Toymods » Tech & Conversions » Nevo pulley
myne
October 2005
Nevo pulley Sat, 15 October 2005 17:28 Go to next message
Anyone know if it's possible to put these on 180* off?
I decided to check my base timing earlier saturday and was suprised to find that the timing marks were almost opposite to where they should have been. I ended up assuming that it was 180 out and used #2 cylinder to set it.
Seems fine but it'd be nice to know why the pulley timing marks arent where they should be.
shinybluesteel
melbourne
Re: Nevo pulley Sun, 16 October 2005 02:15 Go to previous messageGo to next message
more likely your dizzy is out?
i would assume that the pulley would only have one keyway in it.
toof
Re: Nevo pulley Sun, 16 October 2005 02:38 Go to previous messageGo to next message
you need to check the timing from below. the timing mark is 180deg out from the stock pulley as you have to cut off the standard timing pointer. you bolt up a little timing marker to the sump pan and check it from underneath Smile
myne
October 2005
Re: Nevo pulley Sun, 16 October 2005 05:20 Go to previous message
Ah thankyou, just the answer I wanted Smile
I was figuring something along those lines because it was a real pain to spot where the timing mark on the plastic cover was, AND find the timing mark. Atleast I know #2 is a reliable way of setting it.
Previous Topic:Heating Problem! **I GIVE UP!**
Next Topic:JDM diff no calipers - Using AE92 rear Calipers now!
Current Time: Sat Nov 21 07:36:57 UTC 2026
Total time taken to generate the page: 0.0050060749053955 seconds
