Toymods » Tech & Conversions » 2/3tg oil cooler question.
t_temperley
2/3tg oil cooler question. Fri, 14 October 2005 08:22 Go to next message
I have a 3tgteu oil cooler sandwitch plate and thermostat housing lying around and i am considering putting an oil cooler onto my 2/3tg .
My question is:
Can anyone confirm wether a 3t/13t oil pump safely supply enough pressure/volume for an oil cooler?
wombat
Laverton, Vic
Re: 2/3tg oil cooler question. Fri, 14 October 2005 08:33 Go to previous messageGo to next message
I got a 2tg/3t race engine (3tg) with a standard oil pump and a Rx7 turbo oil cooler, runs with no problems at all.
Re: 2/3tg oil cooler question. Fri, 14 October 2005 08:55 Go to previous messageGo to next message
fwiw, 2T pumps are the same size at K series engines..
i hear a rumour that the 3TGT pump is thicker.. and R series gears ARE thicker than 2T ones, so should be able to be modded for a bteer pump.
are 3TC and 2TG pumps the same?
wombat
Laverton, Vic
Re: 2/3tg oil cooler question. Tue, 18 October 2005 08:10 Go to previous messageGo to next message
no idea dude.
But I know the standard one with a adaptor plate with the in and out tubes works fine on the race car.
t_temperley
Re: 2/3tg oil cooler question. Tue, 18 October 2005 09:18 Go to previous messageGo to next message
alright thanks for that.
Ive got a 3tgte pump here but the casing appears to be fractured Confused i should get it checked out...
yrhkira
June 2005
Re: 2/3tg oil cooler question. Wed, 19 October 2005 05:35 Go to previous message
HI Guys,
My "avatar" TA-22 with a mild 2T has the OEM oil pump.
For my last couple of runs at Wakefield Park I ran an oil cooler form an adaptor plate. The OEM pump could not pump enough to match the "non oil cooler set up" pressure.
My oil cooler core may have been the restricting limit as pressure came up a bit more when hot.
Anyway my biggest problem was oil surge in the sump. The motor ran dry the last time out and rattled the bottom end. I was hoping the extra capacity created by the lines and cooler would help to absorb some of the surge, but to no avail.
My Competition 2T uses the TRD Oil pump made for the 2T/2T-G and has baffling in the sump. This combination gives me good oil pressure through the cooler.
t_temperley
You may find that putting baffling into the sump and running the OEM lower capacity pump will work fine.
As far as I know 2T, 2T-G and 3T motors run the same oil pump. If the 3T-GTE pump is bigger (ie has a thicker set of gears and a spacer plate) then it should be compatable to the other "T" motors.
Regards
Rodger
Previous Topic:Replacement rust patch plates - 1983 sprinter
Next Topic:where to buy?
Current Time: Wed Oct 21 02:56:31 UTC 2026
Total time taken to generate the page: 0.0044529438018799 seconds
