done on Wednesday, and wheel align on Thurs.
There's a truckload of things to finish off and put back together, but it's looking good to have it done by the end of the week. Man, I thought I was excited when the engine was dropped in last weekend - but when you hear it start up for the first time it's even better!
Matt
matt86sx
Gold Coast, QLD
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Fri, 11 November 2005 04:18 Go to previous messageGo to next message
My baby is back on the road and pretty much all done! It's certainly a different car these days - goes better, steers better, stops better....as you can imagine I am very happy with it! All went to plan last week, had the exhaust done on Wednesday and a wheel alignment on Thursday. I then spent Thursday and Friday nights getting everything put back together (particularly the interior) in readiness for an Ozcelica cruise on Saturday.
Had the exhaust done at Southport Exhaust (right around the corner from my work), and they fitted a 2.25" system with high flow cat, resonator and straight through muffler. I found this to be WAY too loud (couldn't hear myself think at idle, let alone under any kind of load during acceleration), plus it didn't feel like it had much low down torque either, certainly not much below 3000rpm. So yesterday they swapped the muffler to a more baffled one (although still less restrictive than standard) and I am MUCH happier with it. It's a lot quieter now, but still has a nice sound when you nail it. And the low rpm torque has actually improved a bit too. The guys at Southport Exhaust had no problems changing it for me at no charge, to make sure I left a happy customer - highly recommended.
Anyway here's a shot of the engine with all the bits and pieces fitted:
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap066.jpg
All looks nice and stock, I was really rapt with how the airbox fits very neatly into the corner in front of the strut tower - looks like it came from the factory that way! The airbox conceals a nice K&N panel filter that arrived last week. And yes that IS an occy strap around the battery.......the airbox is so much bigger than the original that the battery JUST squeezes into the space between the airbox and fuse box, such that I cannot fit battery clamp rods down the gaps because the gaps just aren't there (see below). I've also had to face the battery post clamps out to the sides for clearance.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap065.jpg
The battery is such a tight fit that it wasn't going to slide anywhere easily, I just put the strap around it to make sure it's somewhat secure. It's only a temporary fix, I'll have to figure out exactly what I'm going to do but I'm leaning towards a physically smaller battery - I'll have to see what Odyssey/Optima/etc have in their ranges. I guess if all else fails I could relocate it to the boot.
I still have a few little things left to do, the main one being the intake setup. At the moment the airbox is just drawing air from the engine bay (you can see in the pic above that there is no pipe coming out of it), but I will be addressing that this weekend. I'll post an update of it when it's done. The N-S crossmember is also interfering with the gearbox, resulting in a slight vibration. Andy had the same problem with his, so I'll be getting that sorted out too. And the aircon isn't hooked up yet, the Gen 1 hose fittings don't match the Gen 3 compressor so I'll get some adaptors made up when I have the system converted and gassed.
More updates as things get done.
Matt
[Updated on: Fri, 11 November 2005 06:38]
da_horse
Melbourne Australia
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Fri, 11 November 2005 17:57 Go to previous messageGo to next message
Looking great!!! Wink
i love how it all looks so stock. Very Happy
matt86sx
Gold Coast, QLD
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Mon, 21 November 2005 06:26 Go to previous messageGo to next message
Got a few more pics, first I thought I'd show how I fitted some of the engine ancillaries for anyone who may attempt this in the future.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap104.jpg
The 3rd gen comes with a different type of oil pressure sender which is not compatible with the 162, simplest thing to do is mount the original one to the new engine. The old sensor will foul on the head, so it needs to be mounted further out to clear it. I bought this pair of brass fittings for a grand total of $1.35, works a treat.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap068.jpg
I used the ST202 charcoal cannister VSV (with the blue plug), in conjunction with the original ST162 cannister. I just fashioned up a little bracket (the silver one you can see, it's made from galvanised angle section that I get from Bunnings) and attached it to the strut tower. The two lines that lead to it (in the foreground on the left) are from the intake, right where the throttle butterfly is located - see earlier pics.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap073.jpg
MAP sensor. Found this was the easiest place to mount it so that both connections could be made easily.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap078.jpg
Coil & Igniter. I turned the coil around 180 degrees on the bracket (needed to grind the bracket a bit) so that all four electrical connections are at the same end - I found that made it easier to connect everything to the loom.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap079.jpg
Looking at the coil/igniter from the other direction. Just bolted the bracket at one end to the mount on the strut brace. Not the neatest solution, but gets the job done.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap077.jpg
A/C VSV mounted to the firewall.
