Toymods » Tech & Conversions » F & G series diff strength?
F & G series diff strength? Thu, 09 January 2003 22:10 Go to next message
Hello, I am hoping someone might have a rough idea of the amount of HP and punishment the F & G series diffs will handle. I'm thinking of putting one in the RA28, though unsprung weight is a concern so i'm thinking if an F series will handle the power then it might be the better option over the heavier G series.
Anyone know the weight differences between the stock T series RA diffs, F & G? And how do BW diffs compare to these?
On another note, anyone ever seen a early celica converted from live axle to an IRS rear end?
Joel
Re: F & G series diff strength? Thu, 09 January 2003 22:55 Go to previous messageGo to next message
I just picked up and placed the Corona Mk2 F series diff I have in the backyard on a set of bathroom scales and it registered 55kg. It's complete drum to drum and with handbrake cable. I'm not very strong but I can't pick up a complete Hilux diff on my own. I'd say it's over 70 kg. T series are pretty lame...any serious power/torque + abuse will lead to a premature demise.
The boys in the US have run 450+ hp thru std MA61 F series rears. The main problem you will find is the lack of quality LSDs for the F series. The Hilux diff on the other hand has a huge range of OEM and aftermarket LSDs. The G series diffs are an order of magnitude stronger again.
I'm not a fan of the Borg Warners for a multitude of reasons - I haven't got anything nice to say about them so I won't say it at all.
Re: F & G series diff strength? Thu, 09 January 2003 22:59 Go to previous messageGo to next message
Thanks very much for going to that trouble!
From those figures i'd say the F series will be strong enough, just suppose its a matter of finding a decent LSD for it. I heard someone say that the front diff in some hilux's might have a F series LSD?
Re: F & G series diff strength? Thu, 09 January 2003 23:04 Go to previous messageGo to next message
MA61 and LiteAce 4wd would be your most likely sources for an F series LSD. Not sure on the Hilux front diff - I haven't seen one so I can't say yes or no with confidence. If you have a spare 1400 or so you can get a TRD one from NZ.
I should also add, if you want an F series disc brake rear end, the MS112 Crown is the diff for you. Solid discs, sliding caliper, easy to convert to vented rears (I have done this). Might be a tiny bit heavier than Mk2 diff.
[Updated on: Thu, 09 January 2003 23:07]
Re: F & G series diff strength? Fri, 10 January 2003 00:12 Go to previous messageGo to next message
Any idea what the width is of the MS112 Crown diff?
Re: F & G series diff strength? Fri, 10 January 2003 00:13 Go to previous messageGo to next message
~1410mm wheel mounting hub to wheel mounting hub.
ddeane
PNG
Re: F & G series diff strength? Fri, 10 January 2003 01:09 Go to previous messageGo to next message
Gidday
One option that you can take is to have a Mk 2 Supra (LSD) hemisphere built into your F series diff. I have just had this done and it is a cost effective approach. The completed centre has then been put into a '76 mark 2 corona casing which has had the celica suspension brackets fitted, RT141 disc brakes attached and it is all now running under my 23.
Craig
Re: F & G series diff strength? Fri, 10 January 2003 01:51 Go to previous messageGo to next message
Craig would you mind letting me know a rough cost of this work?
Re: F & G series diff strength? Fri, 10 January 2003 02:49 Go to previous messageGo to next message
Sure, but you have to find a Mk2 Supra LSD first....easier said than done. Going price here in Melb was ridiculous (>$700!!) for a non warranty 2nd hand one Shocked . The prices actually made the TRD one look attractive. When you find one, the actual cost of swapping the hemisphere in is around $80-100.
ddeane
PNG
Re: F & G series diff strength? Fri, 10 January 2003 04:01 Go to previous messageGo to next message
Mk 2 diffs are a bit of a problem to source, but remember that you can always use a hiace or hilux lsd centre which cost $300-$400. My diff bloke reckoned that the Mk 2 hemisphere was one of the better designs that he had seen - although he was not unhappy with the normal F series LSD.
Anyway the costs!
Mk 2 Corona diff - if you look around you should get one for around $100 - but have a look for an equivalent Hilux/Hiace that is the correct width.
