Toymods » Tech & Conversions » 4AGTE Headgaskets
4ageeza
Adelaide, drift capital
icon5.gif  4AGTE Headgaskets Mon, 17 October 2005 00:33 Go to next message
Hey there,
For all you peeps that have a 4AGTE...what headgaskets are you using??
I'm about to bolt a bigport 4AGE head onto a GZE bottom end and am not sure what head gasket to use.
I was thinking of simply using a factory GZE headgasket...but thought i'd get some of your opinions.
Also...what turbo are you using?
Thanks,
Joel
4ageeza
Re: 4AGTE Headgaskets Mon, 17 October 2005 03:50 Go to previous messageGo to next message
Anyone???
ke382TG
Re: 4AGTE Headgaskets Mon, 17 October 2005 03:51 Go to previous messageGo to next message
My stock ~15 year old HG is holding up to 20psi fine and has been for a number of years now.
Another recently rebuilt 4AGTE was fitted with a stock Toyota HG and its holding up to 25psi fine.
My turbo = Garrett T28
My mates turbo = custom, of unknown origin
cri_ag
northern beaches
Re: 4AGTE Headgaskets Mon, 17 October 2005 07:27 Go to previous messageGo to next message
on the subject of headgaskets, are 20v and 16v headgaskets the same?
Rallystanza
Re: 4AGTE Headgaskets Mon, 17 October 2005 07:46 Go to previous messageGo to next message
I am using a Standard Toyota 4AGE HG, and will have an O'Ringed block also.
The genuine gaskets look to be very good.
Garrett GT28RS.
Jezza
kingmick
Banned by his request
moved to tamworth
Re: 4AGTE Headgaskets Mon, 17 October 2005 08:34 Go to previous messageGo to next message
Rallystanza wrote on Mon, 17 October 2005 17:46
Garrett GT28RS.
Jezza
your going to use a standard gasket with an oringed block?total waste of time.one you really need a copper head gasket with the orings and two you need a reciever cut into the head to do it properly.
just use a 7a head gasket as they are metal shim and will do you to about 20psi happly.i oring and reciever mine and use copper gasket for high boost but unless you going to play over 25psi dont bother.
mick
Big T
Re: 4AGTE Headgaskets Mon, 17 October 2005 09:24 Go to previous messageGo to next message
HKS 1.6mm metal multi-layer hg.
Currently have a rb25det tarbo but looking to upgrade to a hks gt2540.
Eddie.
Rallystanza
Re: 4AGTE Headgaskets Mon, 17 October 2005 09:45 Go to previous messageGo to next message
Mick,
Have a copper HG also, still undecided.
I think the Toyota gasket will be up to it though. Will be interested to see.
Jezza
[Updated on: Mon, 17 October 2005 09:47]
TE72_Turbo
Re: 4AGTE Headgaskets Mon, 17 October 2005 09:50 Go to previous messageGo to next message
I used genuine toyota head gasket also, never had an issue with head sealing running 20psi, originally with T04/CT26, then garrett T28, then GT2535.
Seems to be that they are one tough critter Cool
4ageeza
Re: 4AGTE Headgaskets Mon, 17 October 2005 10:17 Go to previous messageGo to next message
Cheers for your replies.
I'm going to be putting new rings and bearing in my GZE block and running a T25 or similar turbo at like 14psi...so I think i'll just stick with a genuine Toy hg.
Thanks,
Joel
TE72_Turbo
Re: 4AGTE Headgaskets Mon, 17 October 2005 10:20 Go to previous messageGo to next message
good plan Smile
cri_ag
northern beaches
Re: 4AGTE Headgaskets Sat, 05 November 2005 13:35 Go to previous messageGo to next message
so am i going to be doing any harm running an o-ringed block with a standard head gasket?
FLYNSX
    flyn
Re: 4AGTE Headgaskets Sat, 05 November 2005 21:56 Go to previous message
i just fully rebuilt my 4agte pistons rods etc etc iam runing 25psi iam using a cometic metal headgasket 1.1mm thick the standard toyota ones i found blew after about 15psi.
Previous Topic:NEED HELP!!! coolant and engine parts
Next Topic:intercooler piping
Current Time: Tue Oct 27 10:15:50 UTC 2026
Total time taken to generate the page: 0.069438934326172 seconds
