Toymods » Tech & Conversions » how many people otu there with leaking 16v dizzy's
beige_bandit
September 2005
how many people otu there with leaking 16v dizzy's Wed, 19 October 2005 04:10 Go to next message
im just here expressing my anoyance Mad
got my motor out of an ae86 halfcut, bout a week after
i started it in my car oil start's leaking out to rotor shaft(not pissing) so i buy another second handy, bout a week later after i put it in, it start's to leak Mad
ok lets try to rebuild the fucker, took it apart and matched
a seal and bearing both from CBC, $10 for both items Very Happy
now the old seal shatterd like plastic when trying to remove, but
was so hard it had made a groove in the shaft(not good), but
the new seal was 2mm taller so me not think seal working in same
position as original one(cant buy original), so me think i might
get away with it Rolling Eyes
NO NO NO Mad Mad
the fuckers is leaking again, but not as much as before
i think ill just let the prick leak till i get rid of the
dizzy and get an ECU and coil's running direct to plugs
DAMN DISTRIBUTOR OF PAIN Evil or Very Mad
xolent
Re: how many people otu there with leaking 16v dizzy's Wed, 19 October 2005 07:08 Go to previous messageGo to next message
mine is leaking and I don't want to take it out ever again (I "accidently" put it in right and it finally worked after a whole day trying to get it off retard).
drift86levin
brisvegas
Re: how many people otu there with leaking 16v dizzy's Wed, 19 October 2005 12:12 Go to previous messageGo to next message
new o-ring, and ultra blue..
beige_bandit
September 2005
Re: how many people otu there with leaking 16v dizzy's Wed, 19 October 2005 22:30 Go to previous messageGo to next message
Oil leaks Through the rotor shaft,
O-ring not a problem Very Happy
bluehachi
September 2005
Re: how many people otu there with leaking 16v dizzy's Thu, 20 October 2005 00:03 Go to previous messageGo to next message
yeah both of mine leaked... everytime you gave it some stick the oil would leak through and onto the extractors... then burning the oil fumes and into the cabin!
lovely
Kurt.R
Penrith
February 2005
Re: how many people otu there with leaking 16v dizzy's Thu, 20 October 2005 02:39 Go to previous messageGo to next message
This is a very common problem. There was a really good thread on this about 6 months ago and it went into how to change the internal shaft seal e.t.c. The seal that go's onto the outside of the shaft between the shaft and the head can still be bought from toyota for about $5. I got one not long ago.
I put an extra breather in my right hand side rocker cover and this helped.
Kurt.
4agte
Toronto, Downtown
Re: how many people otu there with leaking 16v dizzy's Thu, 20 October 2005 03:50 Go to previous messageGo to next message
bluehachi wrote on Thu, 20 October 2005 10:03
lovely
so true except mine used to smoke out the engine lid i/c vent behind me not really nice seeing that while your sitting at the lights
beige_bandit
September 2005
Re: how many people otu there with leaking 16v dizzy's Thu, 20 October 2005 03:53 Go to previous messageGo to next message
Yes, but the O-ring you speak of seal's the dizzy housing to the
head, the drama is more the fact that the seal that seal's
the shaft and the dizzy housing can not be bought from toyota,
,the only part that toyota can supply is the O-ring for the outside.
I managed to match the inside seal and bearing but it was all for
poop's Crying or Very Sad
Kurt.r, does your dizzy still leak? how did you go about getting
the extra breather?
Did you mod it or get two inlet side cam covers?
ke1500
Re: how many people otu there with leaking 16v dizzy's Thu, 20 October 2005 03:57 Go to previous messageGo to next message
I had an additional breather on opposite rocker cover, with a crank angle sensor... and yes it still leaked. Very annoying
KLR16V
Ryde
Re: how many people otu there with leaking 16v dizzy's Thu, 20 October 2005 13:00 Go to previous messageGo to next message
i got the same problem too...
it gives me the shits bigtime
toof
Re: how many people otu there with leaking 16v dizzy's Thu, 20 October 2005 13:53 Go to previous messageGo to next message
http://www.kbox.ca/page3.html
Quote:
KIT#12311973 - $19.98 US Funds
1984-89 Toyota MR2 4AGE / 4AGZE
Distributor Seal Repair Kit
1 - External Housing O-ring
1 - Internal shaft oil seal
1 - Cap to Distributor O-ring
1 - Replacement shaft pin
1 - O-ring for green electrical plug
may i bring to your attention....
Omen
Melbourne, Australia
March 2005
Re: how many people otu there with leaking 16v dizzy's Sun, 23 October 2005 05:57 Go to previous messageGo to next message
I too had the problem.
I did the replacement of the inner shaft seal, and it worked fine.
My dizzy also had another issue - a faulty pickup. I went to see Mike @ Dissy's Galore VIC ( Phone: (03) 9355 7899 ). He not only had a pickup, but also a dizzy that had this common Toyota inner leaking seal issue fixed properly (different seal and re-machined shaft or something...).
Perhaps give him a call if you are really wanting to fix it...hope this helps...
Kurt.R
Penrith
February 2005
Re: how many people otu there with leaking 16v dizzy's Sun, 23 October 2005 09:06 Go to previous message
The extra breather almost completely stoped my dizy from leaking. I drilled a hole in the top of the cover and used a threaded fitting. I then had to weld a small plate on the inside of the cover with a few holes drilled in it to stop the oil from just pissing out through the breather. I didn't fit another left hand side rocker cover cause I didn't want to have 2 oil caps.
Previous Topic:Still remember the "Bourke Engine"???
Next Topic:ST162 / ST165 / ST185 Brake Upgrade v Wheel Size
Current Time: Mon Oct 26 22:01:44 UTC 2026
Total time taken to generate the page: 0.0064511299133301 seconds