Transfer of suspension pickup points from existing diff - $200
RT141 disk brake rear - $250 - have a read of the tech. article for more detail.
Reface rotors $20
New kits $60
Wheel bearings and fitted $140
Shorten tailshaft 20mm - $130
You can most likely do a dunnydoor diff for the same amount but it is difficult to get the ratios you want and the LSD is a bit suspect.
Craig
Re: F & G series diff strength? Fri, 10 January 2003 04:39 Go to previous messageGo to next message
Funny enough i've actually got a corona mk2, but its my run around car.. KNow of a few at the wreckers in Syd though. Will have to go scout those maybe.
rob_RA40
c'town, NSW
Re: F & G series diff strength? Fri, 10 January 2003 05:20 Go to previous messageGo to next message
i know of a few places u can source a MK2 corona
pick and payless blacktown have 3 MX10's and a wreckers in campbelltown has an MX10 as well think its called road tested spares.
Re: F & G series diff strength? Fri, 10 January 2003 07:24 Go to previous messageGo to next message
Look out for any MS112 diffs while you are out there....it has disc brakes setup already and is likely to be cheaper than getting the RT141 backing plates/brakes and then machining to fit. Your only expense then will be to transfer the suspension points.
clubagreenie
1st street on the right
Re: F & G series diff strength? Fri, 10 January 2003 10:30 Go to previous messageGo to next message
MS112 next to the MS55 and in front of a MK2 at pick n payless, all have rear ends under them
thetoyman75
Club President
icon10.gif  Re: F & G series diff strength? Mon, 13 January 2003 15:19 Go to previous messageGo to next message
Joel,
Mate there are 2 RA23's in canberra with F series Diffs under the back of them and the owner of one should be up here for Dyno day so if you can make it drop down and I'll point you in his direction Smile
Invisible Throw
Re: F & G series diff strength? Mon, 13 January 2003 23:34 Go to previous messageGo to next message
Sounds like you guys in OZ need a JDM AE86 diff w/ LSD Razz its light, disc rear as well as disc handbrake and it can handle 300hp easy.
Re: F & G series diff strength? Tue, 14 January 2003 00:00 Go to previous messageGo to next message
Invisible Throw wrote on Tue, 14 January 2003 10:34
Except it's T series, rare, expensive and can't handle any serious torque.
Re: F & G series diff strength? Tue, 14 January 2003 00:09 Go to previous messageGo to next message
Is Jamie with his twin-turbo 1UZFE still using the AE86 diff? That thing would have S**TLOADS of torque! Evil or Very Mad
I wouldn't go to the hassle personally, the fact that it is rare and expensive means that it'd also be expensive to replace if it can't handle the torque.
Re: F & G series diff strength? Tue, 14 January 2003 00:22 Go to previous messageGo to next message
gianttomato wrote on Tue, 14 January 2003 11:00
And "torture". Razz
Re: F & G series diff strength? Tue, 14 January 2003 00:24 Go to previous messageGo to next message
I just brought a whole MS112 Crown for $500.. Will rip the diff out for my Celica, and am confident that all the bits I need will be there such as cables etc.
Then I can put the 5ME engine into my 73 Corona which currently has the M series engine.
Ended up a perfect deal really as I have been chasing both a diff and engine upgrade for the run around car.. Found it in 1.
Anyone want any Crown parts as I'll have a whole car now less engine and diff.
Re: F & G series diff strength? Tue, 14 January 2003 00:50 Go to previous messageGo to next message
A side note, I used a handbrake cable from a Hiace van.
EDIT: By the way great pickup.
[Updated on: Tue, 14 January 2003 01:21]
Invisible Throw
Re: F & G series diff strength? Tue, 14 January 2003 00:59 Go to previous messageGo to next message
The T series is enough for a 4A-G Turbo.
Anything else and I'd have to say upgrade.
TD42T
Mildura
Re: F & G series diff strength? Tue, 14 January 2003 04:39 Go to previous message
Going back to one of the first posts all live axle Hiluxs are G series front and rear.
HZJ landcruiser are G series front aswell.
marty
Previous Topic:suspension question
Next Topic:MA-70 green light under dash?
Current Time: Sun Nov 22 18:23:14 UTC 2026
Total time taken to generate the page: 0.0079569816589355 seconds
