Toymods » Tech & Conversions » custom plenum dimensions??
LAA.80E
The realist ghetto area P...
April 2005
custom plenum dimensions?? Mon, 17 October 2005 16:18 Go to next message
hi people im just curious bout dimension sizes for a 4age custom plenum, should the chamber be able to hold a maximum of 3 litres and what are the dimensions for the runners that lead to the head
thanks people!
[Updated on: Tue, 18 October 2005 01:07]
DanielGVisser
Rockhampton, Queensland
Re: custom plenum dimensions?? Tue, 18 October 2005 22:06 Go to previous messageGo to next message
well not to give any good ideas away or anything that i have used for my design. The plenum chamber volume should apparently be twice that of the engine capacity. So in our case it would be 3.2Litres. But some performance guru's beg to differ and say that 3.2Litres would be a minimum and larger is better given your desired application. Short length runners are ideal for different situations and setups and so are the long length runners. All depends on what you are going to be doing i suppose.
So yeah, hope this gave you some ... thing.
Dan
LAA.80E
April 2005
Re: custom plenum dimensions?? Wed, 19 October 2005 01:10 Go to previous messageGo to next message
thanks mate!
LAA.80E
April 2005
Re: custom plenum dimensions?? Wed, 19 October 2005 01:11 Go to previous messageGo to next message
how bout the runner sizes should they go from big to small vice versa??
DanielGVisser
Re: custom plenum dimensions?? Wed, 19 October 2005 02:08 Go to previous messageGo to next message
no, try to get your runners equal in length. Have you ever heard of the term "tuned length runners" ? they basically a certain length depending on your application and are equal in length and size.
Ben Wilson
Re: custom plenum dimensions?? Wed, 19 October 2005 02:41 Go to previous messageGo to next message
The factory 4AG inlet runners are a pretty good length, I'd suggest trying for something around 1" or so shorter.
JustenGT4
Re: custom plenum dimensions?? Wed, 19 October 2005 03:23 Go to previous messageGo to next message
The longer the runners the better bottom to mid range torque you will have....shorter runners give better top end power. Actual ideal lengths are engine and use specific but staying as close as you can to the factory or a little shorter is a good rule of thumb.
Plenum size should be roughly 1.5 to 2.5 times engine capacity but there are so many variables that impact on this that any volume in that range will be fine for general performance use. To chase every extra hp lurking in a setup requires testing testing testing so for most of us the rule of thumb type approach is fine.
Fattony
Re: custom plenum dimensions?? Wed, 19 October 2005 03:25 Go to previous messageGo to next message
its been documented that the plenum volume should be anywhere between 1.5 to 2 times that of the engine capacity. Which would make it be 2.4-3.2 litres. As regard to runner legnth make it as physically as long as possible to fit under the bonnet and keep it tunned length, otherwise your gonna end up with runners that are optimised for a power band to rev 10krpm and beyond (thats with 4 inch runners from the valve seat) and to keep it optimised for a lower revving engine the legnth becomes stupid and well beyond what you can fit under your bonnet. I dont have exact figures at hand but i will post them later on how to calc runner legnth.
LAA.80E
April 2005
Re: custom plenum dimensions?? Wed, 19 October 2005 13:31 Go to previous messageGo to next message
good stuff!!! thanks heaps im getting all excited n shit i wanna start chopping things!
DanielGVisser
Re: custom plenum dimensions?? Wed, 19 October 2005 13:33 Go to previous messageGo to next message
haha lol Very Happy
LAA.80E
April 2005
Re: custom plenum dimensions?? Wed, 19 October 2005 13:35 Go to previous messageGo to next message
hehehehe Very Happy
Re: custom plenum dimensions?? Thu, 20 October 2005 03:19 Go to previous messageGo to next message
Where are you guys getting this info about plenum volume?
Regarding plenum volume, Corky Bell says:
Quote:
An air intake plenum sould be several times larger than a cylinders displacement.
Further on in his book he says:
Quote:
The plenum volume should be a function of engine displacement-in general, 50-70%.
Re: custom plenum dimensions?? Thu, 20 October 2005 03:27 Go to previous messageGo to next message
The following page has some good info:
http://www.eng.ed.ac.uk/~jchick/Y5/thesis/FormulaS tudent/public_html/pt7.htm
Quote:
For a tuned plenum and intake pipe the following guidelines, from Grape Ape Racing can be used. For engines operating in the 5000-6000 rpm rage. For a four cylinder 50-60% works well. If a boost is desired in a higher rpm range, closer 7000-7500 rpm, the plenum will need to be 10-15% smaller.
[Updated on: Thu, 20 October 2005 03:27]
Re: custom plenum dimensions?? Thu, 20 October 2005 04:13 Go to previous messageGo to next message
I heard many different ideas on this one.
From 80% engine size to 2.5x engine size.
In the end I set down some requirements (must have min 75mm of air space over the runner bellmouth, must have pace between bellmouth and any wall - 50mm if possible).
Now from my 1st runner to 4th runner (including bellmouths and some space before and after each one so not close to a wall) was a bit over 400mm..
