Toymods » Tech & Conversions » 100kw in AE82 twincam...
BootySlap
100kw in AE82 twincam... Fri, 14 October 2005 09:53 Go to next message
Anything else required besides the engine and ECU ? i.e will my normal C52 box and clutch etc bolt up?
bloody_huge23
Re: 100kw in AE82 twincam... Fri, 14 October 2005 23:59 Go to previous messageGo to next message
im pretty sure all u will need is the ecu and the motor. please someone confirm but im sure thats all we did to my car. just remember you may need an auto electy to wire your dash plug in to the new computer because i think its a diff plug. so make sure you get all three plugs with the ECU
BootySlap
Re: 100kw in AE82 twincam... Sat, 15 October 2005 08:02 Go to previous messageGo to next message
Ok thanks. I might just put another bluetop in it to make it simple. When putting in another engine that has done about 100,000 on it what things should I replace ?
Timing belt and engine seals ?
BootySlap
Stretch
Sydney,Hurstville
Re: 100kw in AE82 twincam... Sat, 15 October 2005 14:14 Go to previous messageGo to next message
yeah wack some platinum plugs in it, change your timing belt, 2 cam seals, 1 crank seal and check your water pump 2 make sure its not leaking.
BootySlap
Re: 100kw in AE82 twincam... Sat, 15 October 2005 23:44 Go to previous messageGo to next message
Excellent, exactly what I wanted to know, thanks!
Scorpion
Menai area of Sydney
Re: 100kw in AE82 twincam... Sun, 16 October 2005 05:05 Go to previous messageGo to next message
... and check your clutch plate while you have the chance.
Best to get the engine loom and underdash loom from the 100kw if doing the red top conversion. From memory the Twinky runs power to the driver's kick panel by running a wire across the radiator panel and along the wheel arch whereas the SX runs it through the firewall. ECU plugs are definitely different and this gets around that problem as well.
BootySlap
Re: 100kw in AE82 twincam... Sun, 16 October 2005 09:20 Go to previous message
Thanks but I think the 100kw conversion seems too time consuming. I need my car up and running very soon. Ill have to source some oil seals and timing belt.
Previous Topic:4A-GE into KM20 liteace '83
Next Topic:ke35 gearboxes
Current Time: Sat Nov 21 07:14:38 UTC 2026
Total time taken to generate the page: 0.0068528652191162 seconds
