Toymods » Tech & Conversions » AE82 100KW Idle Issues
bloody_huge23
AE82 100KW Idle Issues Sun, 16 October 2005 01:38 Go to next message
Hey all,
I have a AE82 100kw Swap and i have some issues idleing when warm. Sometimes when im driving i stop at the lights and the idle doesnt drop below 2000rpm. If i give it a good rev past around 3500rpm it will then drop. Ive checked the throttle body to see if it isnt releasing properly but it seem ok. Could it be a vaccum issue or you think maybe it is something to do with the throttle not releasing?
myne
October 2005
Re: AE82 100KW Idle Issues Sun, 16 October 2005 04:37 Go to previous messageGo to next message
Could be a faulty idle stepper motor (if they have them) or even a sticky cable. There are dozens of things that can cause it, Next time pull over and see if you can see what it is.
Scorpion
Menai area of Sydney
Re: AE82 100KW Idle Issues Sun, 16 October 2005 04:57 Go to previous messageGo to next message
If you are using the stock 100kw airbox, try disconnecting the valve at the front of the airbox or blocking the vacuum line that goes to the throttlebody.
Also try sticking your finger over the cold idle bypass hole in the bottom of the inside of the throttlebody when it is idleing high to see if the revs drop. Use a rag 'cause it could be a bit hot if the hot water is getting through properly.
bloody_huge23
Re: AE82 100KW Idle Issues Sun, 16 October 2005 07:47 Go to previous messageGo to next message
im using a POD filter with the sensor drilled into the pipe. any one else got sum idea. or suggestions on what i should check.
bloody_huge23
Re: AE82 100KW Idle Issues Sun, 16 October 2005 23:01 Go to previous message
another thing i just thought of. could it be caused by the AC. because my AC doesnt work.
Previous Topic:exhaust ignition/firing systems
Next Topic:Tailshaft sound
Current Time: Thu Oct 29 09:49:52 UTC 2026
Total time taken to generate the page: 0.039686918258667 seconds
