Toymods » Tech & Conversions » gze power up
DacBietAE86
gze power up Wed, 19 October 2005 00:01 Go to next message
GUYS...
Does anyone know what result i would get with the following mods
ae101 gze
FMIC
2.5" exahust
nevo pulley
adj cam gears
bigport cams
Would the standard ecu be able to handle it throughout the rev range?
or do u think an aftermarket ecu is a must.
4agte
Toronto, Downtown
Re: gze power up Wed, 19 October 2005 00:05 Go to previous messageGo to next message
firstly search
second how big is you i/c going to be are you just front mounting the stocker
thirdly which size nevo pulley
why bother with adjustable cam gears and bigport cams
get a decent aftermarket ecu and you will get greater benefit. The stock ecu will handle the power no worries
DacBietAE86
Re: gze power up Wed, 19 October 2005 00:20 Go to previous messageGo to next message
Yeah dude.. i have been searching..and noticed people are using the bigport cams in their ze to gain some more
midrange torque.ive already got the cam gears and bigport cams arnt hard to find cheaply.
i have a big Trust intercooler in the front, 175mm nevo..
Sorry maybe i asked the wrong question
Will my standard ecu be able to supply enough fuel and not lean out at high revs and start cutting out.
i hear the standard ecu can only supply enough fuel for about 220hp. (im assuming thats at the engine)
i duno what that is in kw at the wheels
i know a aftermarket ecu would be better but right now i dont have the funds for a new ecu
[Updated on: Wed, 19 October 2005 00:21]
4agte
Toronto, Downtown
Re: gze power up Wed, 19 October 2005 00:43 Go to previous messageGo to next message
pleanty of people are using stock ecu's with 175mm nevo peulleys the stock ecu's run extremley rich so there is good gains if you switch to aftermarket. Best way to see if the ecu will cope is stick it on the dyno. Its not allways the ecu that makes it run lean could be buggered fuel pump block fuel filter etc
DacBietAE86
Re: gze power up Wed, 19 October 2005 00:53 Go to previous messageGo to next message
yeah sounds about right..
i was just thinking , is it worth me getting the big port cams in and get it timed with the adj cam gears with a stock ecu.
i was just worried the standard ecu would sh#t itself.
im going to get some and try it...
i just rebuilt my gze so lets see what i pull up on the dyno..
4agte
Toronto, Downtown
Re: gze power up Wed, 19 October 2005 01:28 Go to previous messageGo to next message
probably wont get the best from them on the stock ecu but the ecu should be allright with the cams ive seen people using trd 272 cams on a stock gze ecu and it still ran ok.
Might be worth looking at a piggyback soloution like a greddy emanage they are about $500 i think and with 200-300 worth of tuning should make the most of your cams/gears
DacBietAE86
Re: gze power up Wed, 19 October 2005 01:34 Go to previous messageGo to next message
really..
well i was searching and i came across a post with someone reccomending 272 cams on a gze.
Does anyone here have them on their gze with a stock ecu?
im very interested in knowing what the result was like.
thanks for all your help 4agte.
Appreciate it!!
drift86levin
brisvegas
Re: gze power up Wed, 19 October 2005 12:16 Go to previous messageGo to next message
big trust front mount? how big is big? if it's any bigger than 420x240x70 you have selected a core that is too big, and prolly loosing power/boost becase of it..is it a bar and plate or a tube and fin? if it's in an AE86 i'd be geussing it would make around 115-120RWKW.. mine spun 104RWKW with my front mount setup, and exhaust..ran 13.9 @98mph..so its pretty consistant with it's dyno read out..approx 200hp A flywheel..that was on the stock 10.44 PSI..
Hodgo
Re: gze power up Wed, 19 October 2005 12:40 Go to previous messageGo to next message
Honk
[Updated on: Wed, 19 October 2005 12:42]
DacBietAE86
Re: gze power up Thu, 20 October 2005 01:34 Go to previous message
well i 520x250x70 trust core
hmms maybe it is too big..
well once the nevo pulley gets here i'll test it all out and let everyone know..
Previous Topic:3k Tosco (TRD) Manual
Next Topic:4ag 20Valve AW11 ignition breakdown
Current Time: Sat Oct 31 14:19:18 UTC 2026
Total time taken to generate the page: 0.084534883499146 seconds
