Toymods » Tech & Conversions » 4 AC tach questions please
Widowmaker
Mexico
4 AC tach questions please Wed, 08 January 2003 08:21 Go to next message
sorry if this has been asked before but i cant find this info anywhere. On a 4AC i need to know the following
*What type of oil should i use
*What size spanner do you need to remove the sump plug
*What torque should you useto put the sump plug back on
*What size oil filter does it use
Re: 4 AC tach questions please Wed, 08 January 2003 11:11 Go to previous messageGo to next message
Type of oil? almost anything! just don't put anything rediculously thin in there. Good basic oil from almost any manufacturer should be fine.
Spanner? 14 or 17mm, depends which plug is in there.
Torque? 'somewhat firm' - if the gasket is in good order (replace it if it isn't), you should be able to feel when its about right - firm, but don't go silly.
Filter? Z386 (tiny!), or larger equivalent.
Widowmaker
Mexico
Re: 4 AC tach questions please Wed, 08 January 2003 11:16 Go to previous messageGo to next message
cheers,
one more thing how much oil does it take with the filter included ?
Kman
Re: 4 AC tach questions please Wed, 08 January 2003 11:22 Go to previous message
You can try 5mm past full on the dip stick, and check again after running the engine for a while.
Previous Topic:Reverse lights MA70 GT
Next Topic:ta22 gauges not working
Current Time: Fri Nov 20 22:03:48 UTC 2026
Total time taken to generate the page: 0.0040640830993652 seconds