Height, 75mm being the lowest over 4th bellmouth.. Tappering up to 95mm over the 1st runner.
Then its not a box either as i wanted some space around the sides of the bellmouths, so more oval shape..
But do some quick calculations of a oval shape with above measurements and you end up with over 4lts.
So 2x engine size was the smallest i could make the plenum i felt. That isn't taking into account runner volume, or throttle body to plenum volume either.
Stuffed if i know how you can make a plenum 80% engine size and have it flow well?
Re: custom plenum dimensions?? Thu, 20 October 2005 05:29 Go to previous messageGo to next message
Joel, i took some pics of the TRD 3SGTE (from JGTC supra?.. at Toyota Amlux) that makes some stupid amount of power... the plenum is very small, and seems more like a device to direct air to the ports, as opposed to a reservoir for holding pressurised air. i dount it is even 100% of capacity.. maybe closer to 50%?
the cast exhaust manifold is also decepitively simple.
I'll put them up on new forum this weekend if i remember Razz
from memory, it kinda looks like Yellorollas plenum.....
Re: custom plenum dimensions?? Thu, 20 October 2005 05:30 Go to previous messageGo to next message
TurboRA28 wrote on Thu, 20 October 2005 14:13
oh, looking at cyl 4, i was wondering how it could get any air at all.. but i guess it does...
Re: custom plenum dimensions?? Thu, 20 October 2005 05:34 Go to previous messageGo to next message
Is that more for outright power though, than a healthy midrange?
LAA.80E
April 2005
Re: custom plenum dimensions?? Thu, 20 October 2005 05:42 Go to previous messageGo to next message
okay!! sorry guys but i have no idea what the hell is going on!! can sum1 pin it down for me on what measurments i will need to gain good mid range to higher rev approx 7k rpm , diameters of runners? length of runners? litres in the chamber?
please amyone?!!!
Re: custom plenum dimensions?? Thu, 20 October 2005 06:06 Go to previous messageGo to next message
oldcorollas wrote on Thu, 20 October 2005 15:29
Just email me the pictures now!!! I want to see!!!
Re: custom plenum dimensions?? Thu, 20 October 2005 06:10 Go to previous messageGo to next message
TurboRA28 wrote on Thu, 20 October 2005 15:34
most likely just for higher rev range... i think it was pulling 460Nm and around 500hp? i took a pic of the specs too. it looks weird tho.. hmm, hard to explain...
sorry Cool1, they are at home.. and i am giving a lecture this afternoon... maybe tonight Wink
ed_ma61
Lost in the K hole
Re: custom plenum dimensions?? Thu, 20 October 2005 06:12 Go to previous messageGo to next message
LAA.80E wrote on Thu, 20 October 2005 15:42
what measurments i will need to gain good mid range to higher rev approx 7k rpm , diameters of runners? length of runners? litres in the chamber? please amyone?!!!
*oh thats an easy question*
me thinks someone needs to do some research - far and wide. i doubt anyone here will give you a pinned-down answer at all.
it took me weeks of calculations, research and a very expensive computer simulator to figure mine out, and its still all a bit of guesswork.
and do you really think you can manufacture tha parts to the exact specifications you come up with anyway??
Re: custom plenum dimensions?? Thu, 20 October 2005 07:32 Go to previous messageGo to next message
oldcorollas wrote on Thu, 20 October 2005 16:10
Alright then... Sad
LAA.80E
April 2005
Re: custom plenum dimensions?? Thu, 20 October 2005 08:06 Go to previous messageGo to next message
im pretty sure it wouldnt, BUt i know it takes heaps of research and shit thats why im here askn those who have had experience b4 as though i have neva got one dun b4, thats why i need sum pionters from people!
kapish!
Re: custom plenum dimensions?? Thu, 20 October 2005 20:42 Go to previous messageGo to next message
I think everyone has given you some pointers man.. I reckon you just wanna be spoon feed the info?
LAA.80E
April 2005
Re: custom plenum dimensions?? Fri, 21 October 2005 05:46 Go to previous messageGo to next message
ummm no not really, i thank you guys for your help thats all.
Re: custom plenum dimensions?? Fri, 21 October 2005 06:40 Go to previous messageGo to next message
Cool1 wrote on Thu, 20 October 2005 17:32
Alright then... Sad
http://toymods.net/forums/showthread.php?t=351
kingmick
Banned by his request
moved to tamworth
Re: custom plenum dimensions?? Fri, 21 October 2005 11:31 Go to previous messageGo to next message
mate if your not going to go over size valves,bigger springs,port the hell out of it and flow it that much that it cost more than the engine,stick to the standard on an atmo 4age
mick
LAA.80E
April 2005
Re: custom plenum dimensions?? Fri, 21 October 2005 16:24 Go to previous message
thats fair enough
Previous Topic:72 rolla
Next Topic:4A GZE Injector
Current Time: Fri Nov 20 21:02:17 UTC 2026
Total time taken to generate the page: 0.020563840866089 seconds
