Toymods » Tech & Conversions » 3s-gte(st185) into ta-23 conversion
gabe
icon10.gif  3s-gte(st185) into ta-23 conversion Thu, 09 January 2003 05:20 Go to next message
I am about to undertake this conversion within the next few weeks but id like to get a few things right in my head first. I have a st-185 3s-gte and i wanted to know peoples thoughts on this engine and also parts compatability with the st-205 3s-gte's. (ie sump, oil pump, injectors etc.) My second worry is the sump, as I dont want to loose the engine due to oil problems, will i need to get a custom sump made with bafflings in the correct direction??
Lastly, if I use the st-185 / 2s bellhousing / w58 gearbox combo, will I need to modify the bellhousing so the starter is on the other side??
Any help is much appreciated. Thanks
ps. what would be a realistic and reliable hp figure when i run with a custom intake, custom turbo manifold, turbo upgrade, fuel system upgrade and a haltech?
Re: 3s-gte(st185) into ta-23 conversion Thu, 09 January 2003 10:49 Go to previous messageGo to next message
Grab the sump and oil pickup off the 2S cause you will need this!
You dont "have" to modify the bellhousing to have the starter on the drivers side but it does make things easier!
TA22-3SGTE
MACKAY
Re: 3s-gte(st185) into ta-23 conversion Thu, 09 January 2003 10:57 Go to previous messageGo to next message
gabe
I fitted a ST165 3SGTE into my TA22 a few years ago , The fitting should be much the same only you will have more room in the TA23 ,
The starter on the left side is no problem as you need to make a custom ex manifold anyway , use the sump and pickup off the 2s ,
I just dynoed mine yesterday and put out 241 RWKW @ 22psi boost , in winter it put out 260 kw @ 21 psi
A reliable hp figure dependes on the tuning and the way it's driven .
Trevor
gabe
icon10.gif  Re: 3s-gte(st185) into ta-23 conversion Thu, 09 January 2003 12:50 Go to previous messageGo to next message
trevor,
interested as to what size fuel lines you are using and what other engine modifications you have done to get such a good power output( it cant be stock.... you must be running 12's!!!??)
cool1 i gather you are doing a similar conversion yourself, is there anything major (ie problembs) that I will run into??
gabe
Re: 3s-gte(st185) into ta-23 conversion Thu, 09 January 2003 12:54 Go to previous messageGo to next message
Yes i'm starting this conversion now using the ST205! Trevor has been helping me alot with information! I'm still tracking down bits and peices to complete the conversion!
gabe
Re: 3s-gte(st185) into ta-23 conversion Thu, 09 January 2003 13:03 Go to previous messageGo to next message
excellent, im VERY interested to know how you go.... does anyone know the fundamental differences between the st205 and the st185??
ive heard better head design, sump and oil pump/filter, basically a stronger engine all round
Re: 3s-gte(st185) into ta-23 conversion Thu, 09 January 2003 13:07 Go to previous messageGo to next message
Check this page mate. Lots of info Shocked http://gtfour.supras.org.nz/
[mikey]
Re: 3s-gte(st185) into ta-23 conversion Sat, 11 January 2003 09:58 Go to previous messageGo to next message
Differences are far many, but either engine is damn strong.
head design is differnet, valves same size, uses shim under bucket instead of over bucket on 205, intake cam on 205 has higher lift (8.7mm) and longer duration 240vs236, exhaust cam pretty much the same as 185. intake ports are diff size for single runner manifold instead of tvis like the 185. 60mm throttle body on st205, 55mm on st185. metal head gasket on st205. rods, pistons and crank pretty much the same on both. sump different with oil filter located off it on st205, baffling slightly better, little difference really. oil pump i am unsure of. ct20b is a better turbo but cant find parts for it anywhere so people rebuild with ct26a center.
hope that helps.
Michael
Classique71
Colac, Victoria
Re: 3s-gte(st185) into ta-23 conversion Sun, 12 January 2003 01:59 Go to previous messageGo to next message
Jusat curious here ?
is there a guide like that on how to put a 1ggte in a ra23/28 to do the 3sgte to ta/ra celica ?
Would be handy if there is - they are excellent to assist in what to buy for the conversions, since the 3tgte's are becoming a bit hard to come across
Also - trevor - what $$$ figure did it set you back for the conversion ?
Re: 3s-gte(st185) into ta-23 conversion Sun, 12 January 2003 02:48 Go to previous messageGo to next message
I will be taking notes of what to do during my conversion!
Classique71
Colac, Victoria
Re: 3s-gte(st185) into ta-23 conversion Sun, 12 January 2003 03:37 Go to previous messageGo to next message
ripper !!
All details appreciated when published
TA22-3SGTE
MACKAY
Re: 3s-gte(st185) into ta-23 conversion Mon, 13 January 2003 12:09 Go to previous messageGo to next message
Gabe
I am running two 5/16" fuel lines , I just pulled the fuel line out of another TA22 and ran it side by side with the original one .
No inturnal modifications have been done , I did a little blending and deburring in the ports and chambers , I made custom plenum and exhaust menifolds , 21/2" mandrel exhaust system , ST185 air to air intercooler , extra four 3SGTE injectors , two vl turbo fuel pumps , hiflowed single entry CT26 , Haltech E6S computer and have run 12.2 @ 120mph on street tyres .
Trevor
Classique71
Colac, Victoria
Re: 3s-gte(st185) into ta-23 conversion Mon, 13 January 2003 12:14 Go to previous messageGo to next message
bar the initial 90 degree swap - finding the RWD bellhousing , starter motor , and exhaust / inlet plumbing issues - was there any need for the likes of sump modifications ( i guess thats a custom call ? )
gearbox is a w57 ? supra box ?
120mph - 12 second pass ? hell thats good - seeing the stocko 2t's maxiumum speed down a VERY LONG STRAIGHT is about that - and a 18 sec quarters the usual .
proven tested theory re top speed - took me a few Km to nearly get there with a slight tail wind and a lot of braking room to pull the old girl up again ( 119 MPH on my 71's guage - 4700 RPM in 5th or there abouts - too scared to look down beyond that )
[Updated on: Mon, 13 January 2003 12:17]
Re: 3s-gte(st185) into ta-23 conversion Mon, 13 January 2003 12:58 Go to previous messageGo to next message
A W57 is from an RA60 etc. and is supposed to be similar in strength. It also has a closer fifth gear that isn't as overdriven as the W58.
Re: 3s-gte(st185) into ta-23 conversion Mon, 13 January 2003 13:02 Go to previous messageGo to next message
Yep you need the 2S sump and oil pickup aswell! The 3S normally sits on an angle to the sump is angled too! The 2S sump is nice and flat!
saspeed
Re: 3s-gte(st185) into ta-23 conversion Thu, 23 January 2003 11:32 Go to previous message
Classique71,
I am doing this conversion at the moment and thought you may like confirmation that everything you're being told is absoloutely correct. There are probably easier conversions you could do but results speak loudly don't they.
My conversion is for Improved Production race car and I will also publish when finished.
cheers !!
Previous Topic:Taking dash out of SV21 Camry - finding water leak
Next Topic:TA22 Brake and Suspension upgrade?
Current Time: Thu Oct 29 08:03:17 UTC 2026
Total time taken to generate the page: 0.0068230628967285 seconds
