Toymods » Tech & Conversions » O/D light flashing
cultus
Kuala Lumpur, Malaysia
April 2005
O/D light flashing Sun, 16 October 2005 13:00 Go to next message
The 1GGTE auto converted manual project is almost completed, will post up some pics soon.
I installed the GA70 dash and digi meter into my RA, All I did for the auto gearbox wires is that I bridged the neutral wires at the round socket near the firewall and hooked up the reverse sensor wires.
When I start the car up everything's fine, but after the car moves, the O/D light will keep on flashing until I shut off. So I double checked the wires at the auto shifter, if I bridge the OD switch wires, it is OD off and the meter indicator will be on. So I was right to leave it out.
Not a biggy though coz the engine is running fine, but it is a bit annoying. Any idea what is wrong? How I can fix it?
Thank you.
LAA.80E
The realist ghetto area P...
April 2005
Re: O/D light flashing Sun, 16 October 2005 14:00 Go to previous messageGo to next message
RIP out the light bulb!!!
Re: O/D light flashing Sun, 16 October 2005 23:32 Go to previous messageGo to next message
Its cause the speed sensor is missing.
cultus
April 2005
Re: O/D light flashing Mon, 17 October 2005 05:18 Go to previous messageGo to next message
I have modified and installed the speedo cable from the manual gearbox to the speed sensor behind the dash meter, and the speedometer is working. Is there another speed sensor somewhere? Perhaps another signal from inside the auto gearbox to the ECU?
I was thinking about removing the bulb but just wanna make sure there is no future problem arising by doing so.
Thank you for your replies.
Re: O/D light flashing Mon, 17 October 2005 08:59 Go to previous messageGo to next message
I'm not sure about this so you will have to check, but I think the auto box would of had an electronic speed sensor.
Soarer
Wollongong
Re: O/D light flashing Mon, 17 October 2005 13:16 Go to previous messageGo to next message
I'm with LAA.80E... rip the bulb out. It's the ECU telling you it can't see the auto box anymore. Happened on my Soarer when I converted to manual. Everything ran perfectly. I eventually replaced the ECU with a PowerFC, but that isn't exactly an option for you.
sideshow
Re: O/D light flashing Mon, 17 October 2005 21:51 Go to previous messageGo to next message
the 1gg ecu doesnt control the auto
it has a 2nd ecu for it if its electronic auto
did u run the speedo signal wire from the dash to the ecu ?
TRD_07
September 2005
Re: O/D light flashing Tue, 18 October 2005 07:58 Go to previous message
could be problem with your transmission's ecu
or something you can reset on the box itself like a wire for the selector etc etc... try changing out the transmission's ecu and see if it does the same thing
Previous Topic:what rods and crank are in a sivertop 20v?
Next Topic:Metal cats
Current Time: Fri Nov 20 20:02:22 UTC 2026
Total time taken to generate the page: 0.015374183654785 seconds
