Toymods » Tech & Conversions » supercharger
bookie
June 2005
supercharger Mon, 17 October 2005 12:45 Go to next message
Hi guys
im jus wonderin how wud a standard gze supercharger (sc12 i tink) perform on a 5sfe?
wot wud i need n how much?
toof
Re: supercharger Mon, 17 October 2005 13:04 Go to previous messageGo to next message
for the same effort use an sc14.
i imagine it will add a nice bit of poke. i used to have an st184 and i imagine it'd make a really nice and punchy setup;
bookie
June 2005
Re: supercharger Mon, 17 October 2005 13:15 Go to previous messageGo to next message
soz im new
wen u said "for the same effort use an sc14."
wot does that mean?
Re: supercharger Mon, 17 October 2005 13:51 Go to previous messageGo to next message
bookie wrote on Mon, 17 October 2005 23:15
soz im new
wot does that mean?
for the same effort to install an SC12, use an sc14 instead.
please also use grammar and spelling if you possibly can. it is more polite and people are much more likely to answer your queries.
toof
Re: supercharger Mon, 17 October 2005 22:03 Go to previous messageGo to next message
toyota make two chargers (well easy to get ones) the SC12 (1200cc/rev) and the SC14 (1400cc/rev)
given you will be doing a bit of fabrication to make either fit save the effort later and just put the bigger one on to start with.
rthy
Melbourne - NthSubs
Re: supercharger Tue, 18 October 2005 00:04 Go to previous messageGo to next message
what does the sc14 come standard in?
Blown86
Re: supercharger Tue, 18 October 2005 00:09 Go to previous messageGo to next message
rthy wrote on Tue, 18 October 2005 08:04
Aluminium! Razz
1ggze
toof
Re: supercharger Tue, 18 October 2005 00:10 Go to previous messageGo to next message
1g-gze's 2L six from early chasers... and possibly soarers... someone will correct me though..
terra
July 2005
Re: supercharger Tue, 18 October 2005 01:17 Go to previous messageGo to next message
may as well buy a cheap ebay gm or ford charger Smile
Re: supercharger Tue, 18 October 2005 05:28 Go to previous messageGo to next message
terra wrote on Tue, 18 October 2005 11:17
the eaton M45's are a little bigger. and a little more efficient as they are twsited lobe roots, but i think they have a much longer snout, and physically larger and may be harder to mount... then again, i may be wrong.
Lysholm all the way baby Razz oh.. right.. they aint cheap Razz
toof
Re: supercharger Tue, 18 October 2005 05:44 Go to previous messageGo to next message
i think the sc 5sf(z)e would go really well.. only problem is the lack of space to mount the thing.. i guess you could mount it low on the block at the abck below the power steering pump. pluming might be an effort though.
but if you get it all working id be keen to see it i imagine it'd go well.
which car ? st184 ? i think it'd make an already nice car an absolute hoot.
Re: supercharger Tue, 18 October 2005 06:17 Go to previous messageGo to next message
so why not just go 3SGTE already Rolling Eyes
or 3SGZE if you want to be different (i would Razz )
toof
Re: supercharger Tue, 18 October 2005 06:48 Go to previous messageGo to next message
5sfe is already there lol Razz some bigger injectors and a piggy back i reckon would make a nice cheap pokey enmgine.
Windex
Melburn!
June 2005
Re: supercharger Tue, 18 October 2005 07:31 Go to previous messageGo to next message
Yeah I am thinking of doing the same sort of thing with my 3SGE, it has no aircon but still has an aircon pully, however due to the manifold on the gen2 I might be looking at 20v quads first. Keep us posted on how you go.
terra
July 2005
Re: supercharger Tue, 18 October 2005 07:39 Go to previous messageGo to next message
wouldnt it be easier to to a intercoolerless turbo set up with 3sgte parts?
toof
Re: supercharger Tue, 18 October 2005 07:59 Go to previous messageGo to next message
but then you would have an intercoolerless setup Razz
and unless you were actually rigging the engine up for forced induction id suggest against it.
if you mounted the charger on the inlet side of the engine below the power steering pump and used a water-air barrel cooler below the inlet manifole and the gearbox or there abouts... the been a while since ive been in a st184 engine bay but im sure it could be workable, just trying to remember how much space there is behind the engine.
seven_mgte
Vancouver BC, Canada.
Re: supercharger Tue, 18 October 2005 22:24 Go to previous messageGo to next message
rthy wrote on Mon, 17 October 2005 17:04
Also, over here in canada they came in the 94-97 Previa (Tarago/Estima to you guys) mated to the 2.4L 4 cyl 2TZ-FZE engine. Dont know if you got them in australia
toof
Re: supercharger Wed, 19 October 2005 00:33 Go to previous messageGo to next message
no we never got them here.
if you do find a charger from a previa (unlikley over here) be careful with brackets that you make casue it wont ge interchangeable with the 1ggze sc14 as i believe not only are the mounting tabs different but also the pulley assembly has a differnt offset.
bookie
June 2005
Re: supercharger Wed, 19 October 2005 10:00 Go to previous message
thank you for all your efforts. The s/c is going into my camry. Does any here have the s/c setup for a 5sfe?
Previous Topic:Removing Valve springs
Next Topic:need a pic of an alternator plug/ wanted fuel hose
Current Time: Fri Oct 23 12:46:15 UTC 2026
Total time taken to generate the page: 0.0096390247344971 seconds
