Toymods » Tech & Conversions » 20v with Microtech LT10, do I need relay on vvt switch?
Gwaijaitat
April 2005
20v with Microtech LT10, do I need relay on vvt switch? Sat, 15 October 2005 05:53 Go to next message
Does anyone know silver top 20v 4AGE with Microtech LTx10, do I need a relay on the vvt switch? I think have read that LT8 needs a relay but not sure on LT10.
4ag20t
Re: 20v with Microtech LT10, do I need relay on vvt switch? Sat, 15 October 2005 11:47 Go to previous messageGo to next message
I would if i was you. ecu only switch low current, so use a relay, for the cost of $5-$10 do it.
Toy510
Toowoomba, QLD
Re: 20v with Microtech LT10, do I need relay on vvt switch? Sat, 15 October 2005 23:12 Go to previous messageGo to next message
Microtech Ecus only switch earths on outputs, ao Yes you will need a relay..
Gwaijaitat
April 2005
Re: 20v with Microtech LT10, do I need relay on vvt switch? Sun, 16 October 2005 03:47 Go to previous messageGo to next message
thx Razz
Gwaijaitat
April 2005
Re: 20v with Microtech LT10, do I need relay on vvt switch? Sun, 16 October 2005 13:03 Go to previous messageGo to next message
hey I got one more problem, does silver top 20v orginally got an air temperature sensor? if not, do I need to get a aftermarket one mount on to the quads because I changed the motor from air flow meter to map sensor?
sideshow
Re: 20v with Microtech LT10, do I need relay on vvt switch? Sun, 16 October 2005 13:49 Go to previous messageGo to next message
no u dont need relay
i have never wired one on a 20v vvt soleniod
its a solenoid so its low current
theres no harm fititng one but not needed
only needs one for things like thermo fans
u dontneed air sensor but i would run one
makes tune better when its hot or cold days
itsonly30 bucks for temp sensor
[Updated on: Sun, 16 October 2005 13:53]
Gwaijaitat
April 2005
Re: 20v with Microtech LT10, do I need relay on vvt switch? Mon, 17 October 2005 02:59 Go to previous message
yep, i'm getting a air temp sensor then, but where is the best place to for the air temp sensor to operate perfectly? I'm using open throttle for the quads, and so there's no plenum I can place the air temp sensor on. any suggestion on that? thanks
Previous Topic:horrible engine noise
Next Topic:Oil pissing out of breather!!!
Current Time: Tue Nov 24 10:57:06 UTC 2026
Total time taken to generate the page: 0.0050020217895508 seconds
