Toymods » Tech & Conversions » swapping axles between crown and mkII diffs?? (4 -> 5 stud)
brett_celicacoupe
townsville NQLD
icon5.gif  swapping axles between crown and mkII diffs?? (4 -> 5 stud) Mon, 17 October 2005 12:17 Go to next message
just wondering if somebody would now first hand if the 5 stud axles from a crown MS65 (any others??) will fit straight in place of the 4 stud axle that come standard with the corona mkII's.
im pretty sure, not 100% but the crown's do have F series diff's right???
so things that may need to be considered are;
-overall axle length
-bearing diameter
-major differences in the flange (NFI what its proply called) on the end of the axle where the studs sit in
- bearing retainer thickness and the 4 bolt hole pattern
any help would be appreiciated
Re: swapping axles between crown and mkII diffs?? (4 -> 5 stud) Mon, 17 October 2005 12:54 Go to previous messageGo to next message
Aussie built MS65 have a Borg Warner diff. Very unlikely the stuff will transfer across to a Mark II diff. The chances of finding a Jap import 60/70 series are about zero - I have seen 3 in my life and I look out for this kind of shit.
Maybe try an MS85 Super Saloon (imported) - I'm pretty sure the base models also had Borg Warner diffs as they were built by AMI.
This is why I suggested people use the much more common MS112 diffs. Discs, 5 stud and F series.
Moral of the story - Mark II diffs should be left in Mark IIs.
Re: swapping axles between crown and mkII diffs?? (4 -> 5 stud) Tue, 18 October 2005 02:11 Go to previous messageGo to next message
gianttomato wrote on Mon, 17 October 2005 22:54
Except for the ones broken/rusted beyond repair, ie most of them these days.
Re: swapping axles between crown and mkII diffs?? (4 -> 5 stud) Tue, 18 October 2005 03:23 Go to previous messageGo to next message
Norbie I disgree.
brett_celicacoupe wrote on Mon, 17 October 2005 22:17
He never searched. Now he wants help with his sticky situation. A cursory glance would have given him the MS112 diff solution. Another search would have confirmed what diff every Australian Crown from 1967 through to 1986 had.
-bearing diameter
We know what to consider, which is why the helpful advice (readily available with a search) was offered before the rare car was destroyed.
Does it sound like I'm moralizing? It should. A lack of research has landed him in the shit. He clearly doesn't listen so why offer advice?
wilbo666
Re: swapping axles between crown and mkII diffs?? (4 -> 5 stud) Tue, 18 October 2005 04:08 Go to previous messageGo to next message
gianttomato wrote on Tue, 18 October 2005 13:23
Norbie I disgree.
-bearing diameter
Alas he has already destroyed a much better looking car to acquire said mk2 diff to put into a very ugly model celica (come on we are being honest Razz) Sad (oh I'm guessing you told him in the first place when he was looking for an F series diff to get an MS112 one? In that case I see where you are coming from Smile)
As far as I'm aware he doesn't need 5 stud, but I'm guessing that like the rest of us he would like to be able to find wheels with a offset that will fit one day...
I suggest he take the MXxx diff back and get an ms112 one Razz (also has the bonus of avoiding the wrath of dave Smile)
brett_celicacoupe
townsville NQLD
Re: swapping axles between crown and mkII diffs?? (4 -> 5 stud) Tue, 18 October 2005 10:06 Go to previous messageGo to next message
well thanks for the info anyway Confused
i did search a bit but maybe not enough.
for your peace of mind GT; the diff was a spare the bloke had who owned a MX13. he advertised the whole car for sale but i only wanted the diff. no harm or destruction brought to any MXxx's in the process
last time i drove past, he still had the car so maybe you should buy it Smile
being where i am, rare bits and rare cars are twice as hard to come by. the mkII diff just popped up at a good price and suited my purpose. i know the MS112 diff would be good but the chances of finding one at a wreckers are basically nill, and the price of buying one and freighting it up would be very Xy. when i searched i did see that there was a fair bit of demand for the MS112 diff's but not many people seemed to have them. it would be easyier and cheaper to source a set of axles than the whole diff.
im not desperate to go to 5 stud right now either, it just would be good knowing i can simply swap it in later
seeing as i already have the diff housing made up, would anybody know if the MS112 axles go into the mkII diff housing??
thanx anyway
Re: swapping axles between crown and mkII diffs?? (4 -> 5 stud) Tue, 18 October 2005 10:15 Go to previous messageGo to next message
brett_celicacoupe wrote on Tue, 18 October 2005 20:06
Not a hope. The MS112 diff has massive double row bearings.
Try MS85 Super Saloon like I said above.
Failing that, see about redrilling the axles. They'll be covered with a disc hat so hopefully your engineer won't see it.
[Updated on: Tue, 18 October 2005 10:16]
Pure_In_Sanity
Melbourne, Vic
Re: swapping axles between crown and mkII diffs?? (4 -> 5 stud) Tue, 18 October 2005 10:47 Go to previous messageGo to next message
Brett
Why do you want to go 5 stud?
Because of wheels?
If its for brakes you can use the rt142 corona rear disk setup and keep the 4 studs...
-Phil
brett_celicacoupe
townsville NQLD
Re: swapping axles between crown and mkII diffs?? (4 -> 5 stud) Tue, 18 October 2005 11:28 Go to previous message
Pure_In_Sanity wrote on Tue, 18 October 2005 20:47
Brett
Because of wheels?
-Phil
yeh 5 stud would be better because there is a much broader choice of wheels and offsets Smile
i already got a set ST141 avante disks so im set in that respect. Smile
gianttomato wrote on Tue, 18 October 2005 20:15
riteo thanks for that. dont think there are many MS85's wrecking up here but i did see a couple driving around. so they are 5 stud as well??
i might even have to look at re-studding the axles and redrilling the disks. just looking for a cheap/easy alternative. Smile
Previous Topic:adjustable rear camber on my ga65
Next Topic:extractors/exhaust help
Current Time: Fri Nov 20 21:45:48 UTC 2026
Total time taken to generate the page: 0.0062370300292969 seconds
