Toymods » Tech & Conversions » 3k-b twin carbys
dave_ke30
sydney, the shire
3k-b twin carbys Thu, 13 October 2005 07:34 Go to next message
hey ive got a warm 4k with twin 3k-b carbys that could use bit of a tune for better performance, atm carby 1 is sucking alot more air in than carby 2 but both squirting petrol in.. is there a way to evenly balance the carbys or any other method to get the best out of these carbys? cheers. dave.
Re: 3k-b twin carbys Thu, 13 October 2005 08:29 Go to previous messageGo to next message
at idle, adjust the throttle butterly/linkages, to balance the vacuum between the carbs.
dave_ke30
sydney, the shire
Re: 3k-b twin carbys Thu, 13 October 2005 09:35 Go to previous messageGo to next message
sweet, thanks oldcorollas, your always there when i need advice on the big girl! Very Happy
Re: 3k-b twin carbys Fri, 14 October 2005 09:55 Go to previous messageGo to next message
Get a piece of hose, shove it down each carb with the engine idling, and put your ear on the other end. Listen to the sucking sound, and use this to help adjust the throttle stops to be fairly even. You can then finish off with some clear hose, connected to the vacuum side between the carbs, with some water in it. Balance the water level.
Of course you'll probably get it just fine with 30 seconds and a screwdriver rather than all the messing around I suggested!
allencr
tallahassee FL usOFa
Re: 3k-b twin carbys Fri, 14 October 2005 14:41 Go to previous message
position the stethoscope/hose at the SAME position on each.
if this manifold has a small balance port between each carb and/or port, then the vacuum won't mean much because it'll always be equal, unless they're REALLY off.
Previous Topic:4A-GZE IDLE CONTROL LOOM WIRING
Next Topic:engine mod
Current Time: Fri Nov 20 14:10:13 UTC 2026
Total time taken to generate the page: 0.0055191516876221 seconds