To be continuued..........
matt86sx
Gold Coast, QLD
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Mon, 21 November 2005 06:29 Go to previous messageGo to next message
I have also been doing a little bit of work on the intake as well, here's what I have been up to so far:
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap081.jpg
Here is the hole in the guard for the intake pipe to come through to the airbox.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap083.jpg
Here is the airbox removed with the matching pipe that I grabbed from the half cut. The pipe was cut just prior to where it branches off to fit the induction resonator. The main reasons that I wanted this pipe was simply to travel through the hole in the guard shown above - after that I would fit a flexible hose to take it down behind the front air dam. Plus of course it perfectly fits the hole into the airbox itself.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap084.jpg
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap085.jpg
80mm flexible intake hose from Autobarn (about $25). Exactly what I had in mind!
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap088.jpg
Here's the general idea - duct it out the engine bay with the ST202 pipe section, and attach the 80mm tube to lead down to the air dam. As luck would have it, the flexible tube fits nicely over the end of the ST202 pipe - they have virtually the same cross sectional area which is a bonus!
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap091.jpg
It was a tight fit, but the ST202 pipe fitted through the original hole fine.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap096.jpg
K&N panel filter in the airbox and ready to go.
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap100.jpg
Fitting the airbox back in place, it was a relief that the pipe lined up with the airbox hole!
http://img.photobucket.com/albums/v636/macca_1972/Engine%20Swap/EngineSwap103.jpg
ST202 pipe sitting in the guard and ready to be ducted down to the air dam. Next project is to make some sort of fibreglass duct with mesh in front of it to sit behind the lower front spoiler.
Stay tuned.........
Matt
da_horse
Melbourne Australia
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Tue, 22 November 2005 00:57 Go to previous messageGo to next message
looking good mate! Smile
have you driven the car yet or is it still yet to be finished? keep up the good work mate.
btw, got the rims already, but thanks anyway Wink
matt86sx
Gold Coast, QLD
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Tue, 22 November 2005 03:10 Go to previous messageGo to next message
Yes the car has been on the road for about three weeks now, I get a very wide grin on my face every time I step into it.... Cool
I'm a little confused about the rims......was I offering some for sale to you at some stage or something?? Sure you haven't mixed me up with someone else? lol
Matt
alliance_22
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Mon, 05 December 2005 21:58 Go to previous messageGo to next message
Hey matt!! that is one nice conversion there mate!
did you have any problems with low RPM Vibration from the engine?
matt86sx
Gold Coast, QLD
Re: Matt's ST162 - 3rd Gen 3SGE Engine swap Wed, 07 December 2005 06:44 Go to previous message
Hey Chopin,
Thanks for the compliment there mate, it's nice that so many people are appreciating it. (By contrast, I see you have bought yourself a conversion! lol)
I don't have any vibration problems as such, have you heard that this could be a common thing with these engines? Only vibration issue I have had was with a little gusset under the gearbox (that was not present on the original box) that fouled on the 162 N-S crossmember. Since I ground it away there have been no problems at all.
Matt
Previous Topic:My cars!!!
Next Topic:now 1JZ turbo AE71 panelvan -- updated 29/11 (no 56k)
Current Time: Wed Nov 18 21:38:23 UTC 2026
Total time taken to generate the page: 0.0082859992980957 seconds
