Toymods » Tech & Conversions » Gze help!!
xxpunkerxx
Gze help!! Thu, 09 January 2003 01:54 Go to next message
I asked jason about this the other day and he suggested use the diagnostic box but it doesnt seem to work for me.
Anyway the problem: i was driving along the highway the other day and the rev would drop from 3 to 1.5 and then back up, like the call was wanting to stall.
This happened again today and the car wont start, it's firing, it seems like there is no fuel getting through, its turning over just not starting.
The possible problems i think it maybe are:
fuel pump, filter or something else to do with fuel (the car was carby before it was converted to run the gze)
The afm
Or i was told it might be the distributor modulator stuffing up.
Im gonna try get it down to the mechanic this arvo, but if any of you have any ideas to what it might be please tell!
The engine is an afm 4agze
Bugman
Re: Gze help!! Thu, 09 January 2003 01:59 Go to previous messageGo to next message
if you slightly push the afm flap does the fuel pump start? I know that is how my car is wired to run, different motor though
xxpunkerxx
Re: Gze help!! Thu, 09 January 2003 02:13 Go to previous messageGo to next message
If it does(nt) what does this mean?
Bugman
Re: Gze help!! Thu, 09 January 2003 02:14 Go to previous messageGo to next message
fuel pump could be dead, also check to see if you are getting power to the pump. hell it could also have just had it's wires come loose. check all plugs etc.
xxpunkerxx
Re: Gze help!! Thu, 09 January 2003 03:51 Go to previous messageGo to next message
Ok i tried that and i can hear fuel going into the engine,
does this mean the pump, lines etc are working
faulksy
Re: Gze help!! Thu, 09 January 2003 06:55 Go to previous messageGo to next message
u checked ur points
xxpunkerxx
Re: Gze help!! Thu, 09 January 2003 10:38 Go to previous messageGo to next message
Um a gze has coil packs and doesnt have points, or thats what i thought anyway.
Anyhow i reconnected the coilpacks and made sure all the wires in the engine bay were upto scratch, and the car now runs, and has done about 60kms without a problem
Bugman
Re: Gze help!! Thu, 09 January 2003 11:10 Go to previous messageGo to next message
sounds like a lose conection got fixed then.
Jonoze
Re: Gze help!! Thu, 09 January 2003 21:35 Go to previous messageGo to next message
Make sure you have a good earth for your igniter. After i hit a bump my car stalled and would not restart. The igniter bracket had shifted slightly and was not earthing properly. Put a seperate earth in and no more dramas.
xxpunkerxx
Re: Gze help!! Thu, 09 January 2003 21:47 Go to previous message
Bugman yea its seems as it was the coilpacks
Thanks for help re: the afm, good to know this for next time (hopefully there isnt a next time)
Previous Topic:air/fuel ratio meter??????
Next Topic:ST205 Blow off valve
Current Time: Fri Oct 23 02:06:54 UTC 2026
Total time taken to generate the page: 0.013756990432739 seconds
