Toymods » Tech & Conversions » exhaust ignition/firing systems
shindeokure
melbourne
exhaust ignition/firing systems Sat, 15 October 2005 10:58 Go to next message
has anyone bought one of these kits? thoughts?
my car runs extremely rich when it hits full boost and this may be one way of solving the black smoke problems.
Re: exhaust ignition/firing systems Sat, 15 October 2005 11:18 Go to previous messageGo to next message
how about tuning it better?
because running rich at boost is much better and safer than than suddenly expiring at boost due to running lean.
Re: exhaust ignition/firing systems Sat, 15 October 2005 11:23 Go to previous messageGo to next message
Proper tuning is the go - you should be able to run rich enough to be safe, but not have shovel-loads of soot pouring out everywhere (i.e. 10:1 AFR is stupid)
shindeokure
melbourne
Re: exhaust ignition/firing systems Sun, 16 October 2005 11:39 Go to previous messageGo to next message
the engine runs naturally rich, and an aftermarket ecu won't make a big difference without risking damage (so my mechanic says..).
back to the question at hand.. has anyone tried one of these kits? the other option is to remove the catylic converter.. but i'd assume the first would be far less illegal, only attracting a yellow sticker rather than a big fine.
shinybluesteel
melbourne
Re: exhaust ignition/firing systems Sun, 16 October 2005 11:49 Go to previous messageGo to next message
get a new mechanic, running overly rich is NOT safe!
shindeokure
melbourne
Re: exhaust ignition/firing systems Sun, 16 October 2005 12:58 Go to previous messageGo to next message
thats usually the case, but fwiw i no longer drive a toyota.
mitsubishi evos are factory tuned to run a bit rich.. if you've seen or driven one you'll know what i mean.
this thread isn't about air/fuel ratios and their affects on the engine.. i want flames! Very Happy
[Updated on: Sun, 16 October 2005 13:03]
Re: exhaust ignition/firing systems Sun, 16 October 2005 13:00 Go to previous messageGo to next message
shindeokure wrote on Sun, 16 October 2005 22:58
this topic isn't about fuel ratios or their affects on the engine.. i want flames! Very Happy
if you are runnign rich, your cat may melt and block and then get all the flames you want Razz
maybe you should be asking on the mitsumods forum Razz
shinybluesteel
melbourne
Re: exhaust ignition/firing systems Sun, 16 October 2005 23:49 Go to previous message
well if you want flames!
go ahead, do you want flames all the time or just on trailing throttle? you could make a kit yourself, just put the plug near the exhaust tip so it doesnt burn out your mufflers.
Previous Topic:throttle body noise (sqeeling)
Next Topic:AE82 100KW Idle Issues
Current Time: Wed Oct 28 13:03:47 UTC 2026
Total time taken to generate the page: 0.02585506439209 seconds
